SuperStreet Bike Magazine Nov 2012 Feature: "50th Red & White Anniversary Scheme" : Yamaha R1 Forum
SportbikeTrackGear
Old 10-30-2012, 04:46 PM   #1
1OGR1
Veteran
1OGR1's Avatar
Bikes: ArE FuN AlThOuGh It Is A VeRy ExPeNsIvE hObBy...
I was featured in the November 2012 issue of SuperStreet Bike Magazine. I attached my article of my 2004 Yamaha R1 LE at the bottom. Please let me know what you guys think Here's a link to my SSB Mag article: http://www.superstreetbike.com/featu...004_yamaha_r1/
-Engine-
*2006 Yamaha R1 LE Graves Motorsports Supersport Race Spec Engine (185 hp & 87 lbs Torque to the Rear Wheel)
*Akrapovic Evo2 Full Titanium Exhaust System
*BMC Race Air Filter
*BMW OEM Antifreeze Engine Coolant
*DID GOLD ERV3 520 Chain
*Driven Front 16 Tooth Sprocket
*Drive Systems Superlite 47 Tooth Rear Sprocket
*Factory Pro Velocity Stacks
*Graves EXUP Valve Eliminator Adaptor
*Graves Oil Pump
*Graves Smog Block Off Plates
*Graves Valve Grinding & Resurfacing of Heads
*Graves Water Pump
*H20 Performance Oversized Race Radiator
*Motul 300V Competition Synthetic Oil
*Samco Silicone Hose Radiator Kit
*STM Slipper Clutch
*YEC Base Gaskets
*YEC Head Gaskets
*YEC Valve Springs
-Electronics-
*AIM Sports GPS Module
*AIM Sports Pista Digital Dash with Full Data Acquisition
*AvioRace 2 Button Billet Stop/Start Switch
*Dynojet Ignition Module
*Dynojet Power Commander
*Shorai 1.5 lbs Lithium Battery
*Speedohealer v4
*XT Racing Potentiometer Sensor with SLS130 Quick Release Kit & Custom 54mm Fork Bracket
*YEC ECU
-Suspension-
*2006 Yamaha R1 Swingarm Powder Coated Matte Black
*17’ OZ Racing Cattiva Forged Magnesium Matte Black Front Wheel with Dunlop Superbike Slick N-Tec UK 120/70
*17’ OZ Racing Cattiva Forged Magnesium Matte Black Rear Wheel with Dunlop Superbike Slick N-Tec USA 190/55
*Ohlins FGRT 810 Forks with SBK Internals
*Ohlins YA-343 Rear Shock With Graves Spec Valving
*Ohlins SD-027 Steering Damper with Harris Performance Fork Damper Bracket
-Brakes-
*ATE Super Blue Racing Brake Fluid DOT 4
*BrakeTech Front 320mm x 6.5mm Axis/Iron SBK-Spec Full-Floating Narrow Band Rotors
*BrakeTech Rear AXIS 220mm x 5mm Full Floating Rotor
*Brembo Front Brake Reservoir Relocator Kit
*Brembo Front Clear Brake Reservoir Tubing
*Brembo CNC 108mm GP4-RR 32/36 Monoblock Front Calipers with Nickel Cadmium Finish
*Brembo HP Rear Caliper
*Ferodo SinterGrip XRAC Racing Brake Pads (with Array Cooling)
*Brembo (Model: x98.A7.C1) GP Billet LTD Race Radial Pump 19x18 Rossi/Hayden Front Brake Master Cylinder
*Galfer Rear Custom Superbike Brake Line
*HRC Rear Brake Reservoir Kit
*Spiegler Custom 3 Line Type 950 Fitting Brake Lines
*Spiegler Dry Brake Sockets with Banjo Fittings
*Spiegler Quick Disconnect Dry Brake Plugs
-Controls-
*Attack Performance Upper & Lower Triple Tree Clamps with Custom Ignition Bracket
*Brembo Clutch Half Lever
*Brembo HPK Clutch Cable Perch
*Brembo GP Master Cylinder Half Lever
*Brembo GP Remote Adjuster with Graves Motorsports Bracket
*Renthal Adjustable Clipons
*Sato Racing Adjustable Rearsets with GP Shift
-Body & Paint-
*3M Paint Protective Film by Elite Auto Films
*Catalyst Composites Race Bodywork
*CleverWolf Racing Carbon Rear Hugger
*Custom Painted “50th Anniversary of Grand Prix Racing in Red & White” by MotoGloss
*Decals by Ace Custom Graphics & Fatlace
*Graves Gloss Black Fairing Stay
*GTYR Carbon Exhaust Heat Shield
*Puig Clear Double Bubble Windscreen
-Accessories-
*Accosato Quick Release Gas Cap
*Driven Preload Gold Fork Adjustors
*Driven Hand Grips
*Gilles Chain Adjusters
*Gilles GP Lifts
*Graves Left Engine Crankcase Cover
*Graves Quick Release Fairing Stay Race Fit
*Graves Rear Brake Return Spring
