Installation 2004 R1 : Yamaha R1 Forum
Old 02-28-2011, 02:43 PM   #1
XFelon
Gilmour
XFelon's Avatar
Bikes: 2004 R1
I have a adjustable linkage system on my 2004 r1. I am looking to get the stock linkage system. I see them on CL and eBay, I am wondering if I could buy one and do it myself...
I have a rear stand, someone told me that I would have to have the bike up on the frame sliders because once I loosen up the bolts, the tail of the bike would snap up.. Just wondering if this is true and maybe some comments on your experience.. Thanks in advance..
XFelon is offline   Reply With Quote
Old 02-28-2011, 02:49 PM   #2
Stevie04R1
1 beer short of a six pack
Stevie04R1's Avatar
Bikes: 2004 R1 Lava red
You have been told correctly that you will need to unload the rear suspension.
By this I mean you have to take all the weight from the swingarm. The easiest way to do this is to put your bike on the rear stand, then put two axle stands, one under each footrest.
Then when you remove the rear stand, the there will be no weight on the rear suspension and you will be able to remove the parts you mentioned.
Modded Termi slipons, Micron decat pipe, A&R smog plates, Krankvent, K&N airfilter, PC111 and custom map, Gipro gear indicator, Speedo healer V4, Hel brake lines, Tygon resevoir tubing, Titax stubbys, 35w 6000K HID's, PIAA Highs, Led running lights, Blaster x tail light, Afam 520, -1 +1 renthal sprockets. PP Tuning rearsets,K-tech front + rear springs, Carbon Hugger, exhaust shields, tank sides, front mudguard, sprocket cover, Puig light smoke screen. Watsen design indys.
Stevie04R1 is offline   Reply With Quote
Old 02-28-2011, 03:07 PM   #3
XFelon
Gilmour
XFelon's Avatar
Bikes: 2004 R1
Gotcha, is there certain "footpeg stands" that are needed or could I use 2 car stands and put those underneith the footpegs?
Old 02-28-2011, 03:15 PM   #4
Sabian
Booya
Sabian's Avatar
Bikes: 1943 Indian Scout 741
Note - foot pegs that don't fold! Otherwise you have to find the hard point of the stock rearsets...you'll be in for a nice surprise if you don't.
Rear suspension holds the tail up - disconnect the suspension...what did you think would happen?
Lastly, you originally mentioned putting the bike up on the frame sliders...bad idea, you need to support the area behind the motor.
"Universe is 14 billion years old. Seems silly to celebrate one year. Be like having a fvcking parade every time I take a piss." -- ShitMyDadSays
Yeah it was head trauma alright....but it was my little head that was traumatized by your mouth.
Sabian is offline   Reply With Quote
Old 02-28-2011, 03:21 PM   #5
XFelon
Gilmour
XFelon's Avatar
Bikes: 2004 R1
Thanks!. So my foot pegs do fold up, what would be the best place to put them, anyplace you would recommend? I am guessing at the seat or further back?
In case you could not tell, this is my first time doing anything like this so I want to make sure I am doing it correctly..
Old 02-28-2011, 03:26 PM   #6
xtremewlr
I ride naked
xtremewlr's Avatar
Bikes: Street: '04 FZ1 Track: '05 ZX6R
A trick with the folding foot pegs is to take them off and flip them upside down so they don't fold up. Allows you to use stands on the pegs that way.
xtremewlr is offline   Reply With Quote
Old 02-28-2011, 03:27 PM   #7
XFelon
Gilmour
XFelon's Avatar
Bikes: 2004 R1
Nice! Good freakin idea...
Just dont forget to flip them back around..
Old 02-28-2011, 03:30 PM   #8
xtremewlr
I ride naked
xtremewlr's Avatar
Old 02-28-2011, 06:11 PM   #9
Jonrone
Decisions
Bikes: S1000RR
I have an 04 R1 and have put on and removed the rear linkage a couple times.
With the bike on a rear stand directly under the opening for my attic. I used rachet tie downs to attached the the rear subframe (remove rear cowl plastics). Then I attach the tie downs to a bar across the attic opening. Have the tie downs attached and un-weight the rear suspension prior to pulling the linkage. Make sure to put a board or something under the tire before you disconnect the linkage. I will make it easier to adjust later to put linkage back in.
Jonrone is offline   Reply With Quote
Old 02-28-2011, 10:08 PM   #10
SAB
An Deireadh
SAB's Avatar
Gotcha, is there certain "footpeg stands" that are needed or could I use 2 car stands and put those underneath the footpegs?
There are special stands that support foot pegs and frame sliders. They are sold by companies like Pitbull, Harris, and Powerstands to name a few. I have a set of the Powerstands jack stands. Really heavy duty and solid.
In addition to the locations mentioned, you can also use traditional jack stands (with flat tops) and some wood under each "spar" of the main frame. It's perfectly flat and will support the bike for unloaded rear end work. I swapped a swing arm this way before I had the Powerstands.
Name:	DSC06869 (Medium).JPG
ID:	430054   Click image for larger version
Name:	DSC06870 (Medium).JPG
"If I'd never thrown my leg over a bike, I'd never have lived." - Hislop
SAB is online now   Reply With Quote
Old 03-04-2011, 09:35 AM   #11
XFelon
Gilmour
XFelon's Avatar
Bikes: 2004 R1
Good info.. Thanks!!! Well see how it goes when I get the dogbone in the mail..
Old 03-04-2011, 02:03 PM   #12
You guys are all doing it the hard way....
You'll need a jack for this method, scissor, bottle or trolley, if you don't have one, someone you know will...
Leave the bike on it's sidestand.
Remove the lower fairing.
Place the jack under the rearmost level section of the exhaust, or under the flat section of frame that runs under the back of the sump.
When you jack the bike you should be shifting the weight onto the side stand and wheels, tripod style.
Remove the nuts from the bolts that go through either end of the linkage. Don't try and remove the bolts...
Jack the bike just slightly enough to take the weight off the bolts.
Now you can remove the bolts and the linkages.
The bike is very vulnerable now, if you let the jack down the bike will fall.
Slight raising or lowering of the jack will allow you to fit the original linkage in.
Put the linkages and bolt in one end, and adjust the jack until you can slide the bolt in the other end.
Remove the jack and put the nuts on the bolts.
Done.
PC3 Installation Help aviatorisu Mechanical / Help 0 08-26-2008 06:40 PM
HID kit installation ???? bennsdb General Motorcycle Discussions 5 05-03-2008 03:23 PM
Hid Installation TURBOJDMR1 Appearance & Mods 15 10-04-2006 05:13 AM
installation meila Mechanical / Help 1 09-29-2005 12:03 PM
jet kit installation Rspeedemon1 Mechanical / Help 9 12-11-2002 07:40 AM
