» Site Navigation |
» Motorcycle Forums
| 09-11 R1 Mechanical Help Mechinical and Critical Issues for the 09-11 R1 |
11-02-2012, 05:44 PM
#1
Bikes: 11 R1
engine power cuts with no throttle response
So today on my way home from work, my engine power basically cuts off and i get no throttle response. the check engine light came on and i can't remember if my engine turned off because i switched the bike off immediately and coasted to a stop. i turned the bike completely off and then switched the key back on and tried to start it and it came back on so i continued to ride home.
this didn't happen once but TWICE. luckily i was close to home so i was able to make it home. i checked the oil level glass so far and the oil looks normal and the bike felt good while i was able to ride it home.
I just recently installed gb racing case savers on both sides and i don't think you can go wrong anywhere in there besides tightening too much.
what do you guys think it can be?
my mods so far are the flashtune, yoshi 3/4 system, kn air filter. i'm scared...  :
11-02-2012, 06:16 PM
#2
My issue was loose battery terminals,
11-02-2012, 06:45 PM
#3
2005 NOLA R1
Bikes: 2005 Yamaha R1
check your grounds.
I had an issue with my 03 zx6r 636 back in 2010 where my bike cut out on me on the interstate. the bike would start back up after i cut the power off and restarted the bike. come to find out, one of my Throttle sensors on my throttle body was bad which would throw the code to be a bad ECU. changed out the whole throttle body assembly with new sensors, and no more issues.
11-02-2012, 06:55 PM
#4
Bikes: 07 R1, flash-tune'd
Do you have a power commander?
-Jamie M.
#5
Astronomer not Astrologer
Bikes: 09 R1, 78 CB750K8
You have flashed the bike...Check the ECU connectors. Make sure they are plugged in securely.
Phantom Squadron
#158
2009 Raven R1
Mods: Custom Fender Eliminator, Custom Extra Heavy Bar Ends, Custom Rear Brake Reservoir Relocation Bracket, Custom Clutch Sliders, Spiegler Rennsport SS Front Brake Lines, Spiegler SS Rear Brake Line, Harri's YZFR1 Sport Bike Grips, Zero Gravity Light Smoke Double Bubble Windscreen, M4 Y-Pipe, Vance and Hines CS One Exhaust, Shogun No-Cut Frame Sliders, Flash-Tune 3/4 Tune Re-Flash with QS, Ferodo ST HH Front Pads
Build Thread
Flash-Tune FAQ Thread
11-02-2012, 06:56 PM
#6
-Jamie M.
 ....People have had issues breaking the TPS wire...
Phantom Squadron
#158
2009 Raven R1
Build Thread
11-02-2012, 09:01 PM
#7
Bikes: 11 R1
just checked, they're tight
Originally Posted by Fr3nchy524
check your grounds.
i will. where are they again? lol
-Jamie M.
no sir i do not.
I just checked that as well and also made sure its plugged in extra securely.
thanks for the ideas so far people. i really appreciate it. anymore? i plan on reflashing it back to stock and riding it like that to see if the problem occurs again...
11-03-2012, 07:56 AM
#8
Bikes: 11 R1
So I reflashed the bike with the stock ecu pc map and it seems to be ok. I let it idle for up to 220 until the fan kicked on and then I rode it around the block so far with no problems. At least it's not some engine problem...
11-03-2012, 08:28 AM
#9
blue blurrrr go zoom
Bikes: 07 r1
yea but electrical can b worse...
New member of
Tpm- white
Ridin' like tomorrow isnt promised
07 R1:
Blue puig windscreen, Two brothers slip ons, -1 +2 sprockets, Blue stealth rear sprocket, Blue EK chain, CNC cut R1 heel guards, Hot bodies flush mount turn signals, Blue axle blocks, Blue rear hugger, Puig chain guard, Blue R1 rims, R1 Progrips, shogun frame sliders, carbon fiber mirror block offs....
11-12-2012, 04:53 PM
#10
Tin Foil Hat
Bikes: 2012 R1 Raven
Broke mine, and had that same issue on the 1/4 mile track. It died on me at about the 1/8th mile mark  . Just guessing, but I'm thinking this MIGHT have something to do with it.
Originally Posted by greenstreak9205
It's like kankles for your head!!
Your local HPT and EFI live tuner.
11-13-2012, 11:53 PM
#11
ghost
Bikes: 2012 R1
My bike did the same thing I think on my bike it is the ecu plug not all the pins are making contact when the bike vibrates
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
