Stock Dyno Runs : Yamaha R1 Forum
SportbikeTrackGear
Old 01-20-2003, 05:31 PM   #1
turnone
turnone's Avatar
Bikes: 2002 Yamaha R1, really fast blue
Stock Dyno Runs
Tomorrow I am going in to Dyno my bike on a Dyno with a buddy of mine from DYNOJET.
Every one has been asking what increase the velocity stacks have over a stock bike
We are going to dyno the bike stock, and then dyno it wiht the velocity stacks on the same dyno..
We will then dyno it with a full Graves Ti system, velocity stacks and PClll. WE will get to see the added HP on the same bike with an actual baseline run...
Everyone hs been wondering and I dont think I have seen any hard numbers on it.
After that we will fine tune the custom map and see if we can get anymore gains from the Graves provided map....
Stay tuned
turnone is offline   Reply With Quote
Old 01-20-2003, 05:34 PM   #2
UT Blue R1
`Are you SERIOUS?`
UT Blue R1's Avatar
Bikes: 02' Blue R1
I hope to see 144+ at back
Ohlins steering damper
Carbon fiber Inlay frame sliders
Carbon fiber Inlay swing arm sliders
Carbon fiber tank protector
Lockhart Phillips V2 Speed Screen (need replacement)
Aritronix alarm w/paging system
Full Akrapovic exhaust w/PCIII
"You don't work, you don't eat, you don't grind, you don't shine..."
UT Blue R1 is offline   Reply With Quote
Old 01-20-2003, 05:55 PM   #3
turnone
turnone's Avatar
144 stock would be some very impressive numbers.... i mainly am doing it to see my personal gains, but also the gains of each thing as no one really knows on here just have a little ideas here and their
Old 01-20-2003, 05:57 PM   #4
Shadow R One
Off Topic mod
Shadow R One's Avatar
Bikes: 04 Ducati 998s FE
With all that it better get damn close to 150
Ah, the elusive balance point...the G-Spot of wheelies if you will.
The early bird gets the worm but the second mouse gets the cheese
http://www.r1-forum.com/gallery/wate...php?file=17141R.I.P. FastblueR1 7-13-03
Shadow R One is offline   Reply With Quote
Old 01-20-2003, 07:13 PM   #5
KRAZY 4MY R1
JUST ....SHUT-UP and RIDE...!
KRAZY 4MY R1's Avatar
Bikes: 02 silver R1 & HD custom(sold) & 97 classic
dyno
my 02 pulled 136 hp stock and 76 torque ,w/709 miles and again at 6000....so post the sheets when you get done w/your mods.....thanxs....Chaz
Just cause ,you have a bike,doesnt make you a rider,.....follow me and I'll show you the way.........
KRAZY 4MY R1 is offline   Reply With Quote
Old 01-20-2003, 07:37 PM   #6
UT Blue R1
`Are you SERIOUS?`
UT Blue R1's Avatar
Bikes: 02' Blue R1
hey i know this is off topic, btu how do you quote people?
Old 01-20-2003, 07:46 PM   #7
Limited R1
Limited R1's Avatar
Bikes: 2001 Champion Edition R1 #815
Hit the quote button at the bottom of the post you want to quote.
http://www.r1-forum.com/gallery/data...066BANNER2.gif
Champion Limited Edition
Akrapovic Full System
Ivan's Jet Kit
Ivan's airbox mod
K&N filter
Ohlins Damper w/Harris mount
520 conversion DID gold 16/45
Intuitive Sliders
Self made Clutch Slider
Self made Radar detector mount (stem stand)
Escort 8500 detector
Garmin Zumo 550
Limited R1 is offline   Reply With Quote
Old 01-20-2003, 07:49 PM   #8
UT Blue R1
`Are you SERIOUS?`
UT Blue R1's Avatar
Bikes: 02' Blue R1
I'm not sure if this will work.
Now that i think about it 150 sound more like it..
Old 01-20-2003, 07:51 PM   #9
UT Blue R1
`Are you SERIOUS?`
UT Blue R1's Avatar
Bikes: 02' Blue R1
I still don't get it why does your say "orignally posted by ut blue r1" like do i do this the right way?
