DOT 4 or DOT 5 Brake fluid : Yamaha R1 Forum
Oil and Lubrication For discussion on oil and lubrication
Old 10-26-2008, 02:53 PM   #1
TheBigO
TheBigO's Avatar
Bikes: 2006 R1
So any ill effects of using dot 5 brake fluid. I went to the Yamaha dealership where i bought my bike and ask for dot 4 they didn't have any but they had dot 5. i asked if its ok to use dot 5 inplace of dot 4. so I bought it. Now i'm debated wheater to change it back to dot 4. Didn't notice any difference but i'm worried it will screw up some of the seals on the calipers. Any ideas.
TheBigO is offline   Reply With Quote
Old 10-26-2008, 05:04 PM   #2
Warrior102
Outside your window...
Warrior102's Avatar
Bikes: 2004 R1
Don't do it! You must flush the entire system with alcohol and even then you could have seal problems.
http://en.wikipedia.org/wiki/DOT_5
Warrior102 is offline   Reply With Quote
Old 10-26-2008, 05:37 PM   #3
Sharksawyer
Is there anybody out there?
Bikes: 2000 R1
From what I know, DOT 5 is NOT compatible with DOT 3/4. You must get every bit of the old DOT 4 out of the system or very bad things can happen. DO NOT ride the bike until you get this sorted out! If it were me, I'd be pulling all brake lines and replacing with stainless. That way, there is no chance of a reaction. If you already have stainless and don't want to replace your lines, you will need to flush the entire system. I'm not sure the safest way to do this but you must do it the proper way or you will have problems. I'd be getting some professional advice if I were you and I'd avoid the dealership at all cost based on the info they provided.
Mark
99 R1
Old 10-26-2008, 06:06 PM   #4
bender
bender's Avatar
Bikes: 04 R1, 08 CBR 1000RR
Is it dot 5 or dot 5.1? If it's dot 5 and you've put it in your bike, it's brakes are fooked. Dot 5.1 will work with dot 3 and dot 4, but dot 5 won't.
bender is offline   Reply With Quote
Old 10-26-2008, 08:34 PM   #5
TheBigO
TheBigO's Avatar
Bikes: 2006 R1
wow. What i did is drained the Dot4 then added the Dot5 and just bleed the brakes until all the dot 4 was out and all that was left coming out is dot 5. I may take everything apart and clean with brake cleaner and reassemble and add the dot 4 back and just chunk the dot 5 at the dealer ship. what a tool over there i asked if it is compatible with dot 4 and he said "oh yeah the mix fine" dayum I am never going back there again. thanks.
Old 10-27-2008, 08:45 AM   #6
yankin&bankin
Squid
yankin&bankin's Avatar
Bikes: '01 YZ-250,'02 YZ-250, '04 919 (Sold) '05 R1 (Sold) '07 R1
Are you sure it's DOT 5 and not DOT 5.1?
Like someone else said, DOT 5.1 IS compatible with DOT 3 or 4, but DOT 5 is NOT.
If you've already put the DOT 5 in, remove it and flush your system with rubbing alcohol. Then you can use the DOT 5 if you want to, but it will probably have a spongier feel than DOT 4 (DOT 5 is silicone). IF you do use the DOT 5, be sure to get ALL the old stuff out of EVERY part of your brake system.
DOT 5 does have its advantages, including the fact that it is non-hygroscopic, and will not damage paint or plastic finishes. Also, it is more stable in extreme temps (according to Wikipedia).
Let us know how it turns out.
yankin&bankin is offline   Reply With Quote
Old 10-27-2008, 09:53 AM   #7
TheBigO
TheBigO's Avatar
Bikes: 2006 R1
Its dot 5 and it does feel spongier on not really liking it to much. i guess I'll drain it and clean the entire system. and refill with dot 4. thanks for the help.
Old 10-27-2008, 09:59 AM   #8
squidhunter
(Trackday Addict)
squidhunter's Avatar
Bikes: 03&07R1 & 07R6
learned something new today. Thanks.
R1-014 Dragon Squadron #1
Covering: West/SW USA: CA, HI, NV, AZ,
Originally Posted by SAB View Post
Forget Nobama and McLame.....
Squid for Pres 2009!
squidhunter is offline   Reply With Quote
Old 10-27-2008, 10:05 AM   #9
R1
BAND
R1's Avatar
I put dot 5 in my bike back in january after i did the ss brake line install and have had NO problems at all. although in the bleeding it flushed out alot of brake fluid.
It says dot 5 and not dot 5.1
again i have had NO seal problems, the brakes work mint and i plan on using the same fluid for the rear next season when i flush all my fluids.
http://www.r1-forum.com/forums/signaturepics/sigpic76170_5.gif
Got banned on the R1-Forum and I'm about to get ban on the R6-Forum.
