Suggestions on removing stuck axle bolt??? : Yamaha R1 Forum
Motorcycle.com Classifieds!
Old 12-22-2008, 07:07 PM   #1
j334
Im Ok, Its My Bike Thats Sick!
j334's Avatar
Bikes: 04 R1
I have a couple issues with my 04 R1. First off; I'm trying to remove the rear wheel and the axle bolt won't budge at all!!!! I like to think that I am pretty but this thing will not move. I tried using both the tool that came in my tool box and my 32mm socket to no success. I have taken the tire off a few times before with no problems, but for some reason this time it's giving me problems.
My 2nd issue is that the cable that attaches to the rear keyhole for the rear compartment came undone and I am not able to access my PCIII or switch out my seat cap to my solo cowl. Any ideas or suggestions on this issue? Thanx
04 R1
Custom Air Brushed Fighter Jet Paint scheme
Custom Pearl White and carbon fiber theme
Mods-M4 exhaust, PCIII, K&N filter, Gilles rearsets, red steel braided brake lines,pazzo levers, carbon fiber airbox, ram air tubes, frame cover, heat shield, chain guard, rear hugger.
j334 is offline   Reply With Quote
Old 12-22-2008, 07:51 PM   #2
Sal_R1
Bikes: 02 Matt Black Streetfighter R1
Spray PB-40 on the thread / bolt and leave it overnight. Heat up the bolt evenly with a torch and it will come right off.
Sal_R1 is offline   Reply With Quote
Old 12-22-2008, 08:00 PM   #3
j334
j334's Avatar
Bikes: 04 R1
Thanx alot man!!! I'll give it a shot... I've never heard of PB-40 but if I can't find that I will just use WD-40 instead...Thanx again
04 R1
Old 12-22-2008, 08:21 PM   #4
lexanidubs09
Getting ready for track!
lexanidubs09's Avatar
Bikes: 07 gixxer 600, 05 R1
i think he meant WD-40
|R1-014 Dragon Squadron|Member # 09|
Covering: West/SW USA: CA, HI, NV, AZ
Originally Posted by 4EverWiKiD View Post
Not that I want to be your dad, but there is the chance that I am.Chances are higher that David is the culprit. He had exact change so he went first.
TEAM SNACH
My 2010 Season Sponsors
Junito70-Bodywork
Socal05R1-Hardparts & Gear
Grom111-Grom photography
Bgesch- Everything
DavidSFC- Alcohol & Bunny Food
Pimp - Track
Deja Vu Showgirls- "M"oral support
lexanidubs09 is offline   Reply With Quote
Old 12-22-2008, 09:16 PM   #5
steveWFL
steveWFL's Avatar
and maybe a big huge hammer
2010 Concours14 - the long hauls
2008 R1 (pornstar nail polish colored red)
ZX14 Red - SOLD!
CBR600RR - Track bike
steveWFL is offline   Reply With Quote
Old 12-22-2008, 09:35 PM   #6
j334
j334's Avatar
Bikes: 04 R1
I couldn't find the PB-40 but I did find some PB-50 and supposedly its better than WD-40. I will see in the morning. If not I'll resort to option B, The "big huge hammer"...
04 R1
Old 12-22-2008, 11:25 PM   #7
Sal_R1
Right you are! PB-50 is the stuff. available at Pep Boys, Sears and mosr major auto places.
Old 12-22-2008, 11:26 PM   #8
Sal_R1
What i meant was, when is the date set for the squadron titty bar ride?
Old 12-23-2008, 01:30 AM   #9
bunnyrbt
Freezing
bunnyrbt's Avatar
Bikes: 2000 R1
I've used a breaker bar and a hammer when mine gets stuck and it works like a charm.
RIP Pierre (DieYoung69) You will be missed brother!!! * It's sammich & beer time
We've reached that comfort level, cause I've been drinking."
Devil1
Definition of ignorant
n. a person who portrays ignorant qualities and is non knowing of facts. used as insult.
adj. a derogatory term used to describe someone who should keep their mouth shut.
bunnyrbt is offline   Reply With Quote
Old 12-23-2008, 05:20 AM   #10
Viper333
G Addict
Viper333's Avatar
Bikes: 04FZ1-04XR650R-02 Raptor-74 Rd350
WD40 and the PB 50 are good for lubricating things but if you want to get something that penetrates into tight or rusted corroded areas you will have better results with a penetranting catalist like liquid wrench.
I personally have had the best results with PB blaster. Its also generally available at most auto parts stores.
http://www.jeepfan.com/reviews/pbblaster.htm
Its doubtful your problem is corrosion and sounds like youre overtorqueing and maybe even lightly galling the threads.
Galling: to lose metal to the other because of heat or molecular attraction resulting from friction.
Dont get so heavy on the nut when securing the axle and dont torque it dry. At least put some WD or oil on the threads.
