Do 07-08 forks Fit 04-06? : Yamaha R1 Forum
Old 12-15-2010, 02:55 PM   #1
SilverbackEC
Bikes: '05 R1 & '05 R6
I have an '05 and saw some forks on E-Bay listed as fitting 04-08.... Are they all really the same size?
SilverbackEC is offline   Reply With Quote
Old 12-15-2010, 06:02 PM   #2
Redgecko
I'm an Englishman in WI.
Redgecko's Avatar
Bikes: 06 R1
Forks would fit but you'd need Calipers and rotors (or rotor spacers) too
Redgecko is offline   Reply With Quote
Old 12-15-2010, 08:49 PM   #3
SilverbackEC
Can I use all my stock stuff?
Old 12-16-2010, 01:22 AM   #4
Blu916
R1-014 Dragon Squadron #200
Blu916's Avatar
Bikes: DPBM: '00 R6 RIP, '06 R1 Sold, '04 R1
Doubtful, as Gecko said, you'd need new calipers and Rotors or Rotor Spacers. I think the 07-08 Changed the rotor carrier and rotor size to accommodate the larger Caliper, so i don't even think spacers will work.
Sig, Thanks to Petrol_Spice
Blue 2000 R6 - Highsided RIP
Blue 2006 R1 - Sold
Blue 2004 R1 - Current
RIP Skyler Page you will never be forgotten! 01/06/87 - 08/01/2008
RIP Pierre - DieYoung69
Blu916 is offline   Reply With Quote
Old 12-16-2010, 02:41 AM   #5
Redgecko
Redgecko's Avatar
Bikes: 06 R1
If you get the 07 forks you will need 07 calipers too. 05 has 108mm mounting but the 07 has 130mm.
The rotors on an 05 are 320mm and the 07 are 310mm, so you can either put 310mm rotors on ( bolt pattern is the same ) or keep the 05 rotors and fit 5mm spacers to the 07 calipers.
Old 12-16-2010, 04:42 AM   #6
ebags
mmmm gold bits
ebags's Avatar
Bikes: 5VY
You'll need an 07 mud guard/fender too
See I'm good for the important information
"Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere."
Colin Chapman
Uncle P. Originals
Originally Posted by burn-z View Post
I'm pretty certain you don't have anything from Magnetti Marelli.
Originally Posted by WayTooFastWhyty View Post
I have a magnetti marelli battery thank you
ebags is online now   Reply With Quote
Old 12-16-2010, 06:21 AM   #7
SilverbackEC
The rotors on an 05 are 320mm and the 07 are 320mm, so you can either put 310mm rotors on ( bolt pattern is the same ) or keep the 05 rotors and fit 5mm spacers to the 07 calipers.
Oh I see now,, lightbulb finally kicked on....Thanks for the feedback guys...
Old 12-16-2010, 06:23 AM   #8
SilverbackEC
Smile
lol,,, Good one Ebags ....
Old 01-10-2011, 03:14 AM   #9
polygaryd
can you use 07 fork tubes with your 04 to 06 fork internals. I want to change the tube color from black to gold but don't wanna pay for ohins since I'm good with my stock forks. know a guy selling 07 gold stock forks for a good price but not sure if i can do the swap. i dont want to change my whole front end basically and pay out a bunch of money just o use 07 forks cuz they are gold.
polygaryd is offline   Reply With Quote
Old 01-10-2011, 03:45 AM   #10
Redgecko
Redgecko's Avatar
Bikes: 06 R1
Your other alternative is to get the forks and then get hold of some caliper adapters to use your 04 stock parts.
Old 01-10-2011, 06:50 AM   #11
617mike9c1
Life is too short
617mike9c1's Avatar
Bikes: '08 R1 Blue + '03 R1 Silver + 02 ZRX12 Red
Actually, that is incorrect... the front fenders from 02-08 are all the same of course with the exception of color. If you don't believe me, check the part number.
617mike9c1 is offline   Reply With Quote
Old 01-10-2011, 06:57 AM   #12
B'eater
I wreck my R1
B'eater's Avatar
Bikes: Rupp Scrambler
Your other alternative is to get the forks and them get hold of some caliper adapters to use your 04 stock parts.
Or contact me for a set of '07 calipers and rotors with only a few thousand miles on them.
B'eater is offline   Reply With Quote
Old 01-10-2011, 04:29 PM   #13
Redgecko
Redgecko's Avatar
Bikes: 06 R1
Post #5
Old 01-10-2011, 04:36 PM   #14
bestman77
Back From the Dead
bestman77's Avatar
Bikes: 03 R1 Limited, 05 R1 Blue
while we're talking about fitment, would the 06 R1 front wheel fit an 06 R6r?
bestman77 is offline   Reply With Quote
Old 02-18-2011, 04:19 PM   #15
juicejuice78
Twist of the Wrist
Bikes: 1992 CBR F2, 2004 R1 Silver, 2005 R1 Raven
Will a 07-08 r1 front end complete fit an 05 r1?
juicejuice78 is offline   Reply With Quote
Old 04-05-2011, 07:43 AM   #16
BLiTzd
R1 for life
BLiTzd's Avatar
Bikes: 2006 Yamaha R1
do 08 r6 forks fit 06 r1?
I have a friend that has a set of 08 r6 forks and my 06 r1 seals are leaking so he said I can buy the forks from him but I wana make sure that these will fit first. does anybody no if the 08 r6 forks will fit on my 06 r1?
BLiTzd is offline   Reply With Quote
08 R1 Gold Forks for Black Forks!! SLC area Big_Red Trade section 2 01-13-2010 11:38 AM
My 09 Gold R1 Forks ~4~ 09 Black Forks! WWPearlMS6 Trade section 3 08-26-2009 09:26 AM
WTT: Penske Rear Shock/Lindeman Fr. Forks TRADE FOR Body Work and stock forks mphamzx7r Trade section 2 11-22-2003 09:05 PM
ohlins forks compared to revalving/coating stock forks champs387 Mechanical / Help 8 10-31-2002 08:03 PM
