Gearing : Yamaha R1 Forum
Drag Racing 1/8 and 1/4 mile Performance.
Old 02-24-2009, 03:32 PM   #1
JonDaddy82
JonDaddy82's Avatar
Gearing
What gearing are the high 9 second bikes running? I am at a 10.1 now on the rev limiter going through the traps in 5th with my 15/45 gearing and a 190/55 tire. The tire was worn a bit, so I know a fresh 190/55 will help a little bit. I plan on getting a new chain and sprocket set soon anyways and was going to go 16/47, but now it's got me thinking I might need to go 16/46. Thoughts?
-Raven 2007 FZ1-
| Hyperpro steering damper | Pazzo levers | Galfer HH pads | Graves frame sliders | Shogun F/R sliders | | CA taillight | Motrax LED flushmounts | Custom FE | CD Speedscreen | AIS removed | Holeshot high mount | BMC filter | PCIII | Airbox mod | Flies | Factory Pro stacks | DynoJet QS | Braking rotors | Spiegler SS lines | Driven 520 16/46 | Graves EXUP plug |
JonDaddy82 is offline   Reply With Quote
Old 02-24-2009, 08:33 PM   #2
BennyBlown2v
BennyBlown2v's Avatar
Bikes: 2002 R1 silver/black
What's stock gearing? 16/45? 16/47 is going to be almost the same as 15/45, so don't run that. Why not gear up more in the back and keep the 15t in the front - that way you'll be shifting into 6th and not worrying about the rev limiter in 5th? 6th isn't an overdrive or something is it?
If you still have usable stock gears, just go back to stock and try that...but honestly I think you're gonna wanna gear up more, not gear back down.
2002 Silver/Black R1 - My drag bike Build - 9.950@140mph (on motor) - 9.616@147.15mph on bottle
BennyBlown2v is offline   Reply With Quote
Old 02-24-2009, 08:38 PM   #3
JonDaddy82
JonDaddy82's Avatar
Stock gearing is the same as an 04-06 R1...17/45. If I geared down any more, the bike would wheelie worse than it does now, and now it's borderline impossible to put down the track. I think crossing the line tapped out in 6th is a bit much for a literbike...I would like to be able to do over 150 MPH still...
-Raven 2007 FZ1-
Old 02-24-2009, 08:52 PM   #4
BennyBlown2v
Ah, ok yeah going to 16t makes sense then! I would try the -1/+1, will keep the wheelies down to a minimum, might be a happy trade off.
Old 02-25-2009, 01:33 PM   #5
JonDaddy82
JonDaddy82's Avatar
Anyone with an 04-06 R1 care to share their gearing combos?
-Raven 2007 FZ1-
Old 02-25-2009, 03:54 PM   #6
1longR1
Ghostrider Squadron
1longR1's Avatar
Bikes: 00 r1 now 04
-2 in front, plus 3 rear.. for 1/8 mile. 120 lb rider. it wont go in 1/4 with this. on 04 u need to gear it as much as possible with clutch. it will help a ton. i picked up .3 in 1/8 just dropping one in front front what i had been running. in 1/4 i run stock rear and -2 in front.. but im lightweight. heavier u are. more gearing u will need.
R.I.P K_FleXXX June 15, 2006
R1-015 `Ghostrider` Squadron
1longR1 is offline   Reply With Quote
Old 02-25-2009, 04:32 PM   #7
JonDaddy82
JonDaddy82's Avatar
This is for 1/4 mile only, 200 pounds in gear. Keep in mind this is also the same bike I ride to work and is also stock height and wheelbase.
-Raven 2007 FZ1-
Old 02-26-2009, 10:36 AM   #8
1longR1
Ghostrider Squadron
1longR1's Avatar
Bikes: 00 r1 now 04
so really u need -1 in front, +2 or 3 in rear. thats about all u really want to go if u ride it alot.
Old 02-26-2009, 03:18 PM   #9
JonDaddy82
JonDaddy82's Avatar
Yea, I'm already 15/45 (-2) in front and I'm just hitting the revlimiter right before going through the traps...
-Raven 2007 FZ1-
Old 02-28-2010, 03:13 PM   #10
03R1FEARLESS
-1 front, +3 rear- strap your frond end...
03R1FEARLESS is offline   Reply With Quote
Old 03-19-2010, 06:43 AM   #11
OneOfEach
OneOfEach's Avatar
Bikes: 07 R1
I ran -1 +4 last year in 1/4 and wasn't hitting rev in 5th. However, I'm not a small guy. I'm actually trying out a -2 +4 setup this year. If I were you I would stay with -1 in the front and if you have a couple sprockets for the rear take them with you so you can change them while at the track. It doesn't take long to change a rear sprocket. You should invest in a strap for the front. They are cheap and a must if you're running on a track that hooks up really good.
