Bad News Regarding my 2008 R1...engine failure : Yamaha R1 Forum
SportbikeTrackGearMotorcycle.comMotorcycle.com Classifieds!Graves Motorsports
Old 10-26-2012, 05:19 PM   #1
albertg
Hey all...I need some help/advice.
I brought my '08 R1 (only ~3,000 miles on bike) to the dealer about 4 weeks ago so they could check a knocking sound that I thought might be the stuck valve/valve guide problem that others have experienced with the R1. I started hearing what I assumed was louder than normal valve ticking the last 200 miles before the knocking started. I also called Yamaha Customer Service to register this issue before seeing the dealer. The dealer got back to me about 2 weeks ago and said they think the problem is the cam chain tensioner which they ordered and replaced and told me it would cost me ~$4-500 out of pocket. Yesterday, they called to say they re-assembled the bike and started it up but the knocking is still there. They spoke on the phone with a Yamaha tech rep and now they suspect I spun a main bearing on the crankshaft.
I changed oil and filter myself at 400, 800, 1,300, 2,000 and again recently at 2,9xx miles when I first noticed the knock. I have 3 bikes and only ride on weekends so I made it a point to change oil before recommended maintenance intervals and at least annually. The bike is garage kept in a dry environment and stable temperatures. I used Rotella Triple Protection 15W40 dino (API CJ-4/SM, JASO MA) and a Purolator 'Pure One' PL14612 filter at each change. This oil meets the standard specified in the owner's manual and scores highly in all used oil lab test results that I've researched.
The Yamaha rep told the dealer that the PL14612 oil filter is a "car" filter and probably caused oil-starvation leading to the engine failure and thus Yamaha won't pay for the repair. I got oil/oil filter recommendations on this forum and other sources like calci.com...others seem to be using this oil and filter for many miles without engine failures. Calci.com gave good feedback on both the Rotella and PL14612 for motorcyles.
The dealer says they have to pull/breakdown the engine for the repair and the cost can be high. I've asked the dealer to give me a best and worst case scenario for cost of parts and labor. I also asked the dealer to wait a week while I check-in with Forum members. It's hard to believe this engine should have failed at just under 3K miles with the oil changes that I did. The bike was undergoing a progressive break-in and never was over 8-9K RPMs to date. I've since read that the by-pass pressure on the PL14612 is ~14-18 PSI, and that motorcycles typically are designed for an oil filter with 8-11 PSI bypass pressure. Would that small difference in by-pass pressure have caused this type of failure? I can't imagine that the by-pass would have even come into play on a relatively clean filter with such low mileage.
So what advice can you offer me? Is Yamaha giving me the corporate run-around? Should I defend the use of the PL14612 and push harder for Yamaha Corp to pay for repairs? Also, if indeed oil starvation caused a main bearing failure, what other potential damage could have been done to the engine/tranny? The dealer drove the bike and said the tranny seems fine. Is it worth fixing if I have to pay for repairs out-of-pocket, or should I eat the loss and sell the bike for parts?
I really like the bike. I was hoping to ride it more, especially for work commutes and pleasure. I got that sick feeling in my gut...
Advice appreciated
albertg is offline   Reply With Quote
Old 10-26-2012, 05:42 PM   #2
TheForumGay
TheForumGay's Avatar
Honestly, you cheaped out on oil and a filter for a high performance machine and now you want Yamaha to pay for it? Sorry man. Get ready to bite a big repair bill, Yamaha shouldn't have to pay for you being cheap.
Oil is the most important part of the bike, why cheap out?
TheForumGay is online now   Reply With Quote
Old 10-26-2012, 06:15 PM   #3
stanmart
Barber or bust?
stanmart's Avatar
Bikes: BMW S1000rr
new engine might be cheaper. look on ebay.
2012 BMW S1000rr
Wunderlich Levers and Windscreen.
Exhaust to come
stanmart is offline   Reply With Quote
Old 10-26-2012, 06:25 PM   #4
Meister37
The Lead Farmer
Meister37's Avatar
Pretty much. Not all filters are created equal. Purolator are total junk.
Necessity is the plea for every infringement of every human freedom, It is the argument of tyrants; It is the creed of slaves.
