Stahlbus speed bleeders review : Yamaha R1 Forum
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > Product Reviews > Handling
Handling Tires, Steering Dampers, Suspensions, Rearsets, Rims, Brakes etc etc
Motorcycle.com Classifieds!
Old 08-22-2012, 08:45 AM   #1
My94GT
My94GT's Avatar
Bikes: 09 R6
i posted this up originally on the R6-Forum but i also spend time over here enjoying all the nice builds you guys have going on so i figured id toss this review up here as well for a great little part.
ok so i picked up a set of the Stahlbus speed bleeders from Chief aka Bauce Racing and finally installed them. i must say at first i was a bit skeptical as to how these would be better then any other variation of a speed bleeder on the market currently, but once i had a chance to use them i immediately was impressed with their quality and function ability.
the install was straight forward, remove the stock and replace with the stahlbus valve
from there, remove the cap and crack open the smaller 8mm valve built into the bleeder base-
here is where everything moves fast, instead of the need to repeat the opening and closing of this valve while pumping the brake to build and release pressure, the internals valve system of the Stahlbus does the work for you
the whole process is a simple one man job now and even with out the use of a mighty vac or something similar, only take a matter of minutes to complete.
its hard to see in these pics because the tubing im using to drain the fluid and air out is stained from the old ate super blue fluid i used before. ive now switched to the motul rbf 600, but the fluid is bubble free and clear after draining the old stuff out and flushing and refilling the new.
from there a simply tighten down the 8mm valve and re install the cap and you are done. for someone that goes to the track regularly and does not want to risk damage to the threading of their calipers or master cyl. this is an ideal part to have. another bonus is the sure feeling of solid brake force every time due to a solid bleed with no risk of air re entering the system while the process takes place. here are a few more shots of them all installed on the bike-
hope this helps anyone on the fence see why these are more then worth the asking price, any questions feel free to ask. anyone looking to order get in touch with Chiefsmokedawg aka Bauce Racing and he will get you set up, these bleeder valves make a nice complement to the Stahlbus oil drain valve as well, which Chief also can hook you up with
http://www.bauce-racing.com/
i just got off the phone with Chief, i know hes a member over here and hes getting the ball rolling to become a vendor here as well right now so ill leave his info in here.
My94GT is offline   Reply With Quote
Old 08-22-2012, 09:26 AM   #2
Stonewall
ROWDY
Stonewall's Avatar
Bikes: 2009 Yamaha R1
+ 1 on those! I have them and they are
ROWDY
Stonewall is offline   Reply With Quote
Old 08-22-2012, 09:46 AM   #3
ChiefSmokeDawg
ChiefSmokeDawg's Avatar
Bikes: 2002 & 2008 R6
This ^^
I am a dealer for Stahlbus if anyone is interested in these, or even cooler than these is having this bleeder in your banjo bolt for the expensive Brembo calipers, etc. AND you can even get these bleeders in Titanium if you'd like!
Ti bleeders:
4 pack of Stainless bleeders:
PM or email at info@bauce-racing.com!
I'll put up some FS threads today!
ChiefSmokeDawg is offline   Reply With Quote
Old 08-22-2012, 09:53 AM   #4
ebags
mmmm gold bits
ebags's Avatar
Bikes: 5VY
I herd someone say titanium that's pretty sweet... I've saved your email for when I get my calipers saughted out.
"Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere."
Colin Chapman
Uncle P. Originals
Originally Posted by burn-z View Post
I'm pretty certain you don't have anything from Magnetti Marelli.
Originally Posted by WayTooFastWhyty View Post
I have a magnetti marelli battery thank you
ebags is online now   Reply With Quote
Old 08-22-2012, 10:17 AM   #5
ChiefSmokeDawg
:cheers
Ti is like crack for me man. I can't lie. Between that and the new Leo Vince CF parts we been getting, OMG what a sexy beast you have in the end!!
Old 08-22-2012, 10:41 AM   #6
My94GT
My94GT's Avatar
Bikes: 09 R6
hanging around here makes me want some flashy stuff, im just trying to build a little track bike lol
Old 11-14-2012, 02:28 PM   #7
ChiefSmokeDawg
Tell me about it!!!
Old 11-16-2012, 07:10 AM   #8
My94GT
My94GT's Avatar
Bikes: 09 R6
hey hanging around you and walt is just as bad, both yours and his bike are packed with little goodies
Old 11-25-2012, 08:23 PM   #9
mr2guru
U win some U lose some
mr2guru's Avatar
Bikes: 2009 VMAX, 2006 R1 50thAE
I'm sure they are trick but that is a lot of coin....
mr2guru is offline   Reply With Quote
Old 11-28-2012, 09:47 PM   #10
ChiefSmokeDawg
They were on sale for the holiday weekend. Without the caps, the bleeder itself is only $35. So $105 full retail on the 3 for the front if you frequently bleed brakes and are more into their functionality than anything, it's a good price. Other bleeders aren't too much less money, and make their seal poorly by a thread sealer on them that wears out over time and introduces air into the system. And the constant in out action of bleeding with them or even the traditional OEM style bleeders can wear the caliper threads and result in poor performance when they heat up! The base of the Stahlbus ones goes in once and that it!
It's a VERY high quality piece as well, certainly worth the price!