*H20 Performance Custom Oversized Radiator Guard
*HRC Overflow Radiator Bottle with Brembo Clear Reservoir Tubing
*Intuitive Frame Sliders
*Moose .028 Safety Wires
*ProBolt Titanium Sump Oil Drain Plug Bolt
*ProBolt Titanium Rear Axle Nut
*ProBolt Titanium Swingarm Adjusters
*ProBolt Titanium Unsprung Race Bolt Kit with Predrilled Heads
*Racebolts Titanium Front & Rear Axles
*Racebolts ¼ Turn D-Ring Fasteners
*R&G Clutch and Shifter Sliders
*R&G Swingarm Sliders
*RhinoMoto Fork Sliders
*RhinoMoto Rear Axle Sliders
*Rizoma Oil Cap
*Rizoma Pro Guard System Hand/Lever Protectors
*StompGrip Clear Four Piece Tank Kit
*StompGrip Clear Tank Protector
*StompGrip Clear UniTankTop
*Woodcraft Left & Right Engine Case Covers
*Valter Moto AR50 Aluminum Pro Racing Rear Prong Paddock Stand
*Yoyodyne Rear Titanium Race Caliper Bolts with Predrilled Heads
ID:	475933   Click image for larger version
ID:	476039   Click image for larger version
Name:	SAN (48 of 48).jpg
ID:	476992   Click image for larger version
Name:	SAN (28 of 48).jpg
ID:	476993   Click image for larger version
Name:	SAN (24 of 48).jpg
Name:	SAN (6 of 48).jpg
ID:	476995   Click image for larger version
Name:	SAN (34 of 48).jpg
LiVe LiFe To ThE FuLlEsT
1OGR1 is offline   Reply With Quote
Old 10-30-2012, 04:53 PM   #2
Fvckin sick, dude. But you already knew that!
Old 10-30-2012, 04:53 PM   #3
lobsterhound
lobsterhound's Avatar
Bikes: 03 600rr, 02 r1
I was wondering if the owner was on the forum. Congrats on the feature! Nice to see a real bike in SSB to off set the ridiculously over air brushed crap they like to feature
Sig pic courtesy of Uncle Petrol "Guard against the impostures of pretended patriotism." -G. Washington
lobsterhound is offline   Reply With Quote
Old 10-30-2012, 04:57 PM   #4
Boyka
Now you see me, Now you don't
Boyka's Avatar
Bikes: 2009 Yamaha R1, 2008 Kawasaki ZX10R, 2008 Suzuki SV650s (Track Bike)
Bike looks great. Congratulations.
Boyka is offline   Reply With Quote
Old 10-30-2012, 05:29 PM   #5
fjorn
Bikes: '07 R1 (track only)
IIRC, Chris' bike (burn-z) was the first to be featured in SSB from the forum that wasn't stretched or drag inspired.
Congrats to the OP on the feature.
Old 10-30-2012, 05:58 PM   #6
polakw/aR1
Violence of action is key.....
polakw/aR1's Avatar
Bikes: Yami Blue 06 R1
Awesome...your ride is tits, its awesome that dudes like you and Chris not only own works of art but also thrash'em on the track and put those tastey bits to use. Congrats on the feature.
Sig by Petrol
Originally Posted by GEN Patton
A good plan violently executed now is better than a perfect plan executed next week.
Originally Posted by loose_vagina View Post
Haters everywhere
Take a look:
FS: 04-06 aftermarket and stock parts
http://www.r1-forum.com/forums/showthread.php?t=324694
polakw/aR1 is offline   Reply With Quote
Old 10-30-2012, 06:35 PM   #7
Meister37
The Lead Farmer
Meister37's Avatar
Damn! nice ride!
Necessity is the plea for every infringement of every human freedom, It is the argument of tyrants; It is the creed of slaves.
William Pitt 1783
Phantom Squadron #37
Meister37 is offline   Reply With Quote
Old 10-30-2012, 06:42 PM   #8
burn-z
burn-z's Avatar
I saw that last week when the issue came out. I figured I'd wait for you to post it up. Congrats Jovan. Your build is without a doubt one of my all time favorites and it just keeps getting better. I remember the guy that won this years SSB Yamaha build contest when he came here begging for votes (had a Honda VFR single sided swinger and not much else) and ended up getting banned because we didn't give him the feedback he was expecting. I told him his bike wasn't even in the same league as yours and he got all pissy.
