2004 R1 - Is this engine sound normal? Loud clack from clutch? : Yamaha R1 Forum
SportbikeTrackGear
Old 04-11-2009, 02:05 PM   #1
TarzanBoy
Does my engine sound abnormal?
Watch the video clip. (http://video.google.com/videoplay?do...58858981884479)
I'm running a stock exhaust. My clutch seems noisy (clacking?) and there is a slight 'knock' I can sometimes feel through the handlebars that isn't evident if I pull the clutch handle in. I have heard that the 2004-2006 have noisy clutches, but I haven't seen many other R1's I can compare it to.
Also, the bike cutting itself off (as it does in the video) just started doing that today, presumably because of the stalling/TPS issue that many 2004's have... or so I hope! I just called the dealership today to have them order the parts for the recall work.
Thanks in advance
TarzanBoy is offline   Reply With Quote
Old 04-11-2009, 02:17 PM   #2
Dark_
↓ dn ʎɐʍ sıɥʇ ↓
Dark_'s Avatar
Mine sounds/feels the same way. It doesn't cut off or anything but it's surely clutch noise (it goes away when you pull in the clutch lever).
I'm not worried about it as others tend to sound the same. If anything, mine is a hair louder since I removed the clutch wire when I replaced the clutch.
-Ryan
Dark_ is offline   Reply With Quote
Old 04-15-2009, 08:45 AM   #3
TarzanBoy
just one reply?
Old 04-15-2009, 09:05 AM   #4
C Bass
AKA John Redcorn
C Bass's Avatar
Bikes: 04 Shift Red/Raven/50th Anniversary R1.
Same here. I get a bunch of chatter on my 04 as well until I sqeeze the clutch lever. What part of ATL are you in?
C Bass is offline   Reply With Quote
Old 04-15-2009, 09:08 AM   #5
C Bass
AKA John Redcorn
C Bass's Avatar
....also when I had my TPS recall done I had the dealer listen to the noise. They said the clutch needed replacing. I took it to my local bike shop and they had a R1 in the back that was doing the same thing. They didnt recommend changing the clutch until it completely went out. That was 2 years ago. I been rolling ever since with no problems.
Old 04-15-2009, 09:26 AM   #6
moe-r1ce
the R-1 and only!
moe-r1ce's Avatar
Bikes: 02 Yamaha R1
my 02 does the same thing. its clutch chatter. you ever hear a ducati? it sounds like that x 10
moe-r1ce is offline   Reply With Quote
Old 04-15-2009, 09:31 AM   #7
Kangaroo
para bellum
Kangaroo's Avatar
love the ducati dry clutch sound...
Brothers riding on...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
Kangaroo is offline   Reply With Quote
Old 04-21-2009, 08:49 AM   #8
hellion850
i yelled at a box of kittens
hellion850's Avatar
Bikes: 09 DRZ400 SM
hahah, sounds like someone shaking a bag of nickles
blah!
hellion850 is offline   Reply With Quote
Old 04-21-2009, 06:22 PM   #9
1cheapr1
98-03 r1 cheap mod/repair guru
1cheapr1's Avatar
Bikes: 2002 R1... with a few little things done to it
sounds normal
Once you go Blue you never go back...
1cheapr1 is offline   Reply With Quote
Does this sound normal? 98 R1 #48 General Motorcycle Discussions 13 02-20-2005 11:37 AM
Anyone else ever had a loud clicking sound when using the rear brake on the 04? SBFreakR1 General Motorcycle Discussions 19 12-25-2004 07:26 AM
Loud humming sound with vibration at 7k up to 8k in first and second gear!! Kenny S R1-012 `Phantom Squadron` 2 06-02-2003 12:18 PM
Loud sound when switching gears echo7 General Motorcycle Discussions 2 07-01-2002 07:40 PM
Loud sound when hittin gears echo7 Mechanical / Help 6 07-01-2002 01:53 PM
