2010 R1 starting problems : Yamaha R1 Forum
09-14 R1 Mechanical Help Mechanical and Critical Issues for the 09-14 R1
Old 03-18-2012, 02:15 PM   #1
Scrypt
Raise...
Bikes: Yamaha R1 2010
When I start the bike cold or hot doesnt matter it doesnt start from the first time , it starts then quickly dies , also the dash goes off for a second when it starts......any ideas?
it has akrapovic full race , PCV , graves smog-offs
Scrypt is offline   Reply With Quote
Old 03-22-2012, 04:06 PM   #2
sharan
sharan's Avatar
Bikes: Yamaha R1 2009
Probably the PCV is not correctly tuned for starting (low RPM and 0% throttle) ... my guess.
The best way of testing this theory would be to disconnect the PCV and try starting the bike. If it works correct without the PCV then you have to tune it properly.
sharan is offline   Reply With Quote
Old 03-23-2012, 11:00 AM   #3
Scrypt
Raise...
Yes I did try without the PCV and it starts perfectly ... as I know the 0% throttle cant be tunned with PCV you must reflash the ECU for that.
So I dont know what to belive anymore ?
And I checked the map in the PCV on 0% the values are 0 from 500 rpm to 15000 so it should start with the factory values right?
Also I think its not from the map of the PCV because the dashboard goes off for a second so its like something is eating power a second when it starts ......doesnt anyone had this problem ????
Old 03-24-2012, 01:36 PM   #4
sharan
sharan's Avatar
To my understanding, if you type '0' in a PCV cell it will use OEM ECU values.
I used to run PCV on my R1 09, and do not have similar problem. It may be the PCV hardware, maybe you should contact Dynojet.
What map are you using?
and have you tried to setup for "startup gass/fuel"?
Old 03-25-2012, 03:17 AM   #5
Scrypt
Raise...
No, how do I do that ? the map is M22-006-502
Old 03-25-2012, 11:38 AM   #6
sharan
sharan's Avatar
Start PCV Software and select:
Power Commander Tools | Configure | Feature Enables and Input Selections | Startup Fuel
Try also a zero map
Old 03-27-2012, 07:13 AM   #7
Scrypt
Raise...
Try also a zero map
Tryed today the zero map , same thing. Not sure what to edit in StartupFuel.
If I edit this like Run Time 10 sec Add Fuel 5 % does this mean it will rev it up 5 % or just add fuel and maybe choke ?
Old 03-27-2012, 12:33 PM   #8
sharan
sharan's Avatar
My understanding is that the PCV will add 5% fuel for 10 sec, and after 10 sec it will remove the additional 5%.
Try and let me know.
PS. Have to modified anything else on the engine and have you installed the Dynojet O2 optimizer that came with PCV?
Old 03-27-2012, 02:39 PM   #9
Scrypt
Raise...
Yes I installed the O2 optimizer that came with the PCV so the bike has a full akrapovic race open system and graves smog off plates.
Old 03-29-2012, 08:19 AM   #10
Scrypt
Raise...
I tryed with StartUP Fuel still nothing ...
Can you tell me when you switch the ignition on and you hear the gas pump for a few seconds my PCV green power light is on and after the pump stops the light goes off too , when you try to start it blink and stays on , is that normal ?
Old 03-29-2012, 08:21 AM   #11
R1nStang
R1nStang's Avatar
Bikes: 2009 Yamaha R1
have you made sure your PCV has the newest firmware update on it? not sure what version they are on..but from what I've heard its a must have firmware update
R1-015 `Ghostrider` Squadron
Yoshi TRC-D slip-ons, Leo Ypipe, PCV, -1/+1 520 conversion, ECUnleashed with Race Idle.
Originally Posted by TheBigO View Post
my anus is just swollen.. Shut it!!!
R1nStang is offline   Reply With Quote
Old 03-29-2012, 08:22 AM   #12
Scrypt
Raise...
Yes I`ve updated it a few days ago to V0.1.8.8 ...
Old 04-04-2013, 02:51 PM   #13
Ace_1ofakind
can anyone help me on. how to remove the pcv and where is it located? 2010 r1
Ace_1ofakind is offline   Reply With Quote
r1 2010 starting problem Scrypt 09-14 R1 Mechanical Help 13 01-14-2012 04:02 AM
help! 2010 R1 starting problems? paulie1108 09-14 R1 Mechanical Help 39 09-06-2011 05:39 PM
Starting off 2010 with a bang!! lexusrx Vendors and Group Purchases 8 01-05-2010 11:15 PM
Starting up problems... 328citony 02-03 R1 Mechanical Help 0 09-03-2007 09:38 AM
Starting Problems? tayhasanr1 Mechanical / Help 3 08-29-2005 04:42 PM