Sig courtesy of Petrol Spice
Originally Posted by shari1ninja View Post
"Hi, my name is Chris and I'm a carbonfiberholic"
burn-z is offline   Reply With Quote
Old 10-30-2012, 06:49 PM   #9
desire68
My R1 thinks she's a Twin
desire68's Avatar
Bikes: 01R1 Champion Limited Edition #187(SOLD) 2012 R1 WGP 50th Anniversary No#0095
Very nice indeed!
Mike
Petrol Spice, You Da MAN!!!
WGP 50th Anniversary #95 Akrapovic carbon cans,Akrapovic Ti Y pipe,Rapid red Watsen's,ASV black leavers with gold adjusters,Driven gold preload adjusters,Rizoma track-77 turn signals, Puig fender eliminator,Puig DB screen,Driven black spools,Harris clear puzzle tank pad,Graves clutch kit, Driven 520 kit,Gilles Ti axle nut,Gilles TCA-GP chain adjusters,Driven sprocket nuts, Sato rearsets,GYTR no cut frame sliders,ECUnleashed tune
desire68 is offline   Reply With Quote
Old 10-30-2012, 08:47 PM   #10
SakiBomb
Herro!
SakiBomb's Avatar
Bikes: 05 R1
This should've been the TRUE winner of the SSB build-off. Great job brother again and congrats on the feature
I was thinking the same thing, but held my tongue when he came on here
SakiBomb is offline   Reply With Quote
Old 10-30-2012, 09:06 PM   #11
DouglasyzfR1
Winter Sucks!!!
DouglasyzfR1's Avatar
Bikes: 08 R1
Very well put together. Congrats on the article, nice to see a bike like yours get featured.
Why no half naked chick in the article next to the bike??? Guess this bike doesn't need anymore eye candy like most of the other ones.
<img src=http://www.r1-forum.com/forums/signaturepics/sigpic41650_4.gif border=0 alt= />
DouglasyzfR1 is online now   Reply With Quote
Old 10-30-2012, 09:18 PM   #12
AnonymousR1
Track addict!
AnonymousR1's Avatar
Bikes: 09 R1, 03 R1, 04 CRF-50, 06 R6(sold)
Beautiful bike. I would love to see more pics.
-Sig complements of Buddyluv-
AnonymousR1 is offline   Reply With Quote
Old 10-30-2012, 09:32 PM   #13
burn-z
burn-z's Avatar
Easy enough brutha...
http://www.r1-forum.com/forums/showt...302&highlight=
Old 10-30-2012, 10:25 PM   #14
1OGR1
Veteran
1OGR1's Avatar
Thanks for the compliment AnonymousR1 Here's the link to my updated R1 pics: http://www.r1-forum.com/forums/showthread.php?t=340890
Old 10-30-2012, 10:28 PM   #15
1OGR1
Veteran
1OGR1's Avatar
Thanks for the nice compliment CarbonAR1
Old 10-31-2012, 06:05 AM   #16
BlueDevil
1 Sick Individual
BlueDevil's Avatar
Bikes: 06 R6 50th / Raven Hybrid
Love to see the receipt history on that bike.. Yeouch.... Shes purdy
R6-Forum's June 2010 Ride of the Month!
Sig. courtesy of GIJoe007
Dion's Sponsorhouse
Sponsors:
Rief Resources Media/Rebellion Motorsports /
Lockhart Phillips / Factory Backing / GoPro Camera
BlueDevil is offline   Reply With Quote
Old 10-31-2012, 06:23 AM   #17
T.C.
Bourbon is my blood
T.C.'s Avatar
That's one awesome bike.
Sig by Uncle P.
T.C. is offline   Reply With Quote
Old 10-31-2012, 06:26 AM   #18
Trevmo
Ride it like you stole it!
Bikes: 2004 YZF-R1
Very nice indeed! I hope to have more aftermarket stuff on my ride. It's cool that you ride the bike like it is supposed to be ridden. Good job on such a nice bike!
Trevmo is offline   Reply With Quote
Old 10-31-2012, 06:34 AM   #19
mvera
mvera's Avatar
Bikes: 2012 R1 50th
Beautiful build 10GR1 ! ! Bike came out insane. Congrats on the Feature..
2012 50th Anniversary #18
Akrapovic / BMC / Flash-Tune / Watsen / Zero-Gravity / Rizoma / Agras / MotovationUSA / Brembo / Ohlins / ASV / Driven / LightTech / Braking / Spiegler / Carrozzeria
mvera is offline   Reply With Quote
Old 10-31-2012, 06:49 AM   #20
cyclepsycho7
R1, "A Superior Addiction"
cyclepsycho7's Avatar
Bikes: 06 R1
Well deserved, as sweet as they come, beautiful bike!!!!!!
Lucky 13 Squadron
cyclepsycho7 is offline   Reply With Quote
