Crooked Handle Bars...How can I Fix? : Yamaha R1 Forum
Old 03-26-2002, 12:55 AM   #1
RED RYDER
On one Wheel
RED RYDER's Avatar
Bikes: R1
Hey guys after I went down a couple of weeks ago I noticed my handle bars were not straight when I was going straight. My bike went down on the left side so now when I go straight my handle bars are pointed slightly to the right. I tried putting the front wheel up against the side of a wall and straightening it like you would with a bicycle, but that didnt work. Do any of you guys know how I can fix it? Do you think a dealership will rip me off to fix it? And if its not too much does anyone know of a shop in the bay area that might be able to fix it ? Thanks alot.
RED RYDER is offline   Reply With Quote
Old 03-27-2002, 07:12 PM   #2
BallsR-Not4Sale
One time at band camp.......
Bikes: Silver '02 R1
You are on the right track. Try to loosen the bolts that hold the fork tubes in the lower or upper (NOT BOTH) triple clamps. Then try to straighten them in the same manner. It would be helpful if you had a buddy help. Have him/her stand facing the bike with legs on each side of the front wheel. That way you can sit on the bike and move the bars to adjust it. You might have to slightly loosen the front axle also. I also use blue loctite when re-install or tighten the bolts in the triple clamps. Can't be too safe! Good luck. Let me know if this works or if you need more help........Later
"Balls are not for sale. You hear that Bill Gates?.....Balls are not for sale!" -Tom Green
If there is no grass on the field, then turn her around and play in the dirt!
BallsR-Not4Sale is offline   Reply With Quote
Old 03-27-2002, 07:23 PM   #3
bugs
I put my knee down for prayer.
Bikes: 02, R1 silver
I did the same thing on my R6 and all I did was set the bike up next to a curb and turned the tire hard into it. You have to really hit it though.
ps. make sure the tire is hitting the curb and not the rim.
this worked for me
bugs is offline   Reply With Quote
Old 03-27-2002, 08:08 PM   #4
martinc
martinc's Avatar
Bikes: 99 R1/07 1098S TRE
oh boy...
hitting to repair?
not in my house please...
loosen all triples bolts on both sides,all clipons bolts,remove front axle and weel;slide front axle without the wheel back in;it has to meet the other side straight on.
retighten bolts,then figure out that you had a bent clipon.
(first remove the lower,use a jack to lift the front)
martinc is offline   Reply With Quote
Old 03-28-2002, 08:34 AM   #5
JJman
pegs & sliders scrapin'
JJman's Avatar
Bikes: YZF R1 1999
JESSE!
What is going on here!!!
If your handle bars are not straight when you are riding along, your BACK WHEEL is not in line or has been adjusted incorrectly!!!!
Check the markers are at the same pint on both sides.
This WILL be the problem you have, I just hope you get this message before you destory your front end!!!!
JJman
YZF-R1 - 1999
M3 EVO Convertible - 1996
JJman@yzf-r1.co.uk
JJman is offline   Reply With Quote
Yamaha Motorcycles Victory Gunner Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
