where is the neutral safety switch : Yamaha R1 Forum
00-01 R1 Mechanical Help Mechanical and Critical Issues for the 00-01 R1
Old 05-06-2010, 10:19 AM   #1
whitey601
I EAT MY R1
whitey601's Avatar
Bikes: R1
my bike wont start with the bike in neutral and the kick stand down, im pritty sure it should start like that so im thinking its the neutral saftey switch. the problem is i dont know where it is or what it looks like
whitey601 is offline   Reply With Quote
Old 05-06-2010, 03:05 PM   #2
old r1
Yeah it should start.
Better wait for confirmation from somone else, but I think the neutral switch is located at the back of the engine in front of the rear shock. You should see a black cable sheath. It is pretty obvious as there is a single cable there. Check the connector under the tank first naturally.
old r1 is offline   Reply With Quote
Old 05-06-2010, 03:09 PM   #3
whitey601
I EAT MY R1
whitey601's Avatar
Bikes: R1
sweet ill look but i was also told it could be around the front sproket and not exactly sure what im looking for
Old 05-06-2010, 07:24 PM   #4
old r1
ok firstly I was right the directions I gave you are indeed for the neutral switch pls see attached sketch.
Having said that, is your neutral light coming up on your dash lights? If you put it into gear does it disappear. If so your neutral switch is fine.
The other switch you may be thinking of is the side stand kill switch where the wiring is close to the front chain sprocket.
Name:	neutral switch.jpg
Old 05-06-2010, 11:15 PM   #5
whitey601
I EAT MY R1
whitey601's Avatar
Bikes: R1
no i know where and what the side stand switch does i just wasnt sure on the neutral switch and the reason i was asking for the help on locating it is cause the light on the display does not come on when its in neutral so i knew that that was the problem. i have also looked at that picture befor but couldnt quit make out where it was. so now that we both know that thats the problem im going to check the wire and if thats messed up try to fix it but if the wires good what do you thing need a new switch?
Old 05-06-2010, 11:25 PM   #6
SySt
Bikes: 2007 R1
Test the switch if the wiring is fine. The switch either normally sends a negative signal through the wire when not in nuetral, or the other way around. So test for continuity between the engine case and the terminal on the switch.
SySt is offline   Reply With Quote
Old 05-07-2010, 08:55 AM   #7
Sharksawyer
Is there anybody out there?
Bikes: 2000 R1
Neutral switch is located on the rear of the engine under the starter motor.
Mark
99 R1
neutral safety switch 02-03 R1 TBK Bikes/Parts Wanted 0 05-24-2009 08:12 AM
02 Neutral Safety Switch LT1Pat Bikes/Parts Wanted 1 05-21-2009 09:12 AM
Neutral safety switch Nance 00-01 R1 Mechanical Help 4 04-27-2009 08:27 PM
WTB: fairing screw and neutral safety switch "02 R1 m5shooter Bikes/Parts Wanted 13 04-01-2008 07:48 PM
not want but need a neutral safety switch for an 01 r1 trixxergixxer Bikes/Parts Wanted 0 09-28-2005 03:02 PM
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
