The secret of the 2012 side light : Yamaha R1 Forum
Motorcycle.comGraves MotorsportsSportbikeTrackGear
Old 07-27-2012, 03:03 AM   #1
Flash-Ry
Flash-Ry's Avatar
Bikes: White R1 09 (My Baby) White R6 10 (the run around) GSXR 1000 09 (spare bike)
So i recently did the 2009 to 2012 conversion on my R1 and there was talk about not being able to change the side lights.
I said that's rubbish Yamaha wouldn't be so stupid as to seal a light inside a unit and not be able to change it if it fails.
So this post is for every one that was as curious as me to know what was behind the new 2012 side light for the R1 and why Yamaha thought it so important to seal it up.
I tried to heat it up, prise it off, twist it, pull it talk to it nothing worked
So i cut it off and i was surprised at what i saw.
There is no bulb its a circuit board with two LED's one facing straight and the other facing down.
I have a idea to modify this side light to hold a bulb/LED for more light and im hoping it shines brighter and all the way down the strip. Those who have the 2012 front end will know what i mean. The light doesn't quite reach all the way down the strip.
Comments welcome
2009 YAMAHA R1
FULL AKRAPOVIC SYSTEM, POWER COMMANDER V, K&N AIR + OIL FILTER, DARK WINDSCREEN, FLUSH MOUNT INDICATORS, INTERGRATED TAIL LIGHT, EVOTEK TAIL TIDY, HELL BRAIDED BRAKE LINES, ATE BLUE BRAKE FLUID, HID KIT 6K,
Flash-Ry is offline   Reply With Quote
Old 07-27-2012, 03:21 AM   #2
JRH_YellowR1_09
Rx for 2nd mid-life crisis
JRH_YellowR1_09's Avatar
Bikes: 2009 R1
So the "strip" is some sort of fiber optic light pipe?
I can't see why it doesn't light up the entire length.
They sealed the LED housing, because LED's theoretically have no where out mechanism if the current is properly limited to safe level.
Sent from my Motorcycle iPad app
2009 R1
2001 Yamaha Grizzly 660 4x4
1992 Suzuki DR650SN
RIP:
1981 Yamaha XV920RH
1974 Norton 850 Commando
1971 Norton 750 Commando
1979 Yamaha Enduro DT175
1971 Honda Z50A mini trail
JRH_YellowR1_09 is offline   Reply With Quote
Old 07-27-2012, 03:25 AM   #3
TheBFA
It's got pegs, shocks...LUCKY!
TheBFA's Avatar
I believe those are high intensity LEDs. You probably won't have much luck getting anything brighter unless you just put more. If you get brighter ones they will probably need a heat sink.
Sig courtesy of Petrol_Spice
TheBFA is offline   Reply With Quote
Old 07-27-2012, 03:33 AM   #4
JRH_YellowR1_09
Bikes: 2009 R1
So what color is the side light, white?
I changed the side bulbs on my '09 to PIAA ion yellow just to be different. I'm also running yellow H7's in the headlights during the day. It seems to make a difference in fewer cars cutting me off and generally noticing me more. Running with beams on high as well.
2009 R1
1992 Suzuki DR650SN
RIP:
1981 Yamaha XV920RH
Old 07-27-2012, 03:41 AM   #5
Flash-Ry
Flash-Ry's Avatar
Yes there pretty bright for only 2 LED's but you can always go brighter with more. I got some thing lined up i want to try and i will keep every one posted.
2009 YAMAHA R1
Old 07-27-2012, 03:49 AM   #6
Flash-Ry
Flash-Ry's Avatar
There side light is white and the light travels about 2/3 the way down
Shot at 2012-07-27
2009 YAMAHA R1
Old 07-27-2012, 04:59 AM   #7
T.C.
Bourbon is my blood
T.C.'s Avatar
You could try to change the led with one of these.
http://www.cree.com/led-components-a...onal/xlamp-xml
I have a flashlight with one in it and they're fvckn bright.
Sig by Uncle P.
T.C. is offline   Reply With Quote
Old 07-27-2012, 05:16 AM   #8
TheBFA
TheBFA's Avatar
I bet it would get too hot though. My dive light has those eLED's in it (I think 4) and runs off 4 C batteries and has a heatsink that protrudes through the middle of the lens to be water cooled. IT has a cap you have to keep on it so you don't burn yourself with it.
Old 07-27-2012, 05:20 AM   #9
T.C.
Bourbon is my blood
T.C.'s Avatar
You are right, they do get hot.
Sig by Uncle P.
Old 08-29-2012, 10:12 AM   #10
iMa Boss
Bikes: 2012 R1 WGP **#-1160** 08 R1, 01 CBR929, 09 DUCATI 1098, 05 GSXR 750 (sold), 06 CBR1000 (sold)
hmmmm.. i got an idea for this that will work... its going to be a winter project stay tuned....
iMa Boss is offline   Reply With Quote
Old 08-29-2012, 10:40 AM   #11
bacchus40
kickin' at the darkness
bacchus40's Avatar
Bikes: 2005 RAVEN R6, sold; PEARL WHITE 2009 YZF R1 ~ rip, CADMIUM YELLOW 2009 YZF-R1!
geez, i'm glad i've got an 09!... ahhahahhaa...
