» Site Navigation |
» Motorcycle Forums
04-26-2010, 03:16 PM
#1
[VET HNTR] Can Haz Teh Win?
Bikes: 2007 R1
How To Remove Chain & Sprockets
Will someone please point me in the right direction? It's the Driven Chain Kit that I'll be removing from my bike.
Thanks in advance!
Arrow Exhaust with Carbon Cans and Catless Y-Pipe, Power
Commander III, Driven Chain Kit (+2 rear/-1 front), Speedo
Tuner, Gilles VCR Gold Anodized Rearsets, Puig Dark Smoked Double
Bubble Windshield, T-Rex Frame Sliders, T-Rex Spools, Galfer
Stainless Braided Brake Lines, Blaster-X Smoked Tail Light, Driven
D3 Grips with Collars, GYTR Carbon Fiber Tank Pad, GYTR
Carbon Fiber Triple Tree Cover, KR Tuned Bar Ends, Shock Racing
Fender Eliminator, Graves Flush Mounts, Pazzo Race Levers.
04-26-2010, 03:21 PM
#2
it looks easy, whats a clutch?
Bikes: oh3 R1
angle grinder will go right through that chain.
-just working on my throttle control bitch!
04-26-2010, 04:58 PM
#3
Bikes: 2007 R1
I'm intending on using it again. Or at least making it so that someone else may use it again.
04-26-2010, 05:29 PM
#4
SuperModerateur
Bikes: 1980 Huffy Santa Fe
Stick a 2 x 4 through your rear wheel and brace the wheel against the 2 x 4 and swing arm so that it can't rotate. Remove front sprocket cover, bend locking tabs out on the retaining nut washer (or whatever the hell it is called) and use big breaker bar and socket, or impact wrench and remove front sprocket nut. Remove the rear wheel. Remove master chain link with chain breaker tool. Remove chain and front sprocket. Remove rear sprocket with appropriate wrench. Crack a beer.
04-26-2010, 05:43 PM
#5
para bellum
I did a how to, run a search for my thread. but basically what Kmac said.
Brothers riding on...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
04-26-2010, 06:06 PM
#6
Just rolling along
Bikes: 06 R1 50th
And don't forget the beer, very important.
That's my story and I'm sticking to it.
__________________________________Mike
04-26-2010, 06:11 PM
#7
SuperModerateur
and did you have the beer part in it? Huh? I don't think so.
04-28-2010, 11:58 AM
#8
Bikes: 2007 R1
LMAO Thank you guys very much!
Kmac, where can I get the chain breaker tool?
04-28-2010, 11:59 AM
#9
para bellum
 assumed amongst real men
grind off the rivets then use the chain breaker.
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
04-28-2010, 12:00 PM
#10
Bikes: oh3 R1
angle grinder...assuming it's not a clip-on. You're going to just buy another master link for $3 anyways, plus its fun
04-28-2010, 12:31 PM
#11
Bikes: 2007 R1
Doesn't sound too difficult. Can I order the chain breaker tool online? Or is it something I can most likely get locally?
04-28-2010, 12:37 PM
#12
para bellum
online is cheaper. I have an expensive RK rivet tool. But Motion Pro also makes them for around 90 bucks.
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
