» Site Navigation |
» Motorcycle Forums
02-06-2011, 02:44 AM
#1
Best battery for 2009 R1
I bought my 2009 R1 and put a scorpion alarm on it, And everything was fine untill the cold weather came and the battery started having trouble starting. I tried to buy a bikemasters truegel battery but the leads were on the wrong side so I sent it back and they kept insisting it was the correct battery. I'm guessing they sent me a 2008 battery and they thought it was the same. It's to bad cause I really wanted to give it a try. So the question is what is the best battery for cold crank amps and reliability? I know the alarm can draw power from the battery but when I drive the bike on a fully charged battery for 20 min and leave the bike sitting for 10 hours in the cold its a fifty fifty shot whether the bike will start, during the warm weather it does not seem to be an issue.
02-06-2011, 05:59 AM
#2
My R1 knows me way to well!
Bikes: 2009 Yamaha R1
I have the same problem up here in NH. Luckally I parked real close to my apartment and ran an AC cord to the bike and plugged in my battery tender.
I now have a garage but it's still cold but at least I'm not faced with someone borrowing my power or the maintenance guys take the AC cord.
Just a thought...
Alan
 An 09 R1 with customer pegs, Custom LED tail light & flasher, a ZG-Double Bubble and Driven G3's.
Living in Barrington, NH.
02-06-2011, 08:10 AM
#3
Save me from a highside..!!!
Bikes: 2007 R1 - charcoal
Go to Shoraipower dot com and get a lithium unit - 80% lighter than stock, same dimensions, holds more power better, and stores all winter with zero maintenance. Also, they can last up to 8 years or so.... It's the ultimate battery mod, in my opinion.... ( just need to save some dough and get one in my 07... should lower the CG nicely for quick transitions...!!
02-07-2011, 01:34 AM
#4
I took a look at the website and the battery looks very cool with lots of CCA's. the only problem is it is the same style battery that I got. it seems the battery for the R1 has not changed untill 2009 and I assume that the manufatorors thought it is the same but it is not. On the 2009 if I am sitting on my bike the positive lead is on my right hand side. I looked at some pictures of the 2008 and the positive lead is in the same position as the 2009 but the battery is laid on its side. Has anyone had this issue or is it just me?
02-07-2011, 04:43 AM
#5
Don't fence me in...
Bikes: 2009 R1
I just bought a Shorai for my 09 R1. I have not put it in yet, but it is way smaller and lighter. They provide foam pads to add size to the battery (I assume to make it fit better in the stock location).
A little pricey, but way lighter and should last for many years. I have noticed that my stock battery seems to be showing some signs of slow cranking, so I figured I would replace it before it dies. My stock unit is about 18 months old.
Ben
02-07-2011, 11:19 AM
#6
yield
Bikes: 2002 R1 #335 red/white livery
Ive been looking at the Shorai.. the Li batteries look tough and is the best bang for buck weight loss out there.
02-07-2011, 11:23 AM
#7
Bikes: Rupp Scrambler
Absolutely.
Costs just a few dollars more that the stock Yuasa and shaves another 6ish lbs off of the top of the bike! No brainer.
02-07-2011, 11:28 AM
#8
yield
No doubt!!
02-07-2011, 01:16 PM
#9
Bikes: 2009 Yellow R1
Hi Huckleberry:
let us know how the battery fits on your bike.
02-07-2011, 01:31 PM
#10
My Duc eats my wallet
Bikes: R1
so can you use Battery Tender to keep this Li-Ion Shorai battery on charge??
07 R1, 04 ///M3
06 R6 Raven(sold), 06 Sport1000(sold), 05 R1(sold), 00 996 (sold), 03 R6 (sold), 01 748 (sold), 01 F4i (sold), 00 ZX6R (sold)
02-11-2011, 08:31 AM
#11
The OEM battery is $87.99 from Yamaha.
My Ballistic Performance Components 8 Cell EVO 2 Battery is $159.99, weighs 1.4 pounds (7 lbs less than stock), has 240 Cranking Amps vs less than 180 for the stock battery, and comes with a three year warranty....and it fits in the palm of your hand!
Give it a look: www.ballisticparts.com
If you ride in cold weather often like the OP then I would recommend the 12 Cell for the R1. It has 360 Cranking amps and is only $30 more at $189.99
02-11-2011, 09:44 AM
#12
well, if you want to go lithium I suggest shorai battery,
at least you mantain the stock format and it's not A123 cell based giving you 14A/h!!!
02-11-2011, 11:12 AM
#13
Bikes: Yamaha R1 2010 Raven
I had the Scorpio i900 for the CBR, I didn't have a battery problem till I left it unused for a month. Batteries should last 5 to 6 years. Lithium can't be on a battery tender. Check the website for details
"Q. Can I use Lead-Acid battery chargers or charger/tenders?
A.Yes. HOWEVER, you may NOT use a charger/tender if it has an automatic "desulfation mode", which cannot be turned off. We have confirmed with Deltran, makers of the "Battery Tender" brand, that their products do NOT have a desulfation mode, and are therefore OK for use with Shorai LFX, for example. But the best possible charger/tender for Shorai LFX is the SHO-BMS01, which will be released on about March 15th 2011, we expect. It uses the 5-pin BMS port in the LFX batteries, in order to monitor, diagnose, and balance the individual cells during charge. And it also has an optimized storage mode that will give the longest possible service life to your LFX.
http://www.shoraipower.com/t-faq.aspx
08-03-2011, 09:36 PM
#14
Bikes: 2009 R1
is that a 4 cell battery ?
PHANTOM#420
08-03-2011, 10:22 PM
#15
MummyMan
Bikes: 1999 r1, 07 GSXR 1k
We have had sooo many people giving us great feedback with the Shorai batteries. We have every model in stock at this time as well.
We have yet to see even one go bad. I was so impressed with them I put one in my bikes a few weeks back.
08-03-2011, 10:26 PM
#16
yield
I look forward to ordering one soon from you Corey...
I am about to alarm my bike, any talk on the way to go. I will be getting one of their chargers too. Any comments or am I better off running my Yuasa lead battery?
08-04-2011, 12:35 PM
#17
Take the red pill
Bikes: '09 R1
Scorpio alarm and Shorai battery.
08-04-2011, 12:39 PM
#18
MummyMan
I run the scoprio rlink with the shorai battery
It's
08-04-2011, 12:50 PM
#19
big tracks scare me
Bikes: R6 track slut
SpeedCell
Or so I've heard.
08-04-2011, 02:13 PM
#20
yield
It's
rlink?
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
