rph problem and acceleration help. : Yamaha R1 Forum
Old 03-19-2010, 06:06 AM   #1
belo85
YZFR1 BOY
Bikes: Yzfr1 01
i have rph problems the play up it goes 7000 3000 0 .... and acceleration from stand still very poorly kinde of bilds power as you go, when over or clutched past 5500 pulls good, sort of got the idea whats wrong (exup and tps) but have no clue what they are can some one help me how to fix it read the service and repair manual but cant figure it out. thanx for the help!!!
belo85 is offline   Reply With Quote
Old 03-19-2010, 12:41 PM   #2
Sharksawyer
Is there anybody out there?
Bikes: 99 R1
RPM codes:
3000 - Throttle Position Sensor
7000 - EXUP valve
8000 - Fuel sensor
Sounds like you need to clean your EXUP valve and set it up and also adjust your TPS. What year is your bike?
Mark
99 R1
Old 03-19-2010, 06:05 PM   #3
belo85
YZFR1 BOY
Bikes: Yzfr1 01
its an 01
i cant get it to work prob best to take it top a profesional
Old 03-20-2010, 02:11 AM   #4
belo85
YZFR1 BOY
Bikes: Yzfr1 01
I got it all fixed eccaped 7000 exup valve How can I fix it tried couple things no luck cables are nice and tight as well.
Old 03-20-2010, 03:32 AM   #5
peter2468
My R1 is fastest
peter2468's Avatar
Bikes: 09 R1
The R1 has a self diagnosis system, the easy way to fix it is to find out what RPM it is stopping at and tell your Yamaha dealer they will be able to fix it easy.
peter2468 is offline   Reply With Quote
Old 03-20-2010, 06:48 AM   #6
belo85
YZFR1 BOY
Bikes: Yzfr1 01
how will i find thet out
Old 03-20-2010, 08:41 AM   #7
Sharksawyer
Bikes: 99 R1
Remove the EXUP cables and see if the valve turns freely. If not, you'll need to remove, clean and apply a little grease. The cables should not be tight. They should be a little loose or they will bind and cause the 7000 error.
Mark
99 R1
Old 03-20-2010, 04:33 PM   #8
belo85
YZFR1 BOY
Bikes: Yzfr1 01
i read that the cables need like max of 1.5mm play thats y i tightend tham
Old 03-20-2010, 08:57 PM   #9
Sharksawyer
Bikes: 99 R1
You are correct about the free play but it doesn't really tell you how hard to push on them to get 1.5 mm. I've adjusted mine to 1.5 mm and found they were too tight and had to loosen them to get the error to go away. There's also a procedure in the maint. manual that will help you set up the correct position but that's also a little vague. Basically, you need to adjust the cables so the tabs line up with the 3.5 mm hole. You then need to start the bike, turn it off and then turn the key back on to initialize the motor. Check the tab positions, rinse and repeat if they are not right.
Mark
99 R1
Old 03-22-2010, 08:43 AM   #10
belo85
YZFR1 BOY
Bikes: Yzfr1 01
i could not fix it somrthing wrong with the motor i have to pres it in so it turns.
i took the 2 cables of and opened the valve tightened it all so it stays open and left the motor so it can freeplay now the error code is gone and bike goes all right, i try fix it when the service is due thanx for the help!!!
Belo
Acceleration Problem Crazy Craven 98-99 R1 Mechanical Help 11 02-15-2007 02:00 PM
Acceleration MANOWAR Off Topic Talk 20 03-28-2006 01:52 PM
04 r1 2nd gear acceleration problem Leonbaran Mechanical / Help 2 05-09-2005 10:56 AM
acceleration gsxcorey General Motorcycle Discussions 4 03-24-2004 07:12 AM
So you want more acceleration??? scud Mechanical / Help 73 05-24-2002 07:14 AM
