» Site Navigation |
» Motorcycle Forums
09-20-2012, 07:22 AM
#1
Bikes: 2010 White R1
Sprocket Help / Chain Recommendations
Looking to drop -1 on my R1, what is the difference between:
520
530
2010 Yamaha R1
Leo Vince Unlimited Mid Night Slip On's
Two Brothers Stainless Steel Y-Pipe
ECU Flashed
BMC Air Filter
Shogun No-Cut Frame Sliders
09-20-2012, 07:38 AM
#2
mmmm gold bits
Bikes: 5VY
"Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere."
Colin Chapman
 Uncle P. Originals
Originally Posted by burn-z
I'm pretty certain you don't have anything from Magnetti Marelli.
Originally Posted by WayTooFastWhyty
I have a magnetti marelli battery thank you
09-20-2012, 07:40 AM
#3
Bikes: 07 R1
It is the pitch of the chain. In very simple terms its how chunky or big the chain is. A 520 chain is smaller and therefore lighter. Its a common conversion especially for track bikes as there is less mass which equates to less momentum in the drive train.
-1 from the front sprocket will give a far more noticable effect. More bottom end and roll on torque but small sacrifice in top end speed.
Heaps on here about it all if you search.
.....I type way too slow, lol.
#4
Originally Posted by ebags
Fanks!
2010 Yamaha R1
ECU Flashed
BMC Air Filter
09-20-2012, 07:58 AM
#5
mmmm gold bits
Bikes: 5VY
Originally Posted by drozek
Fanks!
No worries dude. I'm running a 520 setup with -1/stock aluminium rear and its noticeable that's for sure. Better punch off the line and gets through the rev range quicker.. and very respectable crusing rpm on the freeways.
Colin Chapman
 Uncle P. Originals
#6
Bikes: 2006 Yamah R1
How big of a weight savings are people usually seeing?
When I just put on my 520 kit I think I kept 2 more links but it weighed the same as my old beat up 530 chain. I thought it seemed kind of weird but maybe it was my crappy scale or something else.
09-20-2012, 08:16 AM
#7
mmmm gold bits
Bikes: 5VY
From my 2004 OE 530 to a EK MVXZ 520 I lost 122g... not a lot bit its rotational mass so on another hand its quite large; DID's race chain will save more.
The biggest saving comes from the sprockets. I saved 500g/1 pound-ish switching from a 45t OE sprocket to a Renthal aluminium 45t.  The front from OE to Renthal superlite -1 was around 120g.
I doubt you notice the weight of the chain or front sprocket but I sure as shit noticed the 1lb loss in the rear sprocket. Not sire what the ultra light steel rears weigh but there's good weight saving there's too if wear bothers you... I do stiff all millage each year so alu suits me.
Colin Chapman
 Uncle P. Originals
09-20-2012, 04:34 PM
#8
Can I just change my front sprocket to t16 and leave the rear stock?
Sent from my iPad using MO Free
2010 Yamaha R1
ECU Flashed
BMC Air Filter
09-20-2012, 04:56 PM
#9
I RACE U LOSE
Yes you can, 520 or 530 is on the chain itself to let anyone knoww what size parts are needed. I don't see any type of flashed ecu in your sig. A flashed ecu will do wonders for your power,my '12 is unbelievably stronger flashed. More so than the hp #s show.
'06 50th GYT-R CarbonSlipons,Akra Y Graves stacks,blockoffs,covers BMCair Bazzaz Zafm Zfi mapsw Vortex w/520ERV3 Shogun sliders Vortex rearsets Renthal med.comp Ballistic12cell Stompgrip CRG levers Galfer SBK fr&rr rotors ProboltTi  '12 50th WGP#145. Graves full Ti carbon ex,stacks,blockoffs BMCair Yosh case,oilfill,yokenut,axleblocks Renthal w/520ERV3 CRG RC2's Watsen's Shogun framesliders Renthal med.comp Ballistic8cell ProboltTi  Lucky 13th R1-013Squadron Member
09-21-2012, 05:18 AM
#10
-You can have an odd number front and odd number rear 6:32 PM
-Or even front and even rear 6:33 PM
-Never odd front and even rear 6:33 PM
-And you always need an even number of chain links, no matter what 6:36 PM
Is this true?
2010 Yamaha R1
ECU Flashed
BMC Air Filter
09-21-2012, 05:24 AM
#11
I RACE U LOSE
Any size front or rear,doesn't matter. Chain is always even # of links.
09-21-2012, 05:30 AM
#12
R1 Forum Star
Originally Posted by Doppler
It is the pitch of the chain. .
Incorrect
The 5 is the pitch (same for 520 and 530)..the 20 or 30 is the width
This part is correct in that a 520 chain is thinner and therefore lighter
Originally Posted by Gearheaded
Originally Posted by MelvinAkshay
PJ, so you lied to me.  lol it doesn't look that big
09-21-2012, 05:35 AM
#13
R1 Forum Star
Is this true?
No...chains end up being even # of links but the rest of that is horseshit. You can do odd #teeth in front or back and any combonation
09-21-2012, 04:37 PM
#14
Hook'em Horns
Bikes: 2007 R1
Oh and use nothing but WD-40, always!
Signature courtesy of Petrol Spice
09-21-2012, 09:52 PM
#15
MummyMan
Bikes: 1999 r1, 07 GSXR 1k
technically correct or not everyone still calls it the pitch...even the chain/sprocket manufacturers lol.
10-12-2012, 06:31 AM
#16
so i got a -1 in front and +2 in the rear, what is a recommended chain to use? any have any suggestions
2010 Yamaha R1
ECU Flashed
BMC Air Filter
10-12-2012, 06:41 AM
#17
Don't be so picky. I wasn't!
Bikes: 06 R1
You can use anything from oring to xring. Try to find something with 9,000 lb tensile strength, and most importantly don't mix the numbers up. As in if you have a 520 front, make sure your rear is 520, along with your chain. Don't put 520 sprockets with a 530 chain. I'd personally stay away from eBay chains unless they are from a reputable manufacturer.
Modifications:
Vortex Rear sets
Galfer Lines
Woodcraft Covers
Shorty Levers
Roth Smog Plates
Cox Radiator Guard
Scorpio i900
Smoked Tail Light
Flushies
0 Gravity Windshield
Hotbodies Rear Hugger
Driven Grips
Vortex Sliders
Graves Clutch Slider
Vortex Slider Spools
Pro-Tek BF Caps
BF Socks
10-12-2012, 07:01 AM
#18
what about the chain link length?
2010 Yamaha R1
ECU Flashed
BMC Air Filter
10-12-2012, 07:08 AM
#19
Bikes: 06 R1
Well the stock chain length is 116 links.
So if you are doing just a -1 in the front the stock link length will work. However if you are increasing the rear I'd say find a chain with a 120. You won't need all 120 links, but in this case, it's better to have more than not enough. You can always trim the chain to the desired length. Just make sure you leave some room for adjustments to tighten the chain incase it stretches on you down the road.
Modifications:
Vortex Rear sets
Galfer Lines
Woodcraft Covers
Shorty Levers
Roth Smog Plates
Cox Radiator Guard
Scorpio i900
Smoked Tail Light
Flushies
Driven Grips
Vortex Sliders
Pro-Tek BF Caps
BF Socks
10-12-2012, 09:13 PM
#20
HP Addict
Bikes: 07 White/Carbon Fiber R1
Interesting. So if i get the driven 520 with -1 front and stock t45 the bike will have a better launch? What if i get the t47 rear, what effects will happen there?
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
