Michelin Power Race meduim/soft : Yamaha R1 Forum
Motorcycle.com Classifieds!Motorcycle.comGraves MotorsportsSportbikeTrackGear
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > Tire Tech Forum
Tire Tech Forum Everything tire related post it here.
Old 07-25-2008, 03:24 PM   #1
rhoag
Bikes: BMW S1000RR GSX-600R
Sorry if this has been asked before but, I have searched the forum and really didn't find the info I was looking for. I normally do 3 or 4 track days a year and have been wanting to try some different tires. I have been using corsa III's and they are ok. So I ran across a deal on a Power Race Medium Soft 190/50ZR 17. I am going to Blackhawk farms for a PTT trackday and will be in the intermediate group, so I started looking for a front tire and any info about these tires I could find. From what I have found I should run a power race 120/70ZR 17 meduim/soft front. But, I have also found alot of websites selling combo deals and they are selling 180/50ZR 17 with the 120/70ZR 17. I have also found posts saying they don't warm up fast and that you should run the rear at 22-25 PSI front at 30 PSI. The track is short and technical where you are not at high speeds alot like Road America and the air temp will probably be between 75 and 85. Should I just get the 120/70ZR17 meduim soft or should I just by a combo deal? What air pressure would you run in these conditions? Anyone with experience using these tires on the track I would appreciate your input.
Thanks
rhoag is offline   Reply With Quote
Old 07-25-2008, 04:02 PM   #2
Skeeter
Forum Moderator
Skeeter's Avatar
Bikes: '06 Raven R6
My last track day I ran the Michelin combo 180 PR4 rear and 120 PR2 front on my '06 R6. Actually, I think they were dual compound at least the rear was. Not sure on the front. I ran about 24 psi in the rear and 29 psi in the front. I had them on tire warmers all day. I had no issues hitting it hard on the first lap of the session. Never did slide them or have any " oh shit" moments. Track was JenningsGP. This was back in Feb, so the temps were cooler.
Rest in Peace Glenn "Elvis" Breaux - June, 17th 2007 and Chad Clifton - June, 25th 2008. You will always be with me when I ride. I will never forget you.
Skeeter is offline   Reply With Quote
Old 07-25-2008, 05:01 PM   #3
Mountain Lion
on the track
Mountain Lion's Avatar
Bikes: 07 R1, 04 R6 Track Bike
Set them at 21-22psi rear, 30-31 front. You should see a rise of around 4psi when hot.
You'll probably want the PR5 compound for the rear. PRC for the front. PR4 compound is for extreme heat..like 90+ and super hot surface temps.
Mountain Lion is offline   Reply With Quote
Old 07-26-2008, 07:36 PM   #4
len914
len914's Avatar
Bikes: 2010 R1
yes, the PRC is a great tire. I have a set waiting for my next trackday.
len914 is offline   Reply With Quote
Old 07-28-2008, 04:43 AM   #5
rhoag
I found this write up on gixxer.com and it created more questions. I have a regular power race series meduim/soft which according to this is different then the PR series? But, it says a front meduim/soft is a bit softer than a rear. I am leaning toward just getting the 120/70ZR 17 meduim/soft. The guy that made the post is a dealer so one would hope that he is knowledgable about these tires.
* Ok, this gets confusing so we’ll try and make it simple. Michelin makes two separate Power Race tire line ups. The Power Race and then the Power Race “PR” series. The “PR” series are made specifically for the North American market and feature more technologically advanced and different tread compounds and casing construction than “regular” Power Race. “PR” models are typically only available from authorized race tire distributors. Altogether, there are seven (7) different compounds. Standard Power Race: Fronts and rears in the following compounds: Soft, Medium-Soft and Medium. The front compounds are slightly softer than the rears. (Example: A Medium front/rear combo will have a front that is slightly softer than the rear even though they are both medium compounds.) To identify the compound look on the sidewall of the tire and the compound will be directly follow the words “Power Race”. We Stock: Front 110/70 soft, 120/60 soft, 120/70 soft(PR1), med-soft(PR2), medium. Rear 150/60 soft, 160/60 med-soft & medium, 180/55 soft(PR3) med-soft(PR4) medium, 190/55 med-soft & medium.