07 R1
Stretched-McIntosh swingarm (67" wheel base)
Lowered-adjustable lowering link
Air filter removed
Two Brothers slip on
MPS air shifter
Vortex -2 font sprocket (15 tooth)
Vortex +4 rear sprocket (49 tooth)
EK Quadra Ring chain
Front lowering strap
Puig windscreen
Shogun frame sliders
OneOfEach is offline   Reply With Quote
Old 05-25-2012, 03:58 PM   #12
jang314
My R1 has "THE GLOW"
jang314's Avatar
Bikes: 2008 R1 BLACK
hey guys i just purchased a +2 rear still stock in the front what could I expect from that?
jang314 is offline   Reply With Quote
Old 05-28-2012, 06:19 AM   #13
R105
R105's Avatar
Bikes: '05 raven
wow, 2 year old thread revived. with 17/47, you've changed the gearing by less than 5%.
R105 is offline   Reply With Quote
Old 05-28-2012, 07:45 AM   #14
Got Asphalt?
Life Beyond The Fast Lane!
Got Asphalt?'s Avatar
Bikes: 2012 Moto GP 50th . 2007 YFZ450-Blue ............ 2006 YFZ450-White .......... 2005 SeaDoo RXP SC 215 .. 2006 Anniversary R1-Sold 2006 Green KLR650-Sold 1989 420cc Banshee-Sold 1987 FZ700T-Sold ............ 1985 GS550E-Sold ............
Keep in mind for every 1 tooth change in front will equal 3 teeth in the rear. So going down 1 in front will be the same as just going up 3 in the rear. My bike was new when I changed the gearing so I went -1 on the front and +1 in the rear so I didn't have to mess with my chain at all. This is equal to keeping the front the same and going up+4 in the rear! This gearing is working good for me.
2012 Moto GP 50th Anniversary R1 #0994
Yoshimura R77's, MJS MidPipe, K&N Filter, FlashTune, AirBox Mod, Smog Plate Mod, 16/48 Gearing, Graves Frame Sliders
Clear Alternatives Tailight, Mirimoto HID's, Fender Eliminator, Cox Radiator Screen, Flush LED Blinkers, Chrome Bar Ends
Garage Opener Mod, PUIG Smoke Screen, Vista Cruise Throttle Lock, Recon 19 Tank Bag, Shoei RF-1100 Seilon TC-1
If you ever wanted to know what normal is... take your bike to a local Yamaha dealer!
Got Asphalt? is offline   Reply With Quote
Old 05-31-2012, 12:46 AM   #15
juissed
nitrous ftw.
Bikes: 2004 R1
-2+3 here
+6" lowered 2", strapped, 240lb rider, spyder with .018 jets.
No issues with it coming up, and I'm JUST on the limiter at the traps. (151mph)
Turbo Hayabusa / R1 / Ducati 848 / GTO / Audi A6
juissed is offline   Reply With Quote
Old 05-31-2012, 12:47 AM   #16
juissed
nitrous ftw.
Bikes: 2004 R1
here's the chart of -2+3 on an 04-07.
Old 05-31-2012, 12:48 AM   #17
juissed
nitrous ftw.
Bikes: 2004 R1
2nd gear 50mph @ 7k is absolutely PERFECT for roll racing on the kit.
Old 05-31-2012, 12:50 AM   #18
juissed
nitrous ftw.
Bikes: 2004 R1
oh and one last post-- I put at least 1,000 miles a month on my bike with the -2+3
No issues at all.. It's perfectly streetable. There's no need for a 170mph+ top end on these bikes.
Old 05-31-2012, 01:43 AM   #19
Got Asphalt?
Originally Posted by juissed View Post
-2+3 here
What et's are you running?
Old 05-31-2012, 09:29 AM   #20
TINY 03 R1
ITS NOT OVER UNTIL I SAY It IS
TINY 03 R1's Avatar
Bikes: 2 R1s you want to race?
YOUR WELCOME
:t humbup
03 R1 SOLD
06 R1 Too Fast for you
04 Yamaha blaster 240 kit (kids)
07 YZ 250
02 YZ 125 (kids)
03 TRX 90 (kids)
07 KX 65 (kids)
TINY 03 R1 is offline   Reply With Quote
gearing... frogslinger 04-06 R1 Mechanical Help 9 05-24-2007 11:00 AM
04/05 R1 Gearing 74bones General Motorcycle Discussions 160 07-19-2005 01:46 PM
04 re gearing 1WHLR_03246 Mechanical / Help 2 07-02-2005 05:51 AM
gearing pothead Mechanical / Help 4 03-03-2004 09:59 PM
Gearing? NJWheelieMan Mechanical / Help 38 01-28-2004 09:50 AM
