» Site Navigation |
» Motorcycle Forums
11-03-2012, 01:51 PM
#1
Bikes: 2011 Raven R1
DJ quickshifter engagement question
I've installed a dynojet quickshifter today and when I test where it's engaging (with an ohm meter), it only does so after the shift is completed and I have to pull on it fairly hard. Is this normal for these? I'm hoping in a real world situation it works as needed. Guess I'll find out soon.
11-03-2012, 04:37 PM
#2
Astronomer not Astrologer
Bikes: 09 R1, 78 CB750K8
With the engine off or no load on the gears, it will not provide enough force to activate. When there is load on the gears, it basically prevents the shift forks from moving thus activating and unloading the gears and it will shift....It should work fine, because that is exactly what mine does...
Phantom Squadron
#158
2009 Raven R1
Mods: Custom Fender Eliminator, Custom Extra Heavy Bar Ends, Custom Rear Brake Reservoir Relocation Bracket, Custom Clutch Sliders, Spiegler Rennsport SS Front Brake Lines, Spiegler SS Rear Brake Line, Harri's YZFR1 Sport Bike Grips, Zero Gravity Light Smoke Double Bubble Windscreen, M4 Y-Pipe, Vance and Hines CS One Exhaust, Shogun No-Cut Frame Sliders, Flash-Tune 3/4 Tune Re-Flash with QS, Ferodo ST HH Front Pads
Build Thread
Flash-Tune FAQ Thread
11-03-2012, 05:09 PM
#3
Awesome. I suspected as much, but just wanted to be sure. My last quickshifter was a lot different. Thanks, Tad.
11-03-2012, 05:21 PM
#4
Phantom Squadron
#158
2009 Raven R1
Build Thread
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
