How to: Remove bar end inserts : Yamaha R1 Forum
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > How To's
Motorcycle.com
Old 09-28-2012, 07:29 PM   #1
Monster R1
It taste like burning
Bikes: 2010 Yamaha Yzf R1 Raven
Wink How to: Remove bar end inserts
So, I bought a pair of bar ends for my bike off eBay. I went to install them and they were not a direct bolt on. The ones i got go in further and have a rubber plug that gets squished/ expands to hold it self in the handle bars. I took the stock ones off, low and behold, a threaded insert. I tried what I could and finally found the easiest way.
Step 1: Remove bar end and rubber grip from the handle bar. Removing the grips, if it's the oem ones, you will need some brake cleaner. There is some kind of epoxy glue that holds on the grip. Also, having air and a nozzle to shoot under the grip, that helps a lot also.
Step 2: take a bolt(or the one that you removed) and screw it into the insert( don't install the bar end, just the bolt) and put a set of vise grips on the end of the bolt.
Step 3: get a small torch and heat up where the insert is while pulling out. With in about a minute, it should pop right out. The inserts are glued in and the heat helps break them. Just don't get the bars to hot, not sure if it would ruin the electronics.
If you need to, you can reuse it. I put mIne together as a set and put them away incase I want to change them back.
That completes the clutch side
The right side(accel side) is a ton easier to do because you dont have to mess with removing the grip from the handle bar.
Step 1: remove bar end and also the two screws from cable guide box of the throttle. Once done, set the halves aside( take note that the screws are two different lengths) **top-long: bottom-short**
Step 2: remove the cables from the throttle( keep in mind that the cables will hook up at the bottom, and also te position of the throttle)
Step 3: once that's done, every thing should slide off and your left with bare metal of the bar
Step 4: since you don't have to mess with the grip( attached to throttle tube) continue from step 2 from the first set of directions.
***when your done, make sure you clean the metal before applying the grip. Using hair spray, it will slide on easy and when it drys it will act like glue***
Hope this helps people looking how to remove the bar ends
Monster R1 is offline   Reply With Quote
Old 09-28-2012, 07:43 PM   #2
ss55539
Bikes: '11 FLHX, 09 YFZ450R, 07 YZ450F, 06 R1 50th
or just use a slide hammer
ss55539 is offline   Reply With Quote
Old 09-28-2012, 07:52 PM   #3
Monster R1
Yeah, that would be 100 times easier. I just used what I had. When i was searching I couldnt really find many answers, but I'm kinda terrible with the search feature.
Old 09-28-2012, 07:56 PM   #4
lobsterhound
lobsterhound's Avatar
Bikes: 03 600rr, 02 r1
You can also set a socket up against then end of the bar thats the same diameter as the bar. Throw a washer over the end then a bolt that fits in the threaded hole. Tighten down till the compression fitting slides out
Sig pic courtesy of Uncle Petrol "Guard against the impostures of pretended patriotism." -G. Washington
lobsterhound is offline   Reply With Quote
Old 09-28-2012, 08:24 PM   #5
Monster R1
All good ways
Old 09-28-2012, 10:00 PM   #6
ss55539
yeah i didnt mean to ruin your thread but a slide hammer is easy cheesy
Old 09-29-2012, 06:33 AM   #7
Monster R1
Yeah, there all good. I just didn't have a slide hammer available haha
Old 11-11-2012, 09:18 AM   #8
Monster R1
i cant find this, why is the how to only 1 page long
