» Site Navigation |
» Motorcycle Forums
11-04-2012, 04:46 AM
#1
R1 08 PC V on dyno with sprocket less??
hey.
i was put my R1 on dyno with original sprocket front17, rear 47, all run perfectly but now i want change front sprocket from original 17 to 16 and i dont know if i must run dyno again??
is higher fuel consumption with one less front sprocket?
or the chain wear before with less gear?
sory about my writing.
11-04-2012, 05:04 AM
#2
It shouldn't affect your dyno tune one bit, but your mph/kph will be more off.
Sent from my EVO using Motorcycle.com
11-04-2012, 07:03 AM
#3
I RACE U LOSE
Mileage will definitely be worse, speedo will be off as well. Will not change the "tune" of the engine though.
'06 50th GYT-R CarbonSlipons,Akra Y Graves stacks,blockoffs,covers BMCair Bazzaz Zafm Zfi mapsw Vortex w/520ERV3 Shogun sliders Vortex rearsets Renthal med.comp Ballistic12cell Stompgrip CRG levers Galfer SBK fr&rr rotors ProboltTi  '12 50th WGP#145. Graves full Ti carbon ex,stacks,blockoffs BMCair Yosh case,oilfill,yokenut,axleblocks Renthal w/520ERV3 CRG RC2's Watsen's Shogun framesliders Renthal med.comp Ballistic8cell ProboltTi  Lucky 13th R1-013Squadron Member
11-04-2012, 07:14 AM
#4
thanks. So how much i will loose top speed and how worse will be mileage, 7-15mph?
11-04-2012, 07:21 AM
#5
MummyMan
Bikes: 1999 r1, 07 GSXR 1k
you can go to gearingcommander.com to figure your actual loss. If I had to guess you would lose around 10mph off your top speed. As for your speedo you can go here to figure out how much it's off and use the link in the product description to take you to the calculator.
https://www.motomummy.com/chain-kits...abs-speedodrd/
That speedodrd will also correct your speedometer and odometer if you don't want it off.
11-04-2012, 07:36 AM
#6
I RACE U LOSE
Stock gearing on an '08 is 17-45 , not 17-47. Going to 16-47 will reduce your top speed to roughly 165 from the stock 183. Mileage won't be too bad,but you will be shifting alot more. I prefer stock gearing, if not taller. (more top speed) 165 is too slow for a 1000 IMO.
11-04-2012, 07:40 AM
#7
i was wrong!!! 16-45 not 47!! this cant reduce much..
11-04-2012, 07:46 AM
#8
I RACE U LOSE
173 ,about a 10 mph loss. Not too bad,but more than I'm willing to give up.
11-04-2012, 07:51 AM
#9
i didnt know that reduce so much with one sprocket less...hm. **** im not shure now what to do  more torque or less top speed
11-04-2012, 07:54 AM
#10
I RACE U LOSE
You can always change it back,and they are only $25 or so.
11-04-2012, 12:47 PM
#11
The question is often to do go 183 mph?
11-04-2012, 08:28 PM
#12
MummyMan
With gearing on a 1000cc bike you can't really gain anything without losing something somewhere else. You're not really gaining anything, but just moving things around. The key though is to set up the gearing to what suits your riding style. If you like top speed more then anything then stick with stock. If 95% of the time you're under 150mph then most people would prefer more bottom end at the loss of say 10mph of their top end.
If you think -1 in the front is too much then you could do +2 in the rear which is about 2/3rd's the difference of doing a -1. Doing just a +1 in the rear you will barely even notice the difference over stock. In fact I would wager that if you take a stock bike and one with +1 that you can't even tell the difference. +2 in the rear is the smallest change I would recommend to where it's noticeable.
11-05-2012, 01:11 PM
#13
go go juice gonna make me win
Bikes: 2008 R1 Raven
agree with others about dyno, don't need it. disagree with top speed problem. i'm -1/+1 and still top out at about 170mph. that's plenty, not sure bike has enough power to get much higher, and if it does, there's not enough road here to do it anyway. i can tell u that the increase in acceleration will help you forget that top speed loss. unless your a top speed only person. on the track, on the road, anywhere you'll get much more joy and benefit from gearing. bike will be significantly quicker.
as for mileage, i'm guessing it's the same as a car. less work but more revs, slight negative outcome, but not as bad as people think. i've never gotten more than 30mpg outta my bike, before or after gearing. that's just cuz i of how i drive, not the gearing i have. if it's that important, sell the bike and put that into a gas account.
try going as fast as it'll go, with the stock gearing. see how high u can get it and what number is comfortable with u as far as being attainable.
2008 R1 Raven
PCIIIusb w/FlashTune|Termignoni CF Slipons|Attack Performance Rearsets|Akrapovic Y-Pipe|520 Conversion (-1/+1)|Hyperpro Damper|BlasterX|MRA Racing DB|Gilles Chain Adjuster|BMC Air Filter|Greggs Sprocket Cover|Graves Smog Plates|Speedohealer|GYTR Comfort Seat|Targa Solo Cowl|Tec-Spec Traction Pads|Passenger Pegs Powdercoated Black|Pazzo Shorties|Shogun Crash Kit|Spiegler SS Brake Lines|A&R Motorsports 6000k HID's|Flushmounts|Fender Eliminator|Acumen Gear Indicator
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
