Slip on question : Yamaha R1 Forum
Motorcycle.com Classifieds!
Old 06-30-2012, 06:25 PM   #1
R1barda
ITS MY R1
Bikes: 2009 R1
Slip on question
Hi,
I have just installed akrapovic slip on
On my 09 R1.
I was told I have to install a dyno jet too
Cause of it.
Is it true?
R1barda is offline   Reply With Quote
Old 06-30-2012, 07:38 PM   #2
quick kurt
I RACE U LOSE
quick kurt's Avatar
Yes you should,but I would get a Bazzaz Zfi unit as fuelmap will probably be closer to what you need. Bazzaz unit has 2 fuelmaps already installed,with the connection plug for map selection switch in the harness near the rear of bike it is in slipon map and with plug removed its on the stock exhaust map. The cost of a fuel controller will go a long way for you and your'e bikes enjoyment factor as well keeping it from running too lean and possibly damaging it. Get the Flashtune ecu interface as well to unlock hidden power already in your bike for $350,or they can reflash your ecu for $150
'06 50th GYT-R CarbonSlipons,Akra Y Graves stacks,blockoffs,covers BMCair Bazzaz Zafm Zfi mapsw Vortex w/520ERV3 Shogun sliders Vortex rearsets Renthal med.comp Ballistic12cell Stompgrip CRG levers Galfer SBK fr&rr rotors ProboltTi'12 50th WGP#145. Graves full Ti carbon ex,stacks,blockoffs BMCair Yosh case,oilfill,yokenut,axleblocks Renthal w/520ERV3 CRG RC2's Watsen's Shogun framesliders Renthal med.comp Ballistic8cell ProboltTi Lucky 13th R1-013Squadron Member
quick kurt is offline   Reply With Quote
Old 06-30-2012, 07:47 PM   #3
T-MannIBP
I like to Ride
T-MannIBP's Avatar
Bikes: '09 R1 White/Black, '12 WR450 Supermoto
NO. You don't need power commander for a slip on.
T-MannIBP is offline   Reply With Quote
Old 07-01-2012, 11:52 PM   #4
RayJohns
2005 Yamaha R1
RayJohns's Avatar
Bikes: 2005 R1
Anytime you do something which increases air flow into the motor or reduces back pressure (i.e. slip-ons, full exhaust, etc.) then yes, you should install a power commander.
The power commander over rides the OEM ECU's fuel curve, avoiding possible lean conditions (i.e. more air going into the motor = lean, if you don't bump up the OEM fuel map). The power commander allows you to do this.
You don't *have to* run a Power Commander, but you risk running the motor on the overly lean side, which - over a prolonged period of time - could result in engine damage (burned valved, hot running, piston melting, etc.). With that said, it's difficult to say how lean a condition you'd end up with from just slip-ons. Also, the 2009 might have an O2 sensor that provides a feed back loop to the ECU (I don't know).
Most people do install a Power Commander when doing stuff like changing the stock exhaust to something that flows more freely and/or when adding a K&N type filter, etc. Having a tuned fuel map avoids running lean and matches the fuel curve to the flow characteristic of the exhaust you have. This helps you extract the most power from your bike and, as mentioned, helps to avoid the motor running on the lean side.
It's your bike; it's your call - as far as whether you install a Power Commander. I definitely would do it for a full exhaust (i.e. no cat, etc.). It's probably also not a bad idea for slip-ons; at least you have it and can dump the proper map into the Power Commander.
Ray
RayJohns is offline   Reply With Quote
Old 07-02-2012, 12:04 AM   #5
ss55539
Bikes: '11 FLHX, 09 YFZ450R, 07 YZ450F, 06 R1 50th
beneficial but not neccessary
ss55539 is offline   Reply With Quote
Old 07-04-2012, 09:17 AM   #6
R1barda
ITS MY R1
Bikes: 2009 R1
Thank you guys for your help. better safe then sorry. I will look into a power commander
thx
Slip on question.... pfd53 General Motorcycle Discussions 4 03-11-2005 03:24 PM
Another... slip-on question ahrwun How To's 1 05-12-2004 05:57 PM
slip on question? wildgoose General Motorcycle Discussions 7 04-07-2004 09:12 PM
Slip-On Question Samson Mechanical / Help 2 03-29-2004 06:24 PM
To slip on...or not to slip on...that is the question. 1fasr1 General Motorcycle Discussions 3 02-22-2002 04:42 AM
