Rev Counter jumping, thinkg EXUP valve! Help? : Yamaha R1 Forum
Old 04-08-2012, 11:53 AM   #1
Oz '99 R1
Gday all. Just having a problem, more annoying than anything really. Rev counter on my '99 R1 keeps going from 0 to 7,000 RPM then back to 0 and so on. Been reading aout it and nelieve it to be a fault with the EXUP valve? I have had the fairings off and checked that the valve does the usual turn (hope using the right word) when the ignition is turned on and it seems to be operating normal when revving the bike. Can anyone tell me why the rev counter is coming up with this fault and what I can do to stop it?
The bike runs normal 95% of the time and the fault not always showing on the rev counter but when it does, the bike feels like its stutters under acceleration at low revs.
Any help or ideas would be appreciated.
Thanks
Oz '99 R1 is offline   Reply With Quote
Old 04-08-2012, 01:54 PM   #2
Sharksawyer
Is there anybody out there?
Bikes: 2000 R1
Thanks
I'd pull the valve and clean it up or at least check if it rotates freely. Here's a good procedure for adjusting the EXUP:
http://www.sites4bikes.com/R1-EXUP-98-01-Adjustment.htm
One thing it doesn't tell you though is after each adjustment, start the bike, turn it off and then turn on the key. This will initialize the motor and you can check your adjustment. Also, don't make the cables too tight or you will get errors. Better to be a tad loose.
Mark
semi tight exup valve vs loose exup valve axollyn 07-08 R1 Mechanical Help 48 05-17-2012 04:44 PM
r1 exup valve delete. exup valve rouuting r1 hs no exup in headers stuntridda 00-01 R1 Mechanical Help 0 02-17-2010 06:59 PM
exup rev counter problem vicksr1 00-01 R1 Mechanical Help 3 07-03-2007 09:59 PM
Exup valve longjon Mechanical / Help 7 07-06-2004 07:01 PM
EXUP valve? 02RedR1 General Motorcycle Discussions 1 01-28-2003 09:58 PM