R1 is offline   Reply With Quote
Old 10-27-2008, 01:41 PM   #10
fullhouse
TEAM PIMP HAND STRONG
fullhouse's Avatar
Bikes: 2005 R1 Raven
it wont happen streight away R1slowflyer, it will happen over time
Sig Petrol style
fullhouse is offline   Reply With Quote
Old 10-27-2008, 02:50 PM   #11
R1
BAND
R1's Avatar
well in that case a full flush is in order...
I do know that i flush the system out 3 times during the install.
if in fact it is an issue than i guess i already did the damage.
Old 10-27-2008, 04:06 PM   #12
fullhouse
fullhouse's Avatar
lol, just keep an eye on it
Sig Petrol style
Old 10-27-2008, 04:22 PM   #13
R1
BAND
R1's Avatar
Old 11-21-2008, 01:30 PM   #14
r1mach
damn i used dot 5 also when the dealer said it was ok as long as flushed the entire system first. hmmmmm maybe should switch it but problem was couldnt find 4 at the time anywhere
r1mach is offline   Reply With Quote
Old 11-21-2008, 05:56 PM   #15
R1
BAND
R1's Avatar
oh i finally checked the other day and guess what
dot 5.1 baby
i was really starting to worry for a bit there...
Old 06-05-2013, 06:38 AM   #16
asdfjklm
My R6 is better than your R1!
asdfjklm's Avatar
Bikes: White 09 R1 and Red 04 R6
Location: Belgium (used to be in FL) Holy Shyt it's cold here!!!
bump for lots of good info.
Rubber Down. Shiney Up.
ZW
asdfjklm is offline   Reply With Quote
Old 06-05-2013, 08:39 AM   #17
TheBigO
TheBigO's Avatar
Bikes: 2006 R1
I ran that 5.0 with zero issues as far as seals go. Only thing was the brakes felt spongy. I would have switched back to 4 but bike has been sold.
Old 06-05-2013, 09:18 AM   #18
jake300win
assfault junkies
jake300win's Avatar
Bikes: 2007 r1
Yea I don't know why the named dot 5.1 the way they did. It only causes confusion.
Lesson you cant trust the parts guys at the dealership.
Sent from Motorcycle.com App
"That doesn't sound right but I don't know enough about stars to dispute it"
jake300win is offline   Reply With Quote
Old 06-11-2013, 11:34 AM   #19
Racer Dude
Racer Dude's Avatar
Bikes: 00 R1
DOT 5 is a silicone-based brake fluid (contains at least 70% by weight of a diorgano polysiloxane). Unlike polyethylene glycol based fluids, it is hydrophobic. DOT 5.1, like DOT 3 and DOT 4, is a polyethylene glycol-based fluid (contrasted with DOT 5 which is silicone-based). Polyethylene glycol fluids are hygroscopic and will absorb water from the atmosphere, which is necessary to prevent sheer and undiluted water in the braking system, which is very corrosive. Also, water droplets can freeze in the pipes, thus blocking the system.
Glycol based fluid absorbs moisture, and disperses the moisture throughout the system and contains corrosion inhibitors. Silicone fluid does not allow moisture to enter the system, but does not disperse any that is already there, either. A system filled from dry with silicone fluid does not require the fluid to be changed at intervals, only when the system has been disturbed for a component repair or renewal. The United States armed forces have standardised on silicone brake fluid since the 1990s. Silicone fluid is used extensively in cold climate, particularly in Russia and Finland.
With DOT 3, DOT 4 and DOT 5.1, moisture diffuses into the fluid through brake hoses and rubber seals and, eventually, the fluid will have to be replaced when the water content becomes too high. Because Silicone brake fluid does not absorb and disperse water throughout a brake system, if water does enter the system, (as in the system being disturbed for a component repair) the system can have pockets, or sections of corrosive moisture. Once moisture enters a silicone based brake system, corrosion is inevitable, although if the system is "not" disturbed, the system can go many years without service.
I'll stick with DOT 4
Bogie is the man, and I should learn not to mess with him
Racer Dude is offline   Reply With Quote
galfer ss brake lines and brake fluid question mars General Motorcycle Discussions 19 12-14-2005 06:32 AM
brake fluid R-1 Mechanical / Help 1 07-31-2005 10:36 AM
Brake Fluid??? brdove Mechanical / Help 15 06-08-2003 10:12 PM
brake fluid help JoeBee Mechanical / Help 2 03-13-2003 08:14 AM
brake fluid..... Rageous 1 Mechanical / Help 4 05-19-2002 11:59 PM