William Pitt 1783
Phantom Squadron #37
Meister37 is offline   Reply With Quote
Old 10-26-2012, 06:47 PM   #5
SmoothyNoButt
Don't hit me please
SmoothyNoButt's Avatar
Bikes: 2009 White/Red R1
I agree. I know a lot of people believe in synthetic oils, but I've always used OEM factory Yamaha oil and filter.
SmoothyNoButt is offline   Reply With Quote
Old 10-26-2012, 06:47 PM   #6
designflaw
Did you say R1?
designflaw's Avatar
designflaw is offline   Reply With Quote
Old 10-26-2012, 08:12 PM   #7
IMSTuner
IMSTuner's Avatar
Bikes: 2008 R1
You can see if it's the excessive intake valve guide wear right in the air box down the intake tubes.
2008 R1 Black - Gold AVS C5 Levers, Puig DB Wind Screen, EvoTech Sliders Kit, T-Rex Clutch slider, Stomp Tank Pads, LeoVince Ti Factory Evo II CF end caps, Arko Y-Pipe, R&G Fender Elim., Proton Signals, PZRacing GearTronic Zero , Q2 tires, Flash-Tune Interface
My Build Thread http://www.r1-forum.com/forums/showthread.php?t=336353
YouTube Page http://www.youtube.com/user/imstuner?feature=mhee
IMSTuner is online now   Reply With Quote
Old 10-26-2012, 08:33 PM   #8
Meister37
The Lead Farmer
Meister37's Avatar
I used to use golden spectro cause it was free. I use Mobil 1 4T now.
William Pitt 1783
Old 10-26-2012, 09:30 PM   #9
bacchus40
kickin' at the darkness
bacchus40's Avatar
Bikes: 2005 RAVEN R6, sold; PEARL WHITE 2009 YZF R1 ~ rip, CADMIUM YELLOW 2009 YZF-R1!
purolator makes oil filters!?? wtf...
honestly dude.. amsoil advanced synthetic + hiflofiltro, done...
why would you fvck around with with perfection!??
lesson learned aguess!
recently rode the bike after not riding her through summer, the gear box felt sticky as shite..
instantly new it. oil got old... bike not getting ridden through winter... time for oil change..
in goes AMSOIL, new filter as well.!! will do the same in spring... its so cheap.. when we're talking
about a 10k motorcycle,!!...
'09 R1
weighs 420lbs, 160rwhp!
Dynojet PCV
Leo Vince EVOII sbk CF cans / tips
Leo Vince y-pipe [cat elim]
GYTR air filter
graves AIS block off plates
ECUnleashed w/ Custom Tune, 158rwhp {thanks Nels!}
SHORAI LFX18 Lithium-Iron LiFePO4
SHOGUN no-cut frame slider kit
GB RACING case covers
GYTR screen
tidy tail
Watsens
6000k HID
GYTR Comfort seat
RACETECH springs forks / shock
RACETECH Gold Valve, shock
OHLINs FORK PISTON KIT
Carbon Lorraine pads
HEL SS lines
bacchus40 is offline   Reply With Quote
Old 10-27-2012, 06:37 AM   #10
RedDevil154
R1 pilot
RedDevil154's Avatar
Bikes: 08 Candy Red R1
I bought my bike with 9k on it May of this year and changed the oil right away with Rotella T6 synthetic and a Wix 51358 filter. On my second oil change with 17k miles. Need to change it again ASAP. Engine has been very happy. I drive mine everyday to work 70 miles round trip. Even drove this morning at a chilly 30 degrees.
I have heard that puralator says don't use their filter on motorcycles. Somebody said it has a warning on the box. They do make a motorcycle filter though but I don't have the part number.
RedDevil154 is online now   Reply With Quote
Old 10-27-2012, 06:40 AM   #11
Meister37
The Lead Farmer
Meister37's Avatar
Wix is a decent filter, but not as good as OEM. I prefer the K&N. Wire ready!
William Pitt 1783
Old 10-27-2012, 06:45 AM   #12
RedDevil154
R1 pilot
I ran K&N on my 700 grizzly with the same Rotella T6 and never had any issues with it either. I like the K&N because of the hex welded to the bottom. Make getting the filter of so much easier. Especially on grizzly with all the plastic on. Only reason I run Wix on the bike is because I can pick them up locally. Closest bike shop that carries hiflo or OEM is an hour away verses 5 minutes to get the Wix. And the bike seems to be happy with them so ill probably just keep using them. I don't really ride it hard though. Just a bunch of highway miles.
