Airbox question.. : Yamaha R1 Forum
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > Mechanical / Help > 04-06 R1 Mechanical Help
04-06 R1 Mechanical Help Mechinical and Critical Issues for the 04-06 R1
Graves Motorsports
Old 04-26-2010, 08:17 AM   #1
BigR1
I was going how fast officer??
BigR1's Avatar
Bikes: '06 R1
Airbox question..
I did some searching with no hits. I'm in the process of putting an '06 R1 motor in a quad and I want to remove the airbox and run just K&N's. Is there an adapter made for this somewhere or a specific K&N for it? I know of a setup like this in a quad, but I lost the guys email. As always, thanks for any help.
BigR1 is offline   Reply With Quote
Old 04-26-2010, 08:22 AM   #2
Dark_
↓ dn ʎɐʍ sıɥʇ ↓
Dark_'s Avatar
No specific kit.
-Ryan
Dark_ is offline   Reply With Quote
Old 04-26-2010, 09:22 AM   #3
BigR1
BigR1's Avatar
Bikes: '06 R1
If I fabbed some adapters do you thing it would run ok? I guess I could run it briefly with no filter/open airbox and figure that out.
Old 04-26-2010, 07:20 PM   #4
Dark_
↓ dn ʎɐʍ sıɥʇ ↓
Dark_'s Avatar
It will almost certainly need a tune to run properly.
-Ryan
Old 04-27-2010, 05:53 AM   #5
BigR1
BigR1's Avatar
Bikes: '06 R1
Where is the best place to get it retuned or mapped? Can a dealership do it(there is one 5 miles from me)?
Old 04-28-2010, 06:17 AM   #6
BigR1
BigR1's Avatar
Bikes: '06 R1
After some researching, a Power Commander will do the trick, yes?
Old 04-29-2010, 10:45 AM   #7
Kangaroo
para bellum
Kangaroo's Avatar
You lose torque doing this. Might want to have some sort of airbox.
Brothers riding on...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
Kangaroo is online now   Reply With Quote
Old 04-29-2010, 01:24 PM   #8
rorytsm
damn turkeys
rorytsm's Avatar
Bikes: 04 R1
yes with a PCIII it will work and run properly, but you'll be hurting for torque as kangaroo says.
Join Phantom Squadron
PDB and loving it! whoo hoo!
04 R1 - sunbeam yellow w/custom decals
rorytsm is offline   Reply With Quote
Old 04-29-2010, 02:16 PM   #9
BigR1
BigR1's Avatar
Bikes: '06 R1
Dang, I will have to cut out the upper frame for an air box. The throttle bodies are just 3 or 4 inches from it. I will figure out something. The motor is going into the frame today. I will see what I can come up with. Man this a sweet motor...
Old 05-02-2010, 08:25 AM   #10
BigR1
BigR1's Avatar
Bikes: '06 R1
Does anyone have any torque loss numbers using the K&N's? Substancial loss or minimal? I'm having a heck of a time trying to get the airbox in there.
Old 05-02-2010, 08:02 PM   #11
SHEPPO
Phillip Island Regular
SHEPPO's Avatar
Bikes: '04 YZF-R1 track bike
if you fit some velocity stacks, then some "sock" filters, like the UNI-Filter, it should be fine. you will loose some torque, but a 180hp motor in a quad isn't going to be lacking in the go department.
And yes, you will need a PC3 (or equiv') and it will need a custom map created for the set up as a guess.
2004 YZF-R1 Track Bike (the clunker)
Exhaust: Micron Slip-On's, Akropovic Y Pipe, Exup valve deleted w/ Graves servo eliminator.
Intake: BMC Air Filter & Factory Pro Velocity Stacks
ECU: PowercommanderIII USB w/ custom tune by Dynoverks (150hp at the wheel)
Bodywork: Doctor Race Glass, yet to be painted
Brakes: Hel Braided lines front & rear, Goldfren carbon ceramic pads, Motul 600 fluid.
Rolling on: Superbike Pro "track day" slicks.
SHEPPO is offline   Reply With Quote
Old 05-03-2010, 08:04 AM   #12
BigR1
BigR1's Avatar
Bikes: '06 R1
Ok I will keep plugging away at this... Wait a minute.. 180hp.. really? I have not looked that close at the specs, I just know I wanted a big Yami motor.
Old 05-04-2010, 12:36 AM   #13
SHEPPO
SHEPPO's Avatar
what kinda power were you expecting? a quad with an R1 motor is going to be off its head!
Old 05-04-2010, 08:17 AM   #14
BigR1
BigR1's Avatar
Bikes: '06 R1
I was thinking about 120-130hp. My brother has a drag quad with the oem block putn out 100rwhp. I just new I had to top that and that this bad boy would do it....
Old 05-05-2010, 12:16 AM   #15
SHEPPO
SHEPPO's Avatar
well a stock 04/05 R1 will make 135-140hp at the wheel on average, so you're going to smash your brother in a drag race!
Old 05-05-2010, 06:27 AM   #16
BigR1
BigR1's Avatar
Bikes: '06 R1
1998 R1 airbox question staticx General Motorcycle Discussions 12 04-11-2005 03:11 PM
Question to everyone with a Carbon Fiber Airbox Cover! Kevap General Motorcycle Discussions 15 02-28-2005 09:40 PM
stacks,airbox question freakazoid Mechanical / Help 5 10-23-2004 08:05 PM
Question: rodents making winter home in the airbox. extremeR1der General Motorcycle Discussions 11 11-04-2002 09:50 AM
Stock 02 airbox question? Jboat General Motorcycle Discussions 0 09-08-2002 02:39 PM
