» Site Navigation |
» Motorcycle Forums
11-04-2012, 12:05 PM
#1
The other side of the road!
Bikes: 07 R1, 99 R1, 06 R6R
smog block off problems
so after installing smog block offs on my 07 R1 i have a problem and wonder has anyone else had it...after the bike runs for a few minutes, the bike will blow this piece of gasket out.its where it appears to be a hole where the gasket was but its just pushed inside...oil does spray out...when it blows out it sounds like a big air purge like a compressor when its full....pshhhhhhhhhhhh....wtf..i will say it does start better and the bike is no longer a flame thrower!
What do you mean a R1 is only for the curves?
R1-016 Venom Squadron
11-04-2012, 12:45 PM
#2
I RACE U LOSE
The AIS system that is removed for the blockoffs uses air from the airbox, I would guess that too much blowby gases and air is not being removed from the crankcases and airbox, my '06 just started to leak (don't know where yet) after the last trackday I went to. It has over 50,000 on it , so it is likely the same problem as you're having. Might have to put the AIS system back on to remedy our problems (oil leak). When the throttle is closed, not much of the blowby gases and air are being removed (by the engine at idle) from the airbox, that normally would be removed through the AIS system.
'06 50th GYT-R CarbonSlipons,Akra Y Graves stacks,blockoffs,covers BMCair Bazzaz Zafm Zfi mapsw Vortex w/520ERV3 Shogun sliders Vortex rearsets Renthal med.comp Ballistic12cell Stompgrip CRG levers Galfer SBK fr&rr rotors ProboltTi  '12 50th WGP#145. Graves full Ti carbon ex,stacks,blockoffs BMCair Yosh case,oilfill,yokenut,axleblocks Renthal w/520ERV3 CRG RC2's Watsen's Shogun framesliders Renthal med.comp Ballistic8cell ProboltTi  Lucky 13th R1-013Squadron Member
11-04-2012, 02:15 PM
#3
Damn that sucks,at least my leak show its ugly head up front...but so many people run block offs without error I assume....instead of running the hose back into the motor I guess it could be routed to dump under motor...my bike starts quicker, and before the block offs it's hard to crank hot..
11-04-2012, 02:29 PM
#4
I'm so ready to give up on this R1..if only it wasn't so fast and sexy...
11-06-2012, 01:22 PM
#5
Are we of the few whom had this problem..someone help before I take block offs off...bike runs so well...could seal that gasket but I'm sure itll blow another one off...i guess some release is needed somewhere
cause when it purges the air it sounds like such a release...gonna make a video..
11-08-2012, 09:54 AM
#6
Could this just be valve cover gasket needs replacement??
11-08-2012, 09:57 AM
#7
para bellum
yes.
Brothers riding on...
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
11-08-2012, 04:35 PM
#8
Wow what a fun replacement job. Any probs after this and I think she'll be sold!
11-08-2012, 04:36 PM
#9
para bellum
why? it's only a gasket.
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
11-10-2012, 03:18 PM
#10
Anyone with higher compression running smog block offs..just for the hell of it we sealed the piece back in and it blew another one out wth...guess they'll be coming off...
11-11-2012, 08:59 AM
#11
It taste like burning
Bikes: 2010 Yamaha Yzf R1 Raven
damn man, that sucks. Hope ya get it all figured out. Smog block off plates helped my r1 a ton.
11-11-2012, 07:21 PM
#12
That's the problem. With the block offs my bike cranks perfect. With out them it's hard to crank when hot, which I see a lot of here. Bike does run a lot better with block offs as well..well there off now and i rode 5 miles to the gas station filled up and of course wouldn't crank. Had to wait a few mins...crankcase pressure is to high to run block offs, I'm just wondering why..gonna replace valve cover gasket and check valves..probably gonna sell it and get a 2004 zx10... Still have my 06R6R and 99 R1. Damn gonna miss her..
11-12-2012, 12:07 PM
#13
para bellum
There is something wrong with your engine breathing lines. Blockoffs are used on higher comp motors and this wouild not happen .
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
11-12-2012, 12:19 PM
#14
1 beer short of a six pack
Bikes: 2004 R1 Lava red
I'm with Roo on this.
You haven't accidentally plugged the crank case breather hose have you? or at least kinked it?
For pressure to build up like that you must have a blockage somewhere.
Modded Termi slipons, Micron decat pipe, A&R smog plates, Krankvent, K&N airfilter, PC111 and custom map, Gipro gear indicator, Speedo healer V4, Hel brake lines, Tygon resevoir tubing, Titax stubbys, 35w 6000K HID's, PIAA Highs, Led running lights, Blaster x tail light, Afam 520, -1 +1 renthal sprockets. PP Tuning rearsets,K-tech front + rear springs, Carbon Hugger, exhaust shields, tank sides, front mudguard, sprocket cover, Puig light smoke screen. Watsen design indys.
11-12-2012, 04:43 PM
#15
So a fix would be what...bike has 2 batteries but without block offs is hard to crank..
11-12-2012, 04:54 PM
#16
para bellum
Probably having a hard time cranking because of too much internal pressure. Search for my krankvent thread and see if your crankcase breather tube is clear.
Bandrews 10/11
Dieyoung69 11/10
Vman1300 3/09
Gawarrior 6/08
Elviswarrior 6/07
Crazyclimbr 3/07
K_flexxx 6/06
11-14-2012, 03:43 AM
#17
Not doubting you,trying to understand,but if it was too much pressure, why does it crank better with block offs on?
11-22-2012, 08:21 AM
#18
Bikes: Yamaha R-1
This is not a problem caused by smog block offs. More than likely durning your install and reassembly you've blocked the crank case breather.
www.gravesport.com
11-22-2012, 09:16 AM
#19
LIVE EVERY MOMENT!
Bikes: 2010 r1
maybe try this.
11-22-2012, 10:21 AM
#20
Originally Posted by WestSide_'10R1
maybe try this.
The good old Krankvent.
I have one of those, but without the filter on top.
I don't like the idea of pumping hot oily air from the crankcases into the airbox.
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