Use a torque wrench and question the axle torque specs in the manual. Yamaha has been known to enter too high a torque value to things like axles and sprockets.
A torch can also help by expanding the nut a little, but a cheater bar is ususlly the trick.
If possible try to use a 6 point socket because of the less damaging/larger contact area it exerts on the nut.
The axle nut is big enough that its unlikely youll round it off but when you have a high torque condition its best to use 6 points.
As far as the seatlock. That will be fun. Someone thats done that will have to chime in or take a good look at it with someone mechanically inclined before getting at it.
Best of luck
Rick
- Id rather be judged by 12 than carried by 6.
- Horsepower=Too Much is Just Enough
- It's not the years in your life that count. It's the life in your years.
"What do you want me to do? Slow down?" Mick Doohan
Viper333 is offline   Reply With Quote
Old 12-23-2008, 05:31 AM   #11
Piper
R1 is yummy
Piper's Avatar
Bikes: 2009 R1 (blue), 2012 S1000rr
Haven't tried it myself, but I heard that the OEM seat will bend up in the middle, and with enough effort the tab holding it in at the back will pop out.
Piper is offline   Reply With Quote
Old 12-23-2008, 06:04 AM   #12
turd1
turd1's Avatar
Bikes: 98,1/2. R1
Best of luck
Rick
a good post right there...
+1 on the galling theory too!
turd1 is offline   Reply With Quote
Old 12-23-2008, 07:18 AM   #13
Viper333
G Addict
Viper333's Avatar
Thanks and I know.
By the way. All the best to you mates down under for the Holidays.
Old 12-23-2008, 07:23 AM   #14
turd1
turd1's Avatar
Bikes: 98,1/2. R1
Thanks and I know.
right back atcha bro!
damm, i just noticed you've been a member longer than me!
Old 12-23-2008, 07:40 AM   #15
Viper333
G Addict
Viper333's Avatar
Damn thats true. Id have never thought it by the post counts.
I guess I can call you Junior then.
Old 12-23-2008, 07:48 AM   #16
turd1
turd1's Avatar
Bikes: 98,1/2. R1
lol....yep!
Old 12-23-2008, 07:58 AM   #17
KMac
SuperModerateur
KMac's Avatar
Bikes: 1980 Huffy Santa Fe
Just to clarify, you already have the nut off of it, right?....and it's the axle itself that is stuck inside the wheel?
Spray some penetrating lube in there and hit it with an impact wrench a few times at low pressure. A few sharp impulses will do better to break it free than trying to muscle it off with high force. Once you do, I'd suggest replacing it and anything else that was stuck to it. And when you reinstall make sure the axle is not dry, lube it lightly with something.
KMac is offline   Reply With Quote
Old 12-23-2008, 08:02 AM   #18
Sal_R1
The mutual commendation society!
Thanks and I know.
lol....yep!
Old 12-23-2008, 08:37 AM   #19
Viper333
G Addict
Viper333's Avatar
Its unlikely the axle isnt turning with the nut off because the only thing to hold it would be the brake carrier. Everyting else is bearings and with the nut relieved I doubt the spacers could grip it enough to cause the issue.
It happens but is rare and yes the penetrant impact way would be the way to go.
If he has the nut off then the issue is usually the axle wont slide out because of it being siezed/corroded to the spacers and/or bearings.
Many times when you try to hit the end of the axle, the outer arm thats recieving the impact (through the stuck axle/spacer assy) will act like a spring, absorb the impacts and bounce back.
Ive seen guys sledge the shiat out of axles and not get them out, because of that springing action. Sometime a strategically placed heavy piece of wood on the outer arm helps keep it from springing out and exerts more impact load in the axle. Just be careful to not ding up the arm.
I use a handheld airhammer and at its imact rate it hits while the arm is springing back. This has been the best way Ive found to unstick an axle.
Of course you never pound on the end of the axle and destroy the threads. Its best to use a sacrificial nut screwed onto the threads leaving it proud, or put the stock one on backwards at least.
If its not too stuck then a hammer and drift will work with some penetrant.
Either way let us know what it is/was, good luck and dont hurt her.
Old 12-23-2008, 08:40 AM   #20
KMac
SuperModerateur
KMac's Avatar
I don't disagree with any of that. Would be interesting to find out what is holding it, though. I'd feel pretty dumb to find out it was something like the chain was ungodly tight or something else mostly unrelated.
New in bag Ti R1 axle bolt rorlow Bike Parts For Sale 7 12-02-2008 04:01 AM
changing rotors/pads on car, bolt stuck suggestions? rorytsm Off Topic Talk 10 06-23-2008 06:43 AM
Removing rear axle nut?? 03ki11er Mechanical / Help 6 10-19-2006 12:14 PM
Front forks, compression bolt stuck Jack_R1 Mechanical / Help 9 04-06-2006 03:52 PM
Rear axle bolt TITANIUMR1 Mechanical / Help 7 12-05-2002 02:59 PM