* Power Race “PR” Series – We stock the PR1 and PR4 combo and were able to get a special very special deal on PR1 & PR4 combos. We also have some other PR series tires such as the PR2(med-soft) front, PRC (soft triangulated) front and PR5(medium) rear, but they are rather expensive. Track Notes: Are you are running an SV-650 or new Ninja 650 twin? The PR1 with a Power Race 160/60 medium makes a great track day and race combo. Got one of the hot 600 in-line fours? The PR1 and PR4 combo sets give BIG dollar race tire performance at a smoking good price. If you take your bike on the street occasionally, or want a little harder compound for those really hot summer days, we suggest the Power Race medium front and rear combo. You 1000cc riders have a couple of different choices… The PR1 or PR2 front is an excellent front choice combined with a PR4 or power race medium rear. If you have a 6-inch rear wheel or just like the profile, the Power Race 190/55 rear is a phenomenal rear tire and personal favorite of the authors. We offer the 190/55 in med-soft and medium, with the medium being the best choice for most riders and conditions. IMPORTANT SAFETY NOTE: The 180/55 and 190/55 Power Race & PR tires run 22 – 24 PSI. Do not run above or below this pressure! Power Race & PR fronts run 31-33 PSI.
* Who Should Buy This Tire: Track day riders and racers all compounds based on personal preference. Street riders who ride “near the limit” medium compound.
Old 07-28-2008, 05:02 AM   #6
r1_dav3
R190-`Tyre Fryer`
r1_dav3's Avatar
Bikes: 10r1
im on my 6th power race medium soft front and use them for combined street and track. the R1 should come out with these imho they are perfect. the medium center transition to the soft side gives great feedback for trailing brakes. whats sliding on medium is backing in on the soft rubber.
i set about 30psi cold looking for a 5 degree difference between cold and hot
combine with a rear power race medium or pilot race hard or pilot race H2 you will have to be pretty good to unstick them
Originally Posted by beavisr1 View Post
22nd Jan 2006: i have it hooked to my horn button and i flip the MPS switch by my left leg and tur it on and hold the horn button under full throttle and wooooooooooooooooooooooooooooooooooooooooooooooooo oooooooooooooooooooooooooooooooohhhhhhhhhhhhhooooo ooooooooooooooooooooooo
3rd Aug 2006: Please be the plugs please be the plugs please be the plugs please be the plugs please....well you get the Idea.......
r1_dav3 is offline   Reply With Quote
Old 07-28-2008, 09:37 AM   #7
marcaztls
Good info here guys, especially on the tyre pressure front.
I'm about to try a set of Power Race mediums in a couple of weeks at Oulton Park track. I've got a 120/70 front and a 190/55 rear. I'll report what I find
marcaztls is offline   Reply With Quote
Old 07-28-2008, 10:58 AM   #8
Skeeter
Forum Moderator
Skeeter's Avatar
Bikes: '06 Raven R6
* Ok, this gets confusing so we?ll try and make it simple. Michelin makes two separate Power Race tire line ups. The Power Race and then the Power Race ?PR? series. The ?PR? series are made specifically for the North American market and feature more technologically advanced and different tread compounds and casing construction than ?regular? Power Race. ?PR? models are typically only available from authorized race tire distributors. Altogether, there are seven (7) different compounds. Standard Power Race: Fronts and rears in the following compounds: Soft, Medium-Soft and Medium. The front compounds are slightly softer than the rears. (Example: A Medium front/rear combo will have a front that is slightly softer than the rear even though they are both medium compounds.) To identify the compound look on the sidewall of the tire and the compound will be directly follow the words ?Power Race?. We Stock: Front 110/70 soft, 120/60 soft, 120/70 soft(PR1), med-soft(PR2), medium. Rear 150/60 soft, 160/60 med-soft & medium, 180/55 soft(PR3) med-soft(PR4) medium, 190/55 med-soft & medium.
* Power Race ?PR? Series ? We stock the PR1 and PR4 combo and were able to get a special very special deal on PR1 & PR4 combos. We also have some other PR series tires such as the PR2(med-soft) front, PRC (soft triangulated) front and PR5(medium) rear, but they are rather expensive. Track Notes: Are you are running an SV-650 or new Ninja 650 twin? The PR1 with a Power Race 160/60 medium makes a great track day and race combo. Got one of the hot 600 in-line fours? The PR1 and PR4 combo sets give BIG dollar race tire performance at a smoking good price. If you take your bike on the street occasionally, or want a little harder compound for those really hot summer days, we suggest the Power Race medium front and rear combo. You 1000cc riders have a couple of different choices? The PR1 or PR2 front is an excellent front choice combined with a PR4 or power race medium rear. If you have a 6-inch rear wheel or just like the profile, the Power Race 190/55 rear is a phenomenal rear tire and personal favorite of the authors. We offer the 190/55 in med-soft and medium, with the medium being the best choice for most riders and conditions. IMPORTANT SAFETY NOTE: The 180/55 and 190/55 Power Race & PR tires run 22 ? 24 PSI. Do not run above or below this pressure! Power Race & PR fronts run 31-33 PSI.
* Who Should Buy This Tire: Track day riders and racers all compounds based on personal preference. Street riders who ride ?near the limit? medium compound.
