In my opinion, your real question should be about what oil (and air) filter to use...
I'd run the Purolator PureOne Micronic filter (PL-14612).
With respect to the oil, I'd use Shell Rotella-T full Synthetic 5w-40, and change the oil and filter more often. For the first 2-3 oil chnages, I'd send a sample in for anaylsis so you could get a real good gauge of how well you're protecting the engine and how often you'll need to change the oil and filter.
On the air filter, you'll need something really good and that can be changed or cleaned often. I don't have any specific suggestions there - but maybe something that uses a high-quality filter oil-foam type?
04 Blue Mods: A&R race baffles | CAT gut | ceramic exhaust | K&N filter | Grave Velocity Stacks | Roth Block-off plates | PCIII usb | NGK Iridium plugs | Water Wetter | Spiegler SS Brake lines | FE with LED kit | Custom Black CF comfort seat | LED Flushies | Speedo healer | Shogun Sliders | Solo seat cowl | Blue LED underlighting | Vortex gas cap | Harri's Grips | Deltran Battery tender
