r1 valve adjustment : Yamaha R1 Forum
00-01 R1 Mechanical Help Mechanical and Critical Issues for the 00-01 R1
Old 04-21-2012, 01:50 PM   #1
T tops
T tops's Avatar
r1 valve adjustment
I needed a new rear tire so i took it to the dealer for one and they gave me a list of other stuff i need so if there are write ups on this stuff a link would be super helpful
valve adjustment is necessary dont have a clue where to start
thanks
oh yea its a 01 and has 24,000 miles on it
T tops is offline   Reply With Quote
Old 04-21-2012, 02:13 PM   #2
Sharksawyer
Is there anybody out there?
Bikes: 2000 R1
thanks
A lot of R! guys find their valves in spec when they check them. This if from martinc three years ago:
"my 99 has over 450k km(279k miles) on it and the valves are just starting to tap...adjusted them once at 21k km and only 3 were kinda loose but withng specs....still running original cam sprockets and chain damn it!"
I'm currently pushing 50,000 miles and have never checked mine and don't plan on it. Just going to run it til it don't run no more.
Mark
99 R1
Old 04-21-2012, 02:33 PM   #3
T tops
T tops's Avatar
It is getting pretty noisey any ideas on what else to check
Old 04-21-2012, 03:45 PM   #4
Sharksawyer
Bikes: 2000 R1
What kind of noise?
Mark
Old 04-21-2012, 04:07 PM   #5
T tops
T tops's Avatar
sound is below 4k in all gears it sounds like a ticking or loose valves maybe timing chain guides or something similar??
Old 04-29-2012, 08:36 PM   #6
Treavor
Bikes: 2005 R1, 2004 R1, 2001 R1, 2002 R6
Get em adjusted. Should be something to do every 25000 or 30000 miles. I know the sounds youre having too. Got a 01 myself with almost 45000 miles. I had them as well, got to a point where i started having to adjust my idle speed to keep the bike from dying at idle. Got mine adjusted, the intake valves were pretty off. No more sound, perfect idle and you get so much response and power back.
It's gonna be expensive. Shops know that a 2001 r1 is a pain to work on, so go for a shop that has a flat rate instead of per hour. It's a long job. it'll easily be around 300 or so, depending on where you go. Of course, a Yamaha dealer is much preferred.
It's worth it.
Treavor is offline   Reply With Quote
Old 09-30-2012, 11:05 PM   #7
tigertim20
Mad Thou Rider
tigertim20's Avatar
Bikes: 2001 r1
does anyone know what the clearances should be?
Im looking at a manual, but a couple of friends think the clearances listed are way too tight to be right, can someone post up the intake and exhaust clearances for a 2001 model?
<img src=http://i1226.photobucket.com/albums/ee415/r1tim/sigpic.jpg border=0 alt= />
thanks petrol!!
tigertim20 is offline   Reply With Quote
Old 10-01-2012, 12:15 PM   #8
Treavor
Intake should be .11mm to .20mm
Exhaust should be .21mm to .30mm
Gotta remember though: You can either take your friend's word for it, and risk continuing too run rich or lean, or they can be adjusted to specs and you'll be safe. Something like a valve job, I recommend using a dealer, that way it's done right, and to specs.
Valve adjustment. pep-02R1 Mechanical / Help 5 11-01-2010 08:06 AM
Valve Adjustment Ray1 07-08 R1 Mechanical Help 1 12-26-2009 09:38 PM
Valve Adjustment $ ricardo Mechanical / Help 0 07-14-2003 08:22 PM
Valve adjustment kRon1c General Motorcycle Discussions 1 04-23-2003 03:21 AM
Why do a Valve adjustment? Swedie Mechanical / Help 14 11-28-2002 03:50 PM
Yamaha Motorcycles Victory Gunner Forum Victory Charger Forum Honda Vultus Forum HD LiveWire Forum Ninja H2 Forum Ducati Scrambler Forum Kawasaki Ninja 250SL Forum
