Need Help, I Have A Double Click Sound? : Yamaha R1 Forum
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > Mechanical / Help > 04-06 R1 Mechanical Help
04-06 R1 Mechanical Help Mechinical and Critical Issues for the 04-06 R1
Old 01-16-2011, 02:29 PM   #1
SoonerR1
SoonerR1's Avatar
Bikes: 2005 R1
hey guys I just bought my 2005 R1 not to long ago. and today it just started haveing a weird "double clicking sound when i let off the clutch and rolling in first gear 2-5mph. It's just a real quick "click".."click" then it goes away and everythings fine runs great very strong and powerful,shifts perfect etc etc... It is not a clunk,or clang or a grind. And Im not sure if its comming from the front end or what its just kinda weird it only happens when releasing the clutch comming into 1st gear but it does not happen in any other gear. The bike now has 7,898 miles on it. anyone had anything like this?
2002 gsxr 600---SOLD,thank god
2005 R1
Full Graves TI exhaust
GPR steering damper
and a few other good's
SoonerR1 is offline   Reply With Quote
Old 01-16-2011, 07:14 PM   #2
SoonerR1
SoonerR1's Avatar
Bikes: 2005 R1
well pin-pointed the sound its the rear shock making noise's.. the bike is lowerd and swingarm is extended 6inches. guess the only thing to do is replace the rear shock right????????
2005 R1
GPR steering damper
Old 01-18-2011, 10:18 AM   #3
Stevie04R1
1 beer short of a six pack
Stevie04R1's Avatar
Bikes: 2004 R1 Lava red
If it's the actual shock that's clicking, yes.
Have you checked the upper and lower mounting points to make sure that they are torqued correctly.
Modded Termi slipons, Micron decat pipe, A&R smog plates, Krankvent, K&N airfilter, PC111 and custom map, Gipro gear indicator, Speedo healer V4, Hel brake lines, Tygon resevoir tubing, Titax stubbys, 35w 6000K HID's, PIAA Highs, Led running lights, Blaster x tail light, Afam 520, -1 +1 renthal sprockets. PP Tuning rearsets,K-tech front + rear springs, Carbon Hugger, exhaust shields, tank sides, front mudguard, sprocket cover, Puig light smoke screen. Watsen design indys.
Stevie04R1 is offline   Reply With Quote
Old 01-18-2011, 10:31 AM   #4
SoonerR1
SoonerR1's Avatar
Bikes: 2005 R1
yea i have. I have also put some wd40 on the shock and the bolts around it. Ive also put a zip tie on the brake line (not to tight) around where that metal clip/clamp that holds it in place, so far i havent heard it since i have done all that, i am looking at o'hlins shock's,maybe that will give it a bit of a stiffer ride. and also help from bottoming out with a passenger. since the r1 is lowred and extended the pass rear sets hit my Carbon fiber tire hugger,lol but with me on there it just makes noise and creeks,lol but it seems i have stoped the noise for right now. Thank's for the reply
2005 R1
GPR steering damper
Old 01-18-2011, 11:16 AM   #5
Stevie04R1
Stevie04R1's Avatar
Fingers crossed then
Aftermarket shock is a great upgrade.
Make sure you get the right spring for your weight.
Old 01-18-2011, 12:20 PM   #6
SoonerR1
SoonerR1's Avatar
Bikes: 2005 R1
+1 on that buddy.
2005 R1
GPR steering damper
Click Sound from Rear ? SpeedzR1 04-06 R1 Mechanical Help 0 06-06-2009 09:00 PM
original r1 sound vs. akrapovic sound? Racer1_at General Motorcycle Discussions 9 06-06-2004 12:44 PM
Click click click click click noise oblivion Mechanical / Help 34 05-06-2003 06:15 AM
new blue ermax double bubble for a smoke or clear double bubble drspeedmore Trade section 0 10-11-2002 09:27 PM
Curious CLICK-CLICK when... KevlaR1 Mechanical / Help 4 06-19-2002 08:12 AM
