Step 4: Once the rivets are 'popped', they simply pull out
Step 5: Next, the undertail piece comes out by sliding it toward the front of
the bike, then dropping it down
Step 6: It is suggested that the connectors on the to-be-discarded original
rear turn signals be salvaged and used to connect the Amber Dancer turn signal
wires to the bike wiring harness. To salvage the connectors, use a wire-cutter
and snip the rear turn signal wires such that the turn signal connector is left
with approximately 6 inches (15.25 cm) of wire. Do this to both rear turn
signals and the license plate light. Remove the black wires from the turn
signal connectors by snipping them off flush with the back of the connector
Step 7: To remove the tail cowl, there are two screws under the passenger seat
Step 8: Lift each rear of the operator seat and unbolt (10mm) it from the frame
