7075 Billet Axles : Yamaha R1 Forum
Graves Motorsports
Old 11-04-2012, 03:52 PM   #1
4yamahas
Lifetime Premium Member
4yamahas's Avatar
Bikes: 01R6 , 06R6 , 08 Zuma Big Bore 2smoke
7075 Billet Axles
Just installed the front axle . Stock weighed 384 grams and this one is 144 grams . Over a half pound weight savings .
Rear axle will be here by the weekend and am having a swingarm pivot made also .
I wont post pics since you can see them at Ti64.co.uk/blog
Pete also made an oill cooler bolt that saves close to 1/4 lb as well as some long Ti motor through frame mount bolts .
4yamahas is offline   Reply With Quote
Old 11-04-2012, 05:36 PM   #2
Benocehcap
Sonic Boom!
Benocehcap's Avatar
Bikes: 2001 Yamaha R1
I dont mind...Still wanna see pix!
Benocehcap is offline   Reply With Quote
Old 11-04-2012, 06:16 PM   #3
fjorn
Bikes: '07 R1 (track only)
Nice. Almost afraid to ask how much.
Old 11-05-2012, 06:29 AM   #4
617mike9c1
Life is too short
617mike9c1's Avatar
Bikes: '08 R1 Blue + '03 R1 Silver + 02 ZRX12 Red
Nice stuff! Here comes another long winter of me stockpiling mods (just to sell to Frank later). LOL
617mike9c1 is offline   Reply With Quote
Old 11-16-2012, 03:20 PM   #5
4yamahas
4yamahas's Avatar
Here is a picture of front and rear with aluminum nut .
Old 11-16-2012, 03:26 PM   #6
4yamahas
4yamahas's Avatar
Sorry , email reduced the picture a lot . They are each over 1/2 lb lees than stock . Swinger pivot same . Oil cooler bolt 1/4 lb lighter .
Old 11-16-2012, 04:15 PM   #7
SPanega SS
The "Wog" and only
SPanega SS's Avatar
Bikes: Less than I want
I'm sad, staring at a hunk of aluminium...Drooling.
Sig courtesy of my brotha from down unda PetrolSpice
SPanega SS is offline   Reply With Quote
Old 11-16-2012, 04:23 PM   #8
AKDMA
Bikes: 2011 Raven R1
What is the pricing like?
AKDMA is offline   Reply With Quote
Old 11-17-2012, 05:24 AM   #9
Death R1
99 R1
Death R1's Avatar
Bikes: 99 R1
**subscribe**
Tuned by Bugaj
"In pursuit of more speed with the same power"
my "back from the dead" thread:
http://www.r1-forum.com/forums/showthread.php?t=263176
99 R1 parts for sale :
http://www.r1-forum.com/forums/showthread.php?t=307491
Death R1 is offline   Reply With Quote
Old 11-17-2012, 06:02 AM   #10
Benocehcap
Sonic Boom!
Benocehcap's Avatar
Thumbs up
Lets fix this thead to its awesomeness!
Website link:
http://www.ti64.co.uk/
Person to contact:
pete lidster
Email for Q & A:
ti60four@googlemail.com
Product list:
http://www.ti64.co.uk/yamaha-r1-catalog/
product info:
7075 spindles cost:
Bare front £125, bolt £17.50, anodised £135, £20
Bare rear £160, nut £20, anodised £170, £25
Bare swinging arm £145, nut £20, anodised £155, £25
I don't reccomend anodising the wheel spindles but it is an option you can have, whereas i do suggest the swinging arm spindle is anodised to protect it from corrosion. The anodising process can stress the metal which isn't so much an issue for the swinging arm. 7075 has relatively poor corrosion resistance which is the only practical reason to anodose it, so unanodised you will need to take them out now and again to clean, inspect and regrease them.
Grade 5 Titanium Cost:
Front £150, bolt £30
Rear £280, nut £30
Swinging arm £250, nut £30
Titanium HAS to be lubricated with molybdenum disulphide grease, it is more corrosion resistant than stainless steel but it has a tendency to 'grab' on the threads if it isn't well greased up with molybdenum. Once fitted it needs no further care other than an occasional clean and relube just as you would the OEM parts
Old 11-17-2012, 09:40 AM   #11
bryan niles
performance first
bryan niles's Avatar
Bikes: 2005 Raven, 2010 Raven
Talking
subscribed!!!
PERFORMANCE- Sato full Titanium exhaust with MOTO GP carbon fiber Titanium cans- Gold Sato rearsets- Bmc race filter - Factory pro velocity stacks- Pc3USB- Powercommander Ignition module- secondary throttle plates removed- Brembo 19x18 radial master cylinder- DID 520 ERV3 conversion kit- RRP rear sprocket- Attack Performance magnesium triple clamps- Braking wave rear rotor- JG1 custom map- Gilles chain adjusters and lifters- Galfer stainless steel black front & rear brake line- Scotts oil filter-graves fibers-yec clutch springs-Galfer Superbike Wave Rotors-Ohlins damper-Active quick turn throttle billet black-Over adjustable racing linkage-Krankvent-Yec fuel regulator!
COSMETIC- Pro bolt and Yoyodyne titanium bolts and nuts on entire bike- Puig double bubble screen- Graves smog plates- Greggs customs black sprocket cover- Greggs customs black mirror block plates- Greggs customs black license plate bracket- Greggs Satin black fairing plugs- Factory yamaha billet engine case cover- Woodcraft case covers- CRG silver gp perch clutch lever- Gytr clutch guard- Speedohealer- Shogun clutch slider- Shogun black bar ends- Shogun black swingarm sliders- Motowheels red oil cap and drain plug- Rizoma black anodized front and rear brake reservoir- Agras red front axle sliders-Yoyodyne frame sliders-Samco red coolant hose kit-Evolution Composites Carbon Fiber tank cover and panels!
more to come!
bryan niles is offline   Reply With Quote
Old 11-17-2012, 10:25 AM   #12
4yamahas
4yamahas's Avatar
I was running out of light weight mods for my 01R6 . Seemed like I had hit a brick wall at 320lbs . Now bike is well on its way to weighing 315 lbs. The unsprung mods can really be felt with grip over rough pavement .
If you look at the blog section on TI64.co.uk there are pictures of parts being made etc. He doesnt list everything he makes . Pretty much any odd bolt that ProBolt does not have , he can make out of Ti or 7075 .
Old 02-08-2013, 08:57 PM   #13
Death R1
99 R1
Death R1's Avatar
Bikes: 99 R1
FYI -
check out my Back from the dead thread for more pics ..
took about 1.5 months
Tuned by Bugaj
