Slow/Quick Starting? Battery/Gas? : Yamaha R1 Forum
Old 11-04-2012, 05:37 PM   #1
Puck Fu
Puck Fu's Avatar
If I have around 80 miles or higher on the trip odometer then I sometimes have a slow start, it's possible that the weather/temperature could have some involvement in this as well. I recently had trouble starting my 2010 R1, it took me a second try to get it to start. I always wait for that 'suction' sound or whatever that occurs after you put the key in and turn it to ON. Usually takes like 3 seconds. (I was told by a friend who delivered my bike when I bought it brand new to do this)
I seem to have rather quick starts, like 1-3 seconds when the Tanks is full of gas or I have less than 80 miles on my trip odometer (I reset after each fill-up, since I ran out of gas once!)
I am not sure about what the issue is?
Starting should be quick right? Like 1 -3 seconds?
If I ride the bike to and from work everyday and it's 5 miles, of which I can get most of it done on the highway at high speed am I doing harm to the bike? (I started on a ninja 250 and was told that I should ride 15 minutes at least once a week and at least 15 minutes if bringing it out of storage and then putting it back in)
Is the battery getting charged? Do I need to ride it longer?
Is there some sort of idiot's guide to the R1 as every bike is different and the carbed ninja 250 is totally a world apart from an R1.
I'm taking the slow starts as a sign that I am probably doing something wrong riding the bike, but I don't know...
any advice?
Thanks in advance
http://is200.imagesocket.com/images/2011/06/15/r1signaturenofearjlocp.jpg
I decided that living in fear of dying on a motorcycle isn't living, now at least if I die I had fun beforehand!
Puck Fu is offline   Reply With Quote
Old 11-11-2012, 08:52 AM   #2
Monster R1
It taste like burning
Bikes: 2010 Yamaha Yzf R1 Raven
i have an '10 and have been wondering the same thing. Some times it will start right up, others, it will take a second. Maybe it has to do with the battery and the cold cranking amps?
Monster R1 is offline   Reply With Quote
Old 11-11-2012, 09:38 AM   #3
Puck Fu
Puck Fu's Avatar
Mine is a 2010 also, I notice that it seems to happen when the temperature outside is around 50 or lower... not sure if it's weather related or not... but it may be and it may just be the fuel injection is correcting the air/fuel mix or something... I am not sure
I have done some researching and I guess it's not good to hold the starter on for 5 seconds... try for 2-3 seconds max, wait a few seconds and try again...
I'm probably going to install a quick connect for a battery tender and start plugging it in to the tender all the time though.
Old 11-11-2012, 10:22 AM   #4
quick kurt
I RACE U LOSE
quick kurt's Avatar
Most likely the sh!t ethanol in our fuels, try turning key on then off a few times to cycle the fuel injection and fuelpump. I use Startron in my fuel and my '12 always fires right up, no extended cranking or trying to start, it just starts.
'06 50th GYT-R CarbonSlipons,Akra Y Graves stacks,blockoffs,covers BMCair Bazzaz Zafm Zfi mapsw Vortex w/520ERV3 Shogun sliders Vortex rearsets Renthal med.comp Ballistic12cell Stompgrip CRG levers Galfer SBK fr&rr rotors ProboltTi'12 50th WGP#145. Graves full Ti carbon ex,stacks,blockoffs BMCair Yosh case,oilfill,yokenut,axleblocks Renthal w/520ERV3 CRG RC2's Watsen's Shogun framesliders Renthal med.comp Ballistic8cell ProboltTi Lucky 13th R1-013Squadron Member
quick kurt is offline   Reply With Quote
Old 11-11-2012, 01:41 PM   #5
rocalotopus
arrivederci
rocalotopus's Avatar
so you ride the bike for like five minutes ten times a week? poor motorcycle.
Originally Posted by NSDQ View Post
I would prefer face-to-face discussions with a surplus of Belgian beer, and have chosen self-restraint over posting "I AGREE WITH ME" again and again.
Originally Posted by courier11sec
STG always makes me wonder if I am the only sportbike guy that doesn't split his time evenly between gnc, Gold's Gym, the small shirt store and youtube.
you only funky as your last cut.
rocalotopus is offline   Reply With Quote
Old 11-11-2012, 01:42 PM   #6
Saphexus
You don't impress me.
