2nd gear slip : Yamaha R1 Forum
00-01 R1 Mechanical Help Mechanical and Critical Issues for the 00-01 R1
Old 08-12-2008, 01:27 PM   #1
brakepad21
i wanna ride!!
brakepad21's Avatar
Bikes: 2001 r1....the only one i care about
2nd gear slip
how hard is it to fix this on a 01'... has anyone done it before?
brakepad21 is offline   Reply With Quote
Old 08-13-2008, 06:41 AM   #2
colemine77
Caution: Horses in transit
colemine77's Avatar
Bikes: 2012 CBR1000RR
Hard! You have to split the whole motor. The gearbox is the last thing you take out when you take the motor apart.
colemine77 is offline   Reply With Quote
Old 08-13-2008, 06:52 AM   #3
brakepad21
i wanna ride!!
brakepad21's Avatar
thanks man
Old 08-15-2008, 01:24 PM   #4
dandable
Wink i had the same issue
The reason you are experiencing second gear popping is due to the shift dogs on second gear being worn and rounded off. instead of a nice clean, sharp edge for the slot the shift dog rests in and hold onto while in second gear, it is rounded off, which causes it to slide "pop" right back out when heavy throttle is applied. The reason it doesn't just go back into neutral is because as it "slides" out, it falls back and "slides" back into the next slot-hence the "popping". effect. And with every pop, it will get worse and worse. Like the other guy said, you have to take the entire motor out of the bike and split the bottom half of the engine/trans case. but dont worry, its not as bad as it seems. With parts and everything it came to about $1,200. Wanna know how to avoid having this problem in the future? first of all, when shiftong gears, regardless of what gear, be very gentle on the shifter. if you force the shifter into gear, it will bend the shift forks. Second, you must find that sweet spot where your R1 likes to be shifted. Believe me, it is tough. i am still searching for mine. i have found it best to shift early on in the lower engine RPM's.
If you have any further questions, just ask. I am pretty knowledgable now. Wish i weren't tho.
Dan
dandable is offline   Reply With Quote
Old 08-15-2008, 01:43 PM   #5
brakepad21
i wanna ride!!
brakepad21's Avatar
Dan
i wouldn't have a problem taking the motor out and apart.. i just dont think i could get it back together and it still run....
while its apart i should replace the pistons, rings,valves, cams, ect....is there any other major part that i should look into buying before i do this?.... and is this something i should even attempt?....
Gear slip Foot General Motorcycle Discussions 7 06-24-2008 12:17 AM
2nd gear slip step by step guide binnyblade 98-99 R1 Mechanical Help 11 06-21-2007 02:28 PM
street gear for offroad gear soudry Trade section 0 12-05-2006 05:29 PM
accumen digi gear, digital gear indicator kozumasbullitt Bikes For Sale 4 04-01-2006 05:11 PM
Gear whine, every gear, all the time. Normal? Brewd@wg Mechanical / Help 8 01-16-2003 07:00 AM
