garage door opener : Yamaha R1 Forum
SportbikeTrackGear
Old 04-20-2011, 05:13 PM   #1
sircharles1
Street Runnerz M/C Natl. Prez
sircharles1's Avatar
Bikes: '03 R1, '07 GSXR750, '08 GSXR1000... all stretched and sitting in the dirt
garage door opener
hey i dunno if this the right section but here you go...
a while back i read on someone's post (that i cant find anymore, unless i would be PMing them)... that they had their garage door hooked into their high beam and when ever they would flick it, it would trigger their garage door opener... does anyone know how to do this? or know who it was that posted that... cause I wanna be cool like them
How do you know the tooth brush was invented in Kentucky? If it were developed anywhere else it would be called a teeth brush.
What do you call a female virgin in Kentucky? Faster than her brothers.
Kentucky: 5 million people, 10 last names.
Why couldn't the baby Jesus be born in Kentucky? Because they couldn't find 3 wise men or a virgin.
Why are there so many unsolved murders in Kentucky? There are no dental records and everyone has the same DNA
sircharles1 is offline   Reply With Quote
Old 04-20-2011, 05:17 PM   #2
sircharles1
ok nevermind... i just found the how to for it
Old 04-20-2011, 05:20 PM   #3
Redgecko
buckfarack fan club
Redgecko's Avatar
Bikes: 06 R1
I have done it, it's really nice to be able to roll straight into the garage
Redgecko is offline   Reply With Quote
Old 04-20-2011, 05:38 PM   #4
clarkLER1
#052 of 500
clarkLER1's Avatar
Bikes: 2006 R1 LE
Want to share??
clarkLER1 is offline   Reply With Quote
Old 04-20-2011, 05:43 PM   #5
SySt
Bikes: 2007 R1
I did this too, except I use my horn button to activate it. Just take your remote apart, find out what terminals the switch closes when it is pressed and close that circuit with a piece of wire. Then you need to determine the voltage the remote runs on and wire up a regulator to drop down from 12v to whatever the remote runs on. Then just wire up the positive and negative wires going to the regulator into your bike however you want.
SySt is offline   Reply With Quote
Old 04-20-2011, 05:46 PM   #6
Redgecko
buckfarack fan club
Redgecko's Avatar
Bikes: 06 R1
Originally Posted by clarkLER1 View Post
Want to share??
Well it depends on what type of door opener you have.
I was lucky and mine ran on a little 12v battery. So all I did was open the back and solder a small wire across the switch to short it permanently on. Then I removed the battery and soldered wires to the pos/neg terminals and spliced them into the high beam pos/neg wires.
So when I switch on the high beams it supplies power to the opener and since the switch is always on it activates the opener. Hid the unit in the nose and job done.
If yours is not run with a 12v battery you'll need resistors or something and I think that's the way it's done in the "How To"
Old 04-20-2011, 05:48 PM   #7
sircharles1
http://www.r1-forum.com/forums/showthread.php?t=217769
Old 04-20-2011, 05:50 PM   #8
SySt
Bikes: 2007 R1
If yours is not run with a 12v battery you'll need resistors and I think that's the way it's done in the "How To"
You need more than just resistors to lower to voltage on these garage door remote. Resistors would work if the load (garage door remote) was constant, but it is not. You need to make a regulator. The how to gives a diagram for building a regulator circuit with two resistors and am LM317 regulator.
Old 04-20-2011, 05:55 PM   #9
Redgecko
buckfarack fan club
Redgecko's Avatar
Bikes: 06 R1
Ah OK, well I didn't need anything so I don't care
Old 04-20-2011, 06:06 PM   #10
timoram
@ OPP Racing
timoram's Avatar
Bikes: 2006 R1
I have the garage door opener operated by my horn and high beem.
Here is how it works.
1) Approach the house and press the horn and high beam buttons.
2) Wife gets of couch and opens garage door.
sometimes..
3) Greeted with a cold beer and a sandwich.
Best part about my system.....electrical work needed.
Tim
Sig by Pertol_Spice
timoram is offline   Reply With Quote
Old 04-20-2011, 06:09 PM   #11
Death R1
99 R1
Death R1's Avatar
Bikes: 99 R1
I have this and it works great -no work -- 10 minute install and they discount if you are a member of the AMA
Flash to Pass
Tuned by Bugaj
"In pursuit of more speed with the same power"
my "back from the dead" thread:
http://www.r1-forum.com/forums/showthread.php?t=263176
99 R1 parts for sale :
http://www.r1-forum.com/forums/showthread.php?t=307491
Death R1 is offline   Reply With Quote
Old 04-20-2011, 06:10 PM   #12
Redgecko
buckfarack fan club
Redgecko's Avatar
Bikes: 06 R1
sometimes..
