Quick question.. : Yamaha R1 Forum
SportbikeTrackGearMotorcycle.com Classifieds!Motorcycle.comGraves Motorsports
Graves Motorsports
Old 11-02-2012, 08:31 AM   #1
Mad Matt
Mad Matt's Avatar
Bikes: R1
Quick question..
Would someone constantly opening the throttle without the keys in or engine started cause the engine to flood?????
Mad Matt is offline   Reply With Quote
Old 11-02-2012, 09:00 AM   #2
z064life
R1 Forum Star
z064life's Avatar
Bikes: 2010 R1, 2009 Roadstar Silverado, 2005 GS500F (wife's), PW50 (with training wheels), 2008 R6 (Sold)
on anything new with fly by wire....NO
Old 11-02-2012, 09:36 AM   #3
skunkworx
skunkworx's Avatar
Not even carb bikes there is no airflow thru the Venturi. The only exception would be if you had carb/carbs with an accelerator pump.
All threads lead to Frank...
skunkworx is offline   Reply With Quote
Old 11-02-2012, 10:30 AM   #4
Mad Matt
Mad Matt's Avatar
Bikes: R1
Thought not, thanks guys.....
Second question please..
After having my bike stolen it won't start, when i put the key in i notice none of the settings show up on the screen for example the traction control and mode settings have gone along with that little red light that has stopped flashing. I presume the kids that stole it have either cut something or pulled a wire out from somewhere although nothing seems out of place. Ive checked fuses under the seat and the engine does turn over it just won't start.
Now my question is this, when the shop plug in their computer will that immediately tell them what the problem is??? Or will they be spending time looking like i have for faulty wires???
Thanks guy's..
Old 11-02-2012, 11:28 AM   #5
skunkworx
skunkworx's Avatar
Double check the wires coming out of your ignition. Did they crash it?
Old 11-02-2012, 11:41 AM   #6
Mad Matt
Mad Matt's Avatar
Bikes: R1
No they didn't crash it, they never started it just pushed it away. We found it stashed in a wood on its side.....
All wires look good coming from the ignition...
Old 11-02-2012, 06:56 PM   #7
toysareforboys
toysareforboys's Avatar
Bikes: 07 R1, flash-tune'd
It's probably the immobilizer. Get your ECU flashed with flash-tune to disable it and see if that helps.
-Jamie M.
toysareforboys is online now   Reply With Quote
Old 11-05-2012, 11:09 AM   #8
2f4st
2f4st's Avatar
Bikes: 2009 R1 sold, 2008 R1, 2007 cbr1000rr
you're bike is brand new which is under warranty, i would fix the the damaged fairings bringing it back to as close to new as possible, and take it in the dealer, it's a brand new bike they'd have to fix it under warranty lol
2f4st is offline   Reply With Quote
Old 11-05-2012, 11:15 AM   #9
Mad Matt
Mad Matt's Avatar
Bikes: R1
You are correct however i spoke to the dealer about it being stolen and then booked it in, i asked if they would fix it and put it down to warranty but they said no as its classed as vandalism...
I should of given it a little thought before speaking to them...
She's gone now so im just waiting for the bad news....
Old 11-05-2012, 11:17 AM   #10
Mad Matt
Mad Matt's Avatar
Bikes: R1
-Jamie M.
I will be getting the ecu flashed but the thought that it doesn't have an immobiliser scares me...
Old 11-06-2012, 08:20 AM   #11
marider
Feel the speed attack!
marider's Avatar
Bikes: Modded R1'09 /ex:R1'07+2xR1'03+R6'03
Probably they messed up with wires so you should check that. Your immo light still blinks even if you deactivate the immo feature so everything looks like stock all the time.
marider
Longest distance between two curves... straight line
EU 09 R1:
3/4 c/f Akrapovic,F-T'd ECU,PCV+AT+LCD-200,Ohlins damper+FPK108+.95 springs,
Brembo RCS/w Hel&Braking SK rotors,Marchesini wheels,Graves block offs,Clutch Kit,Fabbri screen,GYTR sliders,gel seat+cowl,ASV C5 levers,Gilles VCR+Variobar,Gregg's Flushmount,GB Racing covers,clutch sliders,Motografix stickers,-1 fr sprocket,SpeedoDRD,CustomLED mod. Dyno:170.1 RWHP,77 Tq.
marider is offline   Reply With Quote
Old 11-06-2012, 08:53 AM   #12
toysareforboys
The number of bikes that the immobilizer prevented from being stolen: 0
Don't worry, if someone wants your bike, they'll get it, immobilizer or not. Make sure you have full coverage insurance. It's the only way to sleep good at night
-Jamie M.
