Carbs : Yamaha R1 Forum
Old 10-01-2011, 05:04 PM   #1
GotShafted
Wish I could ride
GotShafted's Avatar
Carbs
OK I cleaned all four of the carbs and now I have fuel coming out off the exhaust and number 1 and maybe number 2 carb. What did I do wrong? I tapped on the number 1 and 2 also with a rubber mallet to make sure the float isnt sticking. I need serious help because I'm sick of working on this thing.
GotShafted is offline   Reply With Quote
Old 10-01-2011, 06:47 PM   #2
-M-
How fast does this thing go?
-M-'s Avatar
Bikes: 2000 R1
how about you just take it back off and check? nothing beats doing it right...
-M- is offline   Reply With Quote
Old 10-01-2011, 07:35 PM   #3
Sharksawyer
Is there anybody out there?
Bikes: 99 R1
Were they having problems before you cleaned them? What did you clean them with? Did you clean your fuel inlet valves or maybe damage them?
Mark
99 R1
Old 10-01-2011, 08:23 PM   #4
tonebone
tonebone's Avatar
found that when i cleaned mine, and they leaked, that i had to replace the inlet valves. the o rings may look fine,but may be old.replacing all 4 sealed her right up.
tonebone is offline   Reply With Quote
Old 10-01-2011, 08:47 PM   #5
GotShafted
Wish I could ride
GotShafted's Avatar
It sat there for about a year. I was barly able to get it to run because the carbs were so gooped up. i took them apart and just put them in carb cleaner. i took my time putting it back together. im not sure how the floats could have got stuck, if that is the issue.
Set of R1 carbs tomf Bikes/Parts Wanted 0 10-04-2010 03:17 PM
carbs on 99 R1 monkeedave 98-99 R1 Mechanical Help 1 08-20-2007 11:57 AM
carbs dvsryders_grym Mechanical / Help 1 09-25-2005 01:27 AM
R1 carbs!! tomygunr1 Mechanical / Help 3 02-07-2005 07:40 PM
98-99 carbs flak3r Mechanical / Help 1 02-04-2003 11:21 PM