'09 R1
weighs 420lbs, 160rwhp!
Dynojet PCV
Leo Vince EVOII sbk CF cans / tips
Leo Vince y-pipe [cat elim]
GYTR air filter
graves AIS block off plates
ECUnleashed w/ Custom Tune, 158rwhp {thanks Nels!}
SHORAI LFX18 Lithium-Iron LiFePO4
SHOGUN no-cut frame slider kit
GB RACING case covers
GYTR screen
tidy tail
Watsens
6000k HID
GYTR Comfort seat
RACETECH springs forks / shock
RACETECH Gold Valve, shock
OHLINs FORK PISTON KIT
Carbon Lorraine pads
HEL SS lines
bacchus40 is offline   Reply With Quote
Old 08-29-2012, 12:07 PM   #12
iMa Boss
why??? its not a ISSUE its just something that would be nice to MOD
Old 08-29-2012, 06:12 PM   #13
jcfz6r1
jcfz6r1's Avatar
Bikes: '07 FZ6 & '10 R1
Good luck with that...my fingers are way too fat to try and f with wires and lights that small. haha
Would be cool to get a few color changing LEDs in there and hook em up to a controller so you could change colors without modifying anything again.
Lot's O' Stuff
R1-016 VENOM Squadron
jcfz6r1 is offline   Reply With Quote
Old 11-01-2012, 06:41 PM   #14
samngcheesan
50th 2012 R1 #1071/2000
samngcheesan's Avatar
any updates ?
samngcheesan is offline   Reply With Quote
Old 11-01-2012, 06:58 PM   #15
T-MannIBP
I like to Ride
T-MannIBP's Avatar
Bikes: '09 R1 White/Black, '12 WR450 Supermoto
Originally Posted by samngcheesan View Post
any updates ?
+1
T-MannIBP is offline   Reply With Quote
Old 11-02-2012, 01:18 AM   #16
MHAL_8876
Now CROSS-PLANE!!!!!
MHAL_8876's Avatar
Bikes: 06 R1 [RIP] 2010 R1 ROSSI FIAT
Originally Posted by T-MannIBP View Post
+1
+2
'10 R1 FIAT w/ '12 R1 FACE!!!
Yoshimura TRC Ti Slip-On, Jett Tuning ECU ReFlashed/Stock Idle, PCV, Cox Radiator Guards, Graves Smog BlockOffs, GYTR AirFilter, AirBoxMod, GYTR FrameSliders, GYTR SoloSeatCowl, GYTR Gas Cap Cover, TechSpec SnakeSkin TractionPads, ProGrip Clear TankPad, DDM 6K 35W Hids, Rizoma Zero 11 Turn Signals F/R, RizomaFox FenderEliminator, Motovation Fork Sliders, Woodcraft Spool/Sliders, DrivenGrips, Dunlop Q2's, Circuit1 Mirror BlockOffs, CRG LS Bar End Mirrors
MHAL_8876 is offline   Reply With Quote
Old 11-02-2012, 04:52 AM   #17
OptimoPrime
OptimoPrime's Avatar
Bikes: 2009 YZF-R1
damn glad i didnt pay 3k more for a led strip that doesnt light all the way up. missed the bullet on that
1983 yamaha xj550 (SOLD)
1995 kawasaki gpz1100 (engine fail)
2009 yamaha r1 (30k and still rockin)
2006 suzuki gsxr600 (sold)
1981 yamaha xs450 (sold)
2003 honda superhawk 996 (for sale)
OptimoPrime is offline   Reply With Quote
Old 11-02-2012, 12:19 PM   #18
T-MannIBP
I like to Ride
T-MannIBP's Avatar
Try more like I payed $130 dollars for my '12 Upper/Headlight conversion after I sold my '09 Upper and Headlight.
Bike looks ten times more aggressive and I love my LED strip!
Old 11-02-2012, 12:38 PM   #19
kingnba6
R1der
kingnba6's Avatar
Bikes: 2006 R1 Blue
the led strip is very nice on the 12s. i would do the exchange if i had a 09+ and get the 12 lights.
putting a Cree led, make sure you have a proper heatsink!
My 06 R1 Build Thread
R1-013 'Lucky 13th' Squadron
kingnba6 is online now   Reply With Quote
Old 12-03-2012, 05:57 AM   #20
mannny9008
Bikes: 2012 Yamaha R1 Raven edition
I have a 2012 Raven and I encountered the same problem. I wanted to change the color to red and also wanted it brighter. Let me when you figure this one out.
mannny9008 is offline   Reply With Quote
12 R1 Stock Headlights On 09-11 R1 rocketz Appearance & Mods 447 Yesterday 12:51 PM
Aux. light removal 2012 R1 Oilfieldtrash21 Appearance & Mods 6 06-18-2012 02:49 PM
2009 -2012 r1 oem seat cowl and intergrated light (Tn) Bike Parts For Sale 14 03-08-2012 06:21 PM
guage lights, rpm guage, temp guage, neutral light, side stand light -ALL not working 150atwheel Mechanical / Help 4 01-02-2008 07:39 PM
