» Site Navigation |
» Motorcycle Forums
| 07-08 R1 Mechanical Help Mechinical and Critical Issues for the 07-08 R1 |
11-02-2012, 05:49 AM
#1
07-08 intake valve issues
Hello everyone,
Did this issue seem to be a problem for every bike that was during these two years, or did it seem like it was only a "bad batch" for some of the bikes that were released?
For those that had there bikes repaired with this issue, did you get the exact same new valves put back in, or did yamaha find a solution to this and issue slightly different parts to correct this problem with bikes that were still in warantee? Have you continued to have this problem after you put new valves in the bike?
I am asking this because I am looking at an 07 with 9000 miles. I will inspect the vavle stem for wear by looking through intake. But, if everything seems to be ok, I am still curious if this problem may occur later down the road?
Most of the problems regarding this seem to be happening on bikes with a lot less miles than 9000. So Im guessing that if it hasnt had any problems with this issue thus far, I may be in the clear? Is this a reasonable assumption, suggesting that I am not looking at a bike that had "glitches"?
Thank You for all the help, I am new to the forums but have been riding yamaha bikes since 3rd grade
11-02-2012, 10:14 AM
#2
2008 R1 Raven
Bikes: 2008 YZF-R1 Raven
My 08 has 26,000 miles on it with no problems yet. :knock knock:
11-02-2012, 11:00 AM
#3
Bikes: 2008 R1
What was your production date?
2008 R1 Black - Gold AVS C5 Levers, Puig DB Wind Screen, EvoTech Sliders Kit, T-Rex Clutch slider, Stomp Tank Pads, LeoVince Ti Factory Evo II CF end caps, Arko Y-Pipe, R&G Fender Elim., Proton Signals, PZRacing GearTronic Zero , Q2 tires, Flash-Tune Interface
My Build Thread http://www.r1-forum.com/forums/showthread.php?t=336353
YouTube Page http://www.youtube.com/user/imstuner?feature=mhee
11-02-2012, 11:22 AM
#4
I do not know I am going to look at the bike tomorrow. What are the dates that I should be concerned about?
11-02-2012, 11:34 AM
#5
Bikes: 2008 R1
I think we should gather some production dates who had the issue. As far as I know there's no vin range.
11-02-2012, 01:23 PM
#6
What's a newb?
Bikes: 2007 R1
Interested as well. Just bought an 07 with 10,000 miles.
11-02-2012, 02:06 PM
#7
Bikes: 07 R1, flash-tune'd
Once my bike goes into storage I'll open her up and check the intake valves. 07 with 25,000km's.
-Jamie M.
11-02-2012, 05:08 PM
#8
R1 pilot
Bikes: 08 Candy Red R1
I think there are far more 07-08's that have not had an issue. You always here about the problems but you never really hear, "my bike has xxxx miles and its still going strong." With that said, my 08 has had no engine maintenance and is @ 17850 tonight.
I do believe there is an unusual amount of problems, but not quite as bad as some think.
11-02-2012, 07:20 PM
#9
My R1 tickles my balls!
Bikes: 2007 R1, 2000 R6
I have an 07 with around 31,600 and have had no issues. The only time I don't ride it is when it snows otherwise it has seen all condition. Plus I'm not gentle with it although I don't bounce it off the limiter.
11-03-2012, 08:31 AM
#10
blue blurrrr go zoom
Bikes: 07 r1
60k..valves look good for the most part...3 slightly leak on my rebuild currently in progress..i plan a whole new set to go in soon...
New member of
Tpm- white
Ridin' like tomorrow isnt promised
07 R1:
Blue puig windscreen, Two brothers slip ons, -1 +2 sprockets, Blue stealth rear sprocket, Blue EK chain, CNC cut R1 heel guards, Hot bodies flush mount turn signals, Blue axle blocks, Blue rear hugger, Puig chain guard, Blue R1 rims, R1 Progrips, shogun frame sliders, carbon fiber mirror block offs....
11-03-2012, 03:59 PM
#11
My R1 feeds me
Bikes: 07, silver bullet
13k, no troubles yet even tho some people say that the production date bikes 02/07 are the ones with the most likelihood of having that problem( my PY). Im still going to change them up in the spring out of precaution, better safe then sorry.
I love my bike too much to have this mint beauty have a valve break while I'm cruising around.....
11-03-2012, 04:17 PM
#12
kickin' at the darkness
Bikes: 2005 RAVEN R6, sold; PEARL WHITE 2009 YZF R1 ~ rip, CADMIUM YELLOW 2009 YZF-R1!
thats my thinking... i wouldnt mess with it... could be an issue...
you dont wanna ask for a tissue  .. just giter done!
'09 R1
weighs 420lbs, 160rwhp!
Dynojet PCV
Leo Vince EVOII sbk CF cans / tips
Leo Vince y-pipe [cat elim]
GYTR air filter
graves AIS block off plates
ECUnleashed w/ Custom Tune, 158rwhp {thanks Nels!}
SHORAI LFX18 Lithium-Iron LiFePO4
SHOGUN no-cut frame slider kit
GB RACING case covers
GYTR screen
tidy tail
Watsens
6000k HID
GYTR Comfort seat
RACETECH springs forks / shock
RACETECH Gold Valve, shock
OHLINs FORK PISTON KIT
Carbon Lorraine pads
HEL SS lines
11-05-2012, 10:48 AM
#13
Bikes: 07 r1
my 02/07 production date valves look pretty good w 60k...lots of carbon buildup but stems look good
New member of
Tpm- white
07 R1:
11-05-2012, 10:59 AM
#14
Did you check them all when they were fully open? How did you turn the engine so you could check them all?
-Jamie M.
11-05-2012, 02:11 PM
#15
Bikes: 07 r1
When I had the motor put I turned the crank by hand and looked at them
New member of
Tpm- white
07 R1:
11-05-2012, 02:13 PM
#16
What do you think the easiest way to do it with the engine in the bike?
-Jamie M.
11-05-2012, 02:28 PM
#17
Bikes: 2008 R1
Here's the link to the service manual
http://www.mediafire.com/?1zwrwzfyqsi
11-05-2012, 05:05 PM
#18
Bikes: 07 r1
Same procedure.. Tear bike down to motor turn motor by hand and look in each valve as u turn.. Pretty easy u could get to it in 30-45 min w min skill required...
New member of
Tpm- white
07 R1:
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