Old 10-27-2012, 06:55 AM   #13
hawk71
Viva La Figa
hawk71's Avatar
Bikes: 03 Liquid Silver
K&N filter and Mobil 1 Racing 4T. Been using it for as long as I can remember with no issues.
"No. You live more for five minutes going fast on a bike like that than other people do in all of their life."~Marco Simoncelli
R1-016 `Venom` Squadron
NESBA #71
hawk71 is offline   Reply With Quote
Old 10-27-2012, 07:15 AM   #14
WestSide_'10R1
LIVE EVERY MOMENT!
WestSide_'10R1's Avatar
Bikes: 2010 r1
looks like op used wrong rotella.....he said he used " I used Rotella Triple Protection 15W40 dino. ...can you tell us which one you used!
ID:	475768   Click image for larger version
WestSide_'10R1 is offline   Reply With Quote
Old 10-27-2012, 07:23 AM   #15
TheForumGay
I don't understand why people cheap out...
I've seen multiple threads on people taking the cheap ways and having issues, but I've never seen a "amsoil/motul/repsol/mobile/(whatever name brand you feel like saying) blew my motor."
Old 10-27-2012, 07:27 AM   #16
MeanOne
Recreational adrenaline user
MeanOne's Avatar
Bikes: 2008 Raven R1
When did this change into a "what oil do you use thread?"
As soon as I read "Bad News Regarding my 2008 R1...engine failure", I had a feeling...
I'm not going to claim that I'm some engine guru, but I seriously doubt that's what caused the engine problems the OP is having, especially considering the very well documented knocking/valve issues the 08's have.
OP I'd suggest getting a compression test run. If one of your cylinders is crazy low that will tell you right away that its not the damn oil or the filter, its the same valve issue so many other 07-08 owners have had. BTW if they tried to tell you it was the cam chain tensioner without doing a compression test, they just screwed you out of $400+ with no results.
Ask me how I know all of this...
If I had to guess, I'd say Yamaha is looking for a way out of paying $2000+ for the valvetrain work that is probably causing the problem, and they found it by nitpicking your oil filter. I'd say get the compression test run, and steel yourself for a fight.
Check these threads too:
http://www.r1-forum.com/forums/showthread.php?t=296718
http://www.r1-forum.com/forums/showthread.php?t=234200
Sorry, but if you have a sick feeling in your gut now, wait until you see all the pics of valve stems from 07-08s that look like this one:
"It is incredible, what a rider filled with irrational desire can acheive."
Check out my Black 'n' Gold '08 Build Thread
MeanOne is offline   Reply With Quote
Old 10-27-2012, 07:37 AM   #17
MeanOne
MeanOne's Avatar
Agreed, and I seriously doubt that's the case here. But if you were Yamaha, looking down the barrel of over $2000 worth of repairs, it would be easy to use that as a scapegoat.
Old 10-27-2012, 07:37 AM   #18
TheForumGay
You think oil starvation wouldn't cause the valve issue?
Old 10-27-2012, 07:46 AM   #19
RedDevil154
R1 pilot
He said they think he spun a main. The oil I can't see being the problem. What I can see being the problem is the filter. Like I said, puralator tells you not to use their filter on a motorcycle unless its a motorcycle filter. That being said, I'd pull the air box and look at the valves. It's easy to do. I did it when I installe my BMC filter. As notorious as these engines are for valve train issues, I would not rule that out until until I saw the valves personally. If it is a main, I would saw you screwd yourself by using the puralator filters. If its valve guide/valve issue, I would fight tooth and nail to make yamaha pay for it with only 3k miles.
Old 10-27-2012, 07:51 AM   #20
MeanOne
MeanOne's Avatar
With all the 07-08s that had the exact same valve problem, why would this ONE very low mileage bike have valve issues only because of the filter?
They also said they thought it was the cam chain tensioner. Replaced it, billed him for it, and obviously didn't fix a damn thing.
For the record, TWO shops told me it was the cam chain tensioner before my valve issue was discovered, and guess what? 15psi of compression in #3 (200-210 is within spec, I believe) and a valve that looked like a sharpened pencil.
