» Site Navigation |
» Motorcycle Forums
Oil and Lubrication For discussion on oil and lubrication
08-15-2008, 05:29 PM
#1
Loves To Lean
Bikes: 2009 R1 Raven, 2007 R1 (Gone)
Is 2500 miles a Good time to go Synthetic?
I am wonder if this is a good time to go synthetic. Also will it help with running a bit cooler. About to gut the cat also for heat reasons.
Thanks.
Flash-Tuned ECU/w Dyno Tune,Leo Vince exhaust, 520 Renthal chain and sprocket kit,Renthal clip-ons, Smog Block_off Plates, K&N Air Filter, Watsen Flush Mounts, Vortex Rearsets,Running Power 3's, Asv Levers
08-18-2008, 03:01 PM
#2
Forum Moderator
Bikes: '06 Raven R6
How many times have you changed the oil? I like to go through several cycles with just regular mineral oil. I usually wait until I hit around 5K miles before I make the change, but this is just me.
Rest in Peace Glenn "Elvis" Breaux - June, 17th 2007 and Chad Clifton - June, 25th 2008. You will always be with me when I ride. I will never forget you.
08-18-2008, 03:58 PM
#3
Loves To Lean
Only the first 800 mile oil change. I would always change the oil every 1000 miles on my other bikes, but now I dont have a garage to do it myself and it is a real pain
08-18-2008, 04:21 PM
#4
Aces and Eights
Bikes: 2007 GSXR1000
My opinion...once the oil is broken in you can go synthetic. Break-in periodis after about the firt 600 miles. Although this number varies accoding who you ask. I mad the switch to synthetic at 1000. No harm.
08-18-2008, 04:30 PM
#5
DILLIGAF
Bikes: 06R1
Good info. I'm at about 2500 miles and was wondering the same thing. I guess I'll make the change.
Rain or shine I'm ridin.
R1-016 'Venom' Squadron
"Fat arms are NOT huge biceps, they're fat arms. Cover up"
08-18-2008, 04:37 PM
#6
Aces and Eights
I meant to say "once the ENGINE is broken in on regualr OIL" I'm trying to do too many things at once here.
08-19-2008, 09:22 PM
#7
go go juice gonna make me win
Bikes: 2008 R1 Raven
i just changed mine at 2600 to full synthetic. may not be ideal or what most people say, but i don't think it matters any which way.
2008 R1 Raven
PCIIIusb w/FlashTune|Termignoni CF Slipons|Attack Performance Rearsets|Akrapovic Y-Pipe|520 Conversion (-1/+1)|Hyperpro Damper|BlasterX|MRA Racing DB|Gilles Chain Adjuster|BMC Air Filter|Greggs Sprocket Cover|Graves Smog Plates|Speedohealer|GYTR Comfort Seat|Targa Solo Cowl|Tec-Spec Traction Pads|Passenger Pegs Powdercoated Black|Pazzo Shorties|Shogun Crash Kit|Spiegler SS Brake Lines|A&R Motorsports 6000k HID's|Flushmounts|Fender Eliminator|Acumen Gear Indicator
08-20-2008, 12:28 PM
#8
can i go synthetic oil on a 2001 and also will it give me more power
08-22-2008, 10:21 PM
#9
Squid
Bikes: '01 YZ-250,'02 YZ-250, '04 919 (Sold) '05 R1 (Sold) '07 R1
Yes, it is likely that using synthetic oil will free up a little bit of horsepower in your engine.
Like maybe a half.
08-23-2008, 03:53 PM
#10
Bikes: 03 R1 and Raven's gixxer
you can do it after the first oil change
08-23-2008, 09:29 PM
#11
I have an '08 - I've been told my slipper clutch will slip with synthetic, by a guy who has an 07...also owner's manual advises....
no one is having this prob???
2010 Concours14 - the long hauls
2008 R1 (pornstar nail polish colored red)
ZX14 Red - SOLD!
CBR600RR - Track bike
08-23-2008, 10:00 PM
#12
yield
Bikes: 2002 R1 #335 red/white livery
I have an STM slipper and run synthetic, no problems.
Asked if he was afraid of dying in an accident, Marco Simoncelli responded: "No. You live more for five minutes going fast on a bike like that, than other people do in all of their life." rip #58 ciao ciao bello
08-23-2008, 10:27 PM
#13
Thanks!
ZX14 Red - SOLD!
08-26-2008, 10:33 AM
#14
Absolutely not, I just did a rebuild on my race bike which is a superstock class motorcycle, hence this is the first time I have been into its motor. It spun a rod bearing and this is the third clutch I have went through in 7500 miles. My mechanic and I came to a common conclusion that me using synthetic oil is the reason my clutches keep failing and why the bike kept losing power because the sythetic oil was so smooth that in 7500 miles my rings NEVER seated! And the clutch never fully engages because of the same reason so the pressure plates were literally starting to melt. Thankfully the yoyodyne basket and slipper assembly were not hurt. Stay away from synthetics they prematurely killed major parts of my motor.
Chuck Norris built my motorcycle, it runs off the tears of small children and makes 10,000 Hp, he calls it his "street version".
11-02-2008, 12:32 PM
#15
thanks, since this old thread others have told me their 07-08 R1's slip the clutch with synthetic as well. I still haven't tried synthetic in mine ever since a local guy with a sweet blue R1 said his was trouble with it
ZX14 Red - SOLD!
11-02-2008, 08:52 PM
#16
Squid
Castrol Full-syn w/ no problems here...
And I switched from Dino oil...
11-03-2008, 08:14 AM
#17
she drags knees
Bikes: 2006 r1 (raven)
Amsoil is like KY, do work!
11-03-2008, 09:37 AM
#18
Hmmm..... don't see how this is possible. Synthetics do not modify the friction properties - that's a property of the oil additives. Synthetics simply hold up to the shear forces much better than conventional dino stuff.
I suspect that your anticdotes regarding Synthetics and clutch slipage is related to a blend of additives (probably an automotive oil vs a M/C oil) that are part of the friction modifiers package - typical in many automotive motor oils.
Do some research on motor oil before you make any decisions. For me, if I break-in an fresh motor (regardlless of application), I'd do 45 mins or 25-50 miles on a fresh motor and change with conventional oil and filter. Then at 3000 miles or 60-100 hours, I'd change over to a fully synthetic oil and a micronic filter. My personal fav has been Purolator PureOne micronic filters and oil will depend on application. For M/C it's always been Shell RotellaT fully synthetic, but I've been considering trying the Amsoil product.
Change oil and filter every 6 months or 3000 miles and you can't go too wrong...
Jim
04 Blue Mods: A&R race baffles | CAT gut | ceramic exhaust | K&N filter | Grave Velocity Stacks | Roth Block-off plates | PCIII usb | NGK Iridium plugs | Water Wetter | Spiegler SS Brake lines | FE with LED kit | Custom Black CF comfort seat | LED Flushies | Speedo healer | Shogun Sliders | Solo seat cowl | Blue LED underlighting | Vortex gas cap | Harri's Grips | Deltran Battery tender
11-03-2008, 09:42 AM
#19
PS - I also like to use a magnetic oil drain plug. You'd be surprised at how well it works to collect the ultra fine powdery ferous metal that gets circulated in the motor oil and not caught by the filter.
11-04-2008, 07:06 AM
#20
Bikes: Blue 07 R1 sold
Yes i also use the magnet drain plug, i use Mobil 1 and change every 2,000, my main concern is the trans, clutch, using the same three quarts of oil as the engine, rapid bearing wear if the oil is not changed.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