Great info. I decided to make it a sticky so others who run or want to run Michelin race rubber can view it.
Old 07-28-2008, 11:50 AM   #9
gixxerfrank
getting away with it since 84!
Bikes: 02 r1
i loved my dunlop 209 gp's! and the guys from dunlopracing.com made it so much better!
gixxerfrank is offline   Reply With Quote
Old 07-28-2008, 11:57 AM   #10
rhoag
I called and ordered the meduim/soft front. Now my only concern is heat cycles. I don't have tire warmers, because I don't do that many track days. The guy I talked to said they will last a weekend (I don't ride that hard) but, with out tire warmers take it easy the first 2-3 laps of each session. He also said to check them to make sure you can stick a thumb nail into them not getting to hard from heat cycles.
Old 07-28-2008, 03:44 PM   #11
Mountain Lion
on the track
Without warmers the tires should be good for 3 intermediate track days, after that you're pushing it. I wouldn't suggest mixing them as street and track tires. IE do a track day, ride a 600 miles on the street, then go back out on the track. Get the CT for something like that.
I'll note again, the PR4 is for high temperature ranges which is why they're sold as cheap combo deals from a lot of online vendors. Will they work for what you're doing..yes, but they're probably going to tear or wear oddly, reducing life if your running in temps below 90 degrees. If you're an advanced rider or racer, avoid these deals unless you'll be riding in the temps for which they were designed.
Old 07-28-2008, 08:51 PM   #12
r1_dav3
R190-`Tyre Fryer`
r1_dav3's Avatar
Bikes: 10r1
imho if you are out riding power race medium softs and need to be worried about things like heat cycles, you probably already have enough experience with destroying tyres so as to be able to make your own decisions about when a tyre is stuffed
Old 08-07-2008, 03:27 AM   #13
marcaztls
Hey guys, anyone know what a Power Race C front tire is? I can't even find any info on Michelin's website about it. It's listed in all my tyre suppliers catalogues and I have 2 of the actual tyres sat in front of me now...
Thanks in advance
Old 08-07-2008, 02:44 PM   #14
Aron213 ti
Aron213 ti's Avatar
Bikes: 03 R1 and Raven's gixxer
Thanks in advance
PRC is a front tire, taller profile than the older ones, you will have to adjust your suspension a little, but a damn good tire
http://img.photobucket.com/albums/v347/Aron213/Image3-1_zpsab24bb95.jpg
Aron213 ti is online now   Reply With Quote
Old 08-07-2008, 03:01 PM   #15
Aron213 ti
Aron213 ti's Avatar
but thats old info, I dont even think you can still get those tires in PR1,2...everything is PRC now, and the rears are now called PR-D,E and F
And PR-1's and 2's sucked ass
Old 08-07-2008, 04:16 PM   #16
Skeeter
Forum Moderator
Skeeter's Avatar
Bikes: '06 Raven R6
Actually, you still can. STG is selling them. Yes, I agree the PRC is a very premium front tire. I ran the PR2 {front} at my last track day and thought is did pretty well {at least for me}. Maybe, STG will be selling out of the older stock as the newer product comes in.
Old 08-08-2008, 01:10 AM   #17
marcaztls
Fantastic mate, thanks very much for the info
Old 08-08-2008, 06:41 AM   #18
Piper
R1 is yummy
Piper's Avatar
Bikes: 2009 R1 (blue), 2012 S1000rr
The 'C' front being taller gives great side grip when leaned over, and a very fast turn in. The 'C' front works beautifully with the 'E' 190/55 rear on the 07R1. Definitely recommended...
Piper is offline   Reply With Quote
Old 08-08-2008, 06:49 AM   #19
marcaztls
Sounds good
Well I've been given brand new PRC front and soft rear to try on a trackday next Wednesday so I'll report back what I find
Old 08-08-2008, 06:10 PM   #20
Skeeter
Forum Moderator
Skeeter's Avatar
Bikes: '06 Raven R6
Sounds good
For sure. Give us your feedback.
Race take-offs Michelin Power Race-Dunlop208gp naaz90 Bikes For Sale 3 11-02-2007 01:28 PM
Race take offs, Dunlop 208GP and Michelin Power Race naaz90 Bikes For Sale 4 08-10-2007 06:21 AM
Michelin Power Race 120/190 Med-Soft Take-off Tires mikdivad Bikes For Sale 8 07-25-2006 06:11 AM
New Michelin Power Race Medium Soft at track Lespaul66 General Motorcycle Discussions 34 07-17-2005 04:21 AM
Michelin Pilot Race soft/M compound 180???? R1one Mechanical / Help 4 10-25-2004 08:17 AM