Saphexus's Avatar
Bikes: 2011 Raven
My '11 does the same thing when it's cold (yeah, it gets down there in SoCal) so maybe that's it. In the summer heat, fires right up.
THEOS DRACONIS
Nobody said life was easy. Dig your claws into the bedrock, turn against the hurricane and STAND.
Saphexus is offline   Reply With Quote
Old 11-11-2012, 02:03 PM   #7
Puck Fu
Puck Fu's Avatar
Well if I am busy and it rains on the weekend then yeah, I do a lot of short rides.. I try to ride around longer at least once a week though if I am not riding long... heard it's better on the spark plugs for the 'ninja 250'... not sure it matters on an R1... much larger displacement....
dunno.. I'm not an expert on that subject.. not even really an amateur or better lol....
Old 11-14-2012, 01:29 PM   #8
Racer Dude
Racer Dude's Avatar
Bikes: 00 R1
What up Roco
I agree, anything less than 5 miles is considered "severe service", although I think it prolly takes him a little more than 5 minutes to go 5 miles.
Every time you start an engine, water condenses inside the crankcase. If you drive/ride less than 5 miles, you are NOT getting the oil temperature up to normal, optimal operating temperature. If you don't get the oil temp, and the combustion chamber temps up to the optimal temperature, you don't burn the water out of your crankcase, and you don't burn the carbon deposits out of the combustion chamber. If you do this everyday, you will have what is known as "sludge" inside of your engine, although, I would think quite a few bikes will get wrecked before the sludge becomes a problem.
Try to take the long way to work if work is less than 5 miles from home, or get a beater car, and just ride once in a while.
Bogie is the man, and I should learn not to mess with him
Racer Dude is online now   Reply With Quote
Old 11-14-2012, 02:33 PM   #9
Puck Fu
Puck Fu's Avatar
Originally Posted by Racer Dude View Post
What up Roco
Thanks for the VERY GOOD ADVICE... my next question is how would you know if the OIL gets up to TEMP? I mean I try to take the ride slow if the Temp gauge says LO and up to about 140-160.. and not 'WOT' until 160+
I'm guessing that I should ride longer during the winter when it's 30-60 degrees outside...and warm the bike up longer before taking off at all?
I did have plugged carbs on my 250 as well as fouled spark plugs etc and talked with the mechanic about why I had this problem in my first failed spring startup! Didn't have that problem again as I read the ninja 250 wiki guide. I read the service manual for my R1 at least 3 times, but it doesn't really mention a lot of things that I probably should know...not sure what a good source of info is besides helpful users on this forum!
Old 11-14-2012, 09:53 PM   #10
Racer Dude
Racer Dude's Avatar
Bikes: 00 R1
Unless you have a oil temp gauge, you won't know what the exact oil temp is, but if you go on a spirited ride for 30-40 minutes, it's a safe bet that the engine, including the oil temp, are up to optimal temperature.
Old 11-14-2012, 11:56 PM   #11
Saphexus
Saphexus's Avatar
Bikes: 2011 Raven
I'm no expert, but wouldn't starting his bike up for 5 min or so before he took off help out? Maybe rev it up some every now and then? That's what I do when it hits anything under 60 here.
THEOS DRACONIS
Old 11-15-2012, 03:46 AM   #12
Puck Fu
Puck Fu's Avatar
Well when it's 85-115 degrees out I just start it and let it run a minute to get oil up in the engine and take it slow until about 160 degrees on the bike. I tend to warm it up longer when it's 50 or lower, the manual says to not ride it hard when it says LO... so I take it real easy.... no 0-80mph in 4-5 seconds. I am still looking for a remote starter alarm system so I can warm it up more without having to stand around and wait for it. But yeah I don't think letting the bike warm up more hurts it but running the bike is better overall I think especially for charging the battery as well.
Old 11-15-2012, 08:29 AM   #13
kickarsmann
kickarsmann's Avatar
Bikes: Yamaha R1 2010 Raven
I have the same symptoms on my 2010 as well. Summer 70+ first crank it starts. Fall/Winter 50 degrees or lower, it takes it time. If it starts normal in the summer but slow in the winter, is it still the starter magnet?
kickarsmann is offline   Reply With Quote
