Thermo Switch Problem... : Yamaha R1 Forum
Old 02-10-2011, 08:40 PM   #1
YZF Steve
Hi, I have an 01 R1 I just picked up. It was a totaled bike, so I have spent that last couple months rebuilding. I know my thermo switch is bad, so I hooked up the rad fans to a toggle switch just so I can run and ride the bike for testing purposes... But its not RIGHT. I wanna replace the switch so I have a temp reading on my gauge, but I haven't seen any on ebay since December, and the oem ones will run me between $45 and $60 before shipping... Is there any other thermo switch that I could get that would work? Or some other work around so I have a fully functioning cooling system? I'm not worried about plugging it in because the plug on the wire harness is gone, I'm going to have to get creative with hooking it up. I just need something I can screw into the radiator that will function the same way as the oem one.
YZF Steve is offline   Reply With Quote
Old 02-10-2011, 09:39 PM   #2
Sharksawyer
Is there anybody out there?
Bikes: 99 R1
Are you sure your's is bad? There's a test procedure in the maint. manual.
Mark
99 R1
Old 02-10-2011, 09:42 PM   #3
YZF Steve
Mark
99 R1
I'm 80% sure. Whats the testing procedure?
Old 02-10-2011, 09:48 PM   #4
Kangaroo
para bellum
Kangaroo's Avatar
it's either good or bad...
Brothers riding on...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
Kangaroo is offline   Reply With Quote
Old 02-10-2011, 10:04 PM   #5
YZF Steve
Haha I'm aware its good or bad. I meant I think it's bad. The wiring harness was so jacked up when I got the bike, the previous owner did a HORRIBLE hack job repair, and I found the sensor disconnected, found the two wires that were SUPPOSED to go to the sensor stripped and wrapped together and taped, and when I tried to reconnect it I got nothing. So I assumed it was the sensor.
Old 02-10-2011, 11:11 PM   #6
Sharksawyer
Bikes: 99 R1
The two wires for the thermo unit should be Green/Red and Black/Blue. The test procedure involves putting the sensor in a pan of coolant, heat it up and check the resistance as it cools. Should get about about 1 K ohm at 250F and 10K ohms at 120 F. Not the exact numbers but you get the idea. If it were me, I'd measure at room temp and then start heating it up and see if it's anywhere close. From what it sounds like, you either have the wrong wires or your unit is completely shot.
Mark
99 R1
Old 02-11-2011, 12:15 AM   #7
YZF Steve
Did that, sensors definitely shot. Back to the original question, is there a cheap(er) way to replace this than by spending potentially $60? I had the right wires btw. I have a wire diagram for the bike, thats what led me to think sensor in the first place.
Old 02-11-2011, 06:56 AM   #8
sss r1
NeeD 4 SpeeD
sss r1's Avatar
Bikes: 99 blue
try at auto parts store
http://i256.photobucket.com/albums/hh199/lostcomrad/sigpic33288_1.jpg
sss r1 is offline   Reply With Quote
Old 02-11-2011, 07:46 AM   #9
Sharksawyer
Bikes: 99 R1
Can't help you with the thermo unit problem but you should be able to replace it with a thermo switch and at least have your fan come on at the proper time. The only down side is you won't be able to see the temp. I replace mine with a Wells SW518 that turns the fan on at about 190 degrees F.
Mark
99 R1
Old 02-12-2011, 02:44 PM   #10
YZF Steve
Mark
99 R1
I hardwired the fan, So I know it wont overheat, and its not a huge inconvenience to me, but I mainly want to know the temperature, just to make sure everythings running ok. Where did you get your switch?
Old 02-12-2011, 03:00 PM   #11
Sharksawyer
Bikes: 99 R1
Picked it up at Autozone. Not sure about the thread size though and it might not fit your '01.
I'd just keep on keeping on and wait until you find one on eBay or in a junk yard. I'm sure you know this but you shouldn't have to even turn the fan on unless you are stuck in traffic. Normal riding will be ok.
Mark
Old 02-12-2011, 05:13 PM   #12
YZF Steve
Mark
I'm aware, thank you haha. As of right now, the only running its doing is in the garage while I still work out electrical grimmlins. I took it out last weekend and hit the road at 55 because of a shitty ebay brake lever... I'm not ready to ride it yet haha
Old 02-12-2011, 06:54 PM   #13
Sharksawyer
Bikes: 99 R1
Yea, you got to steer clear of those knock off levers. Nothing but OEM.
Mark
Old 02-12-2011, 07:01 PM   #14
YZF Steve
Mark
I've had good luck with them in the past, and a grinder has solved my wierd lever... but losing the skin on the left side of my body, shredding a jacket and ruining a helmet is a horrible way to learn a lesson
Problem: Neutral Saftey Switch???? five409 04-06 R1 Mechanical Help 2 01-15-2011 09:49 PM
Problem with my clutch lever switch BigR1 04-06 R1 Mechanical Help 11 10-02-2010 01:34 PM
Nuetral switch problem cbibb 00-01 R1 Mechanical Help 3 02-12-2008 12:04 PM
neutral light/switch problem zze133L 98-99 R1 Mechanical Help 6 12-15-2007 11:02 AM
Handlebar switch problem cbibb 00-01 R1 Mechanical Help 0 09-15-2007 01:09 AM