Old 01-22-2003, 01:00 AM   #10
turd1
turd1's Avatar
Bikes: 98,1/2. R1
dyno runs???????
turd1 is offline   Reply With Quote
Old 01-22-2003, 07:31 AM   #11
UT Blue R1
`Are you SERIOUS?`
UT Blue R1's Avatar
Bikes: 02' Blue R1
inserting a quote into your statement...
Old 01-22-2003, 07:36 AM   #12
bobjonez
rocket junkie
bobjonez's Avatar
Bikes: 2002 Blue R1
You should get real close to 150 with all your mods. I recently dynoed my 02...I've got the velocity stacks, PCIII, and a Devil high-mount full system: 149.3 HP, 78.5 Torque.
Never did do a baseline run though...
bobjonez is offline   Reply With Quote
Old 01-22-2003, 07:38 AM   #13
9mile
Life is Fatal
9mile's Avatar
Bikes: 02 R1, 99 VFR , 00 SV650, 96 900SS SP
Re: Stock Dyno Runs
tuned
Say Hello to Dusty for me! Great group of folks at Dynojet. I took my R1 to thier HQ last fall for a custom map for my BW pipe. Pretty cool.
You are not your motorcycle.
9mile is offline   Reply With Quote
Old 01-22-2003, 08:32 AM   #14
Scotman623
Don,t even fu**ing try it.
Scotman623's Avatar
Bikes: 06 Raven R-6 05 Harley softail Nightrain
I am very interested in seeing what HP you put out with those mods. The only different mod on my bike besides what you did to yours is I have the Micron serpent system.153.2 HP
Upstatenyriders.com
THE BLACK WIDOW
Scotman623 is offline   Reply With Quote
Old 01-22-2003, 10:30 PM   #15
turnone
turnone's Avatar
WEll i had a bad day the shop got brokemn into so i post poned my dyno runs till this morning, I did them and i pulled 135.6 which is the most HP any R1 has ever put out on the DYNOJET dyno, which is temperature controlled, and run by hte same person each time and bikes adjusted ot be fairly close in set up( chian adjustment, air pressure etc.)
Most R1 he had on there 15 of them all 02's run around 132 to 133.5... so id say i got a ggod one....
Friday we are running agin wiht velocity stacks and then monday wiht a full exhaust.... and stacks and pclll. We will see the end result, should be sweet....
Old 01-22-2003, 10:51 PM   #16
Jboat
Premium Member
Jboat's Avatar
Make sure to keep us posted bro. The anticipation is killing me...Very good so far for a stock run.
Jboat is offline   Reply With Quote
Old 01-23-2003, 06:42 AM   #17
bobjonez
rocket junkie
bobjonez's Avatar
Bikes: 2002 Blue R1
Damn...135 is pretty good for a stock 02, I think. I can't wait to see how much it pulls once you put the mods on it. It'll be interesting to see which mod gives you the most gains. On my bike, the biggest gains were going from slip-on to full system and also just doing a custom map was a huge gain. You've got all the same mods as me except we have different pipes.
Old 01-23-2003, 07:44 AM   #18
r1-superstar
r1-superstar's Avatar
Bikes: '04 R1 (All Stock)
Turnone........Thanks for the update. I am anxiously awaiting you results with the mods in step progress.
BTW My 98' R1 put out 135 RWBHP at sea level. This was done with about 3000 miles on the clock.
I have not dynoed my 02' as of yet.
r1-superstar is offline   Reply With Quote
Old 01-23-2003, 09:44 AM   #19
MR_GIXXER_MAN
mmmmm...black bike
MR_GIXXER_MAN's Avatar
Bikes: 02 FZ1 (01 G1K sold)
Um yeah and if you have 144 hp stock I am gonna ask you what you are smoking dude There is no way an R1 will make 144hp stock.
MR_GIXXER_MAN is offline   Reply With Quote
Old 01-23-2003, 12:51 PM   #20
jayinnh
69!
jayinnh's Avatar
Bikes: 02blu
how did you break her in?
jayinnh is offline   Reply With Quote
