Keihin 41mm carb... Help : Yamaha R1 Forum
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > Mechanical / Help > 00-01 R1 Mechanical Help
00-01 R1 Mechanical Help Mechanical and Critical Issues for the 00-01 R1
Motorcycle.com
Old 10-09-2012, 04:41 AM   #1
racingdynamics
Hey Guys,
I have just acquired a classic 2000 R1.
The Carbs are GONE so i figured ill get the KEIHIN 41MM performance carbs since i am going to be making some performance modes to it.
but before moving forward, and considering the fact that THERE ARE NO DYNOs anywhere close to me, can someone please tell me if a brand new carb like such would require some tuning or it is basically PLUG n PLAY?
hope you would share your much respected opinions.
thanks.
kris-
racingdynamics is offline   Reply With Quote
Old 10-09-2012, 05:12 AM   #2
racingdynamics
ANY ONE ? .... help
Old 10-09-2012, 06:39 AM   #3
zx7marsh
zx7marsh's Avatar
When I got a used set of FCR41's, the jetting was in the ball park but not great. It would run but very rich. Be prepared to spend some time with the jetting. Will try and help you when you get them.
zx7marsh is online now   Reply With Quote
Old 10-09-2012, 07:17 AM   #4
Ronin R1
My 782 gear when I joined
Ronin R1's Avatar
Bikes: 98 R1, 02 R1, 03 KTM 525 Motard, 04 YZ450, 05 ZX-636, 05 HD Street Glide, 07 Gixxer 750
Throttle cables might not be the stock length either, at least they weren't on my 98
Biblical Evidence For Catholicism
(IXOYE)<
Ronin R1 is offline   Reply With Quote
Old 12-01-2012, 07:32 AM   #5
BlaziN R1
ryongchoi is my bitch...
BlaziN R1's Avatar
Bikes: '12 GP Anniversary YZF-R1, '99 Red YZF-R1, '01 Champions Edition YZF-R1, '07 TTR-50, '05 Zuma
Most likely you will need to tune the carbs to get the bike to run optimally. The 41mm flatslides give you an amazing boost of performance from the midrange on. Get it dialed in right and enjoy the ride.
Noriyuki Haga - #41
BlaziN R1 is offline   Reply With Quote
Old 12-02-2012, 05:23 AM   #6
rorlow
Foggy Rules
rorlow's Avatar
Bikes: Silver/Gray 02
to bad blur1 isn't around, he had alot of experience with them on his 98
rorlow is offline   Reply With Quote
Old 12-02-2012, 06:39 AM   #7
firehawk2003
Ask the Master Chief
firehawk2003's Avatar
Bikes: Harris R71
No dyno, might as well mount up a set of stock carbs and save the money. FCRs need tuning to realize full potential.
firehawk2003 is offline   Reply With Quote
Old 12-02-2012, 10:10 AM   #8
Kangaroo
para bellum
Kangaroo's Avatar
For crabs, visit your urologist
Brothers riding on...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
Kangaroo is online now   Reply With Quote
Old 12-02-2012, 03:00 PM   #9
capecodr1
maybe do what i did. someone previously deleted the exup from my collector pipe. i took the exup plate out and welded a o2 bung and bolted back on. run a lc-1 wideband. they are cheap and take the guess work out of a/f. took all of about an hr to install using the plate on the collector to drill and weld bung.
capecodr1 is offline   Reply With Quote
Old 12-02-2012, 03:19 PM   #10
damianroadracer
damianroadracer's Avatar
Bikes: 1999 R1
Smile carbs
I have had three R1's with FCR carbs on them. The carbs come with 185 main jets from the factory. This main jet is about 90 percent correct as long as you are runnin ram air and a full exhaust system. You will notice an immediate difference.
damianroadracer is offline   Reply With Quote