Tim
I've seen the video
Old 04-20-2011, 06:12 PM   #13
Redgecko
buckfarack fan club
Redgecko's Avatar
Bikes: 06 R1
Flash to Pass
Seen those, good option but mine saved me $71.90 (I think I used 9 cents worth of wire and solder )
Old 04-20-2011, 06:14 PM   #14
timoram
@ OPP Racing
timoram's Avatar
Bikes: 2006 R1
I've seen the video
No no, thats the video AFTER the garage door closes
Sig by Pertol_Spice
Old 04-20-2011, 06:17 PM   #15
Slimer08
Slimer08's Avatar
Bikes: 08 Black R1
I have velcro on my tree for my lap timer, during the times im not on the track, the velcro holds my garage door opener which is pretty small. Works for me.
Slimer08 is offline   Reply With Quote
Old 04-20-2011, 10:13 PM   #16
fire343
Eat right,stay fit,die anyway
fire343's Avatar
Guess I shoulda searched before I did mine! That would have helped alot haha.
But I did much the same as the guy at the bottom of the first page on that thread. I just soldered some wires from the opener board to a button and put it under the plastics next to my left thigh. This way works pretty well, yes you have to take your left hand off briefly but I found my opener works from quite a distance away. I just stashed the board and little battery in a ziploc sort of under the rear seat. Has worked well for a year, and many many washes.
2009 Raven R1- Competition Werks fender eliminator, Hotbodies flust mount front turn signals, custom led body kit, 1offmotorsports HID, white LED running lights, Puig Z-racing dark smoke DB, Snakeskins tank grips, motovation fram sliders, motovation bar ends, rear seat cowl, removed passenger pegs, more on the way.......
"Always beware of any man who keeps a pig farm."
May we never forget, the 343. All gave some, some gave all
fire343 is offline   Reply With Quote
Old 04-21-2011, 04:35 AM   #17
Doppler
Doppler's Avatar
Bikes: 07 R1
I kept the remote running off its own battery and added a switch near the back of my right headlight. The remote itself is mounted behind my instrument cluster out of sight under the screen. This way I can use it before I turn the ignition on.
Doppler is offline   Reply With Quote
Old 11-26-2012, 03:42 AM   #18
SakiBomb
Herro!
SakiBomb's Avatar
Bikes: 05 R1
Originally Posted by damsry31 View Post
Powerful, quiet and durable, Overhead Door’s automatic garage door openers are designed for performance. And when you combine an Overhead Door opener with one of our doors, you get an integrated system that maximizes performance and reliability. Our full line of automatic openers features a variety of power levels and specifications to handle different garage door weights and sizes. Each opener also comes with built-in, standard functions for the ultimate in safety, convenience and power. Overhead Door offers a wide variety of additional garage door opener accessories.
Run onto the I-5 during peak transit hours please.
SakiBomb is offline   Reply With Quote
Old 11-30-2012, 10:02 PM   #19
glickman31
Bikes: moutain bike
garage door opener
The garage door opener support guide takes the guess work and uncertainty out of finding the right replacement remote.
potomac garage door repair
glickman31 is offline   Reply With Quote
Old 12-05-2012, 10:38 PM   #20
johnsonnina31
garage door opener
A garage door opener is a motorized device that opens and closes garage doors.
Door opener systems are required to have at least two safety devices that will assist in preventing the door from shutting on an obstruction (a car, a person etc.).
reisterstown garage door
johnsonnina31 is offline   Reply With Quote
HOW TO: Garage Door Opener Mod Trey How To's 87 04-28-2013 08:04 AM
'04 R1 Garage Door Opener Mod, Done!! r1-superstar Appearance & Mods 38 12-31-2007 09:56 AM
Garage Door Opener cheegro Appearance & Mods 13 12-25-2005 11:01 AM
04 R1 garage door opener mod help Rooster62181 General Motorcycle Discussions 11 03-31-2004 08:42 PM
garage door opener mod on 04 Rooster62181 General Motorcycle Discussions 0 03-26-2004 05:12 PM
