condensation in lights : Yamaha R1 Forum
Old 11-06-2012, 06:55 AM   #1
silvr002001
Recently I noticed after a ride, that both my headlights are accumulation condensation in the corners. I hadnt taken the bike out for a decent amount of time in a few weeks. Rode for about an hour and there was a little condenstation in both headlights. I pulled out the bulbs and let it dry. Then I took out the bike yesterday for a few hours. Same thing in both corners of the headlights. No moisture had touched the bike since they had previously dried out. It seems weird that 2 headlight seals would go bad together. I was thinking of putting in angel eyes so I would have to re seal the lights anyway. Anyone else had both headlights start leaking together?
silvr002001 is offline   Reply With Quote
Old 11-06-2012, 07:05 AM   #2
KMac
SuperModerateur
KMac's Avatar
Bikes: 1980 Huffy Santa Fe
sounds like the headlight fluid is leaking. That's a dealer fix.
KMac is offline   Reply With Quote
Old 11-06-2012, 07:34 AM   #3
TheBigO
TheBigO's Avatar
Bikes: 2006 R1
Headlight fluid? Wtf... no no no its blinker fluid. Duh
Sent from my DROIDX
TheBigO is online now   Reply With Quote
Old 11-06-2012, 07:41 AM   #4
z064life
R1 Forum Star
z064life's Avatar
Sent from my DROIDX
Exactly why it's a dealer fix. If you aren't careful, you'll end up fixing the wrong one...what a waste of money...and the tools to do the job
Old 11-06-2012, 07:43 AM   #5
silvr002001
the thing that sucks is I just changed the fluid, Both of them. Bought a 55 gal drum of it for a buck a gallon. It was tough to change, I burned myself on the front differential pretty bad, could barely get it back into 4 wheel drive after that. So I guess no one has had both headlight seals go bad together.
Old 11-06-2012, 08:00 AM   #6
KMac
SuperModerateur
KMac's Avatar
That's nothing.............you know how much a bucket of prop wash costs? You don't want to spill a drop of that stuff.
Old 11-06-2012, 08:31 AM   #7
silvr002001
Right!.. Well i'm leaving for afghanistan in like 2 weeks so its gonna have to wait anyway, I just didnt know if this was common or not. Thanks for all the help though
Old 11-06-2012, 10:02 AM   #8
Badshot
What's a newb?
Badshot's Avatar
Bikes: 2007 R1
Mine does it sometimes. That's a lot of heat generated by the bulbs especially if you have the highs running whole time. If its just in the corners it's not a big deal but if your whole lens is getting fogged up then you have an issue id say.
Badshot is offline   Reply With Quote
Old 11-06-2012, 12:44 PM   #9
Blue Streak
I've fallen and I can't get up
Blue Streak's Avatar
Bikes: 2000 Yamaha R1
have you checked all the sockets at the back and made sure the rubber seals are good and that they are screwed in tight?
Blue Streak is offline   Reply With Quote
Old 11-06-2012, 02:31 PM   #10
silvr002001
Yes its just the corners where the lights come together from what I can tell. Im not super worried about it at this time, I was just wondering if anyone else had this happen. I just double checked to make sure the rubber seals are on the back also.
Old 11-09-2012, 02:30 AM   #11
Jacobien
[ Premium Member ]
Jacobien's Avatar
Bikes: 07
Ah man, I had the same issue with my previous bike - FZ6. The only way I finally fixed it was to buy a whole new headlight. I tried everything: Hairdryer, heat from a light, compressed air, shouting at it and I even left a heater on it overnight.
Any moisture that gets in, stays in.
If you do get a new one, check that it seals properly.
Something else you might consider, is just living with it...
Keep it real...
______________________________________________
Jacobien is offline   Reply With Quote
Old 04-03-2013, 09:07 AM   #12
Detrich
2012 Yamaha YZF-R1 Blue
Detrich's Avatar
Bikes: 2012 YZF-R1 Team Yamaha Blue
Just picked up my 2012 this past Saturday, and both my lenses fogged up after the 70 mile ride home. Weird. Both cleared the next day. I did ride with my high beams on the entire time.
Is there a Yamaha TSB (Technical Service Bulletin) for this issue? If so, does anyone have the number, a copy, or a link to it? Thanks in advance...
I will have the dealer check it when I go in for 600 mile service I guess. Brand new bike, so I'm a bit perplexed too. And, I'm excited to join the Yamaha liter bike club finally.
:headscratch:
2012 Yamaha YZF-R1 - Blue [3.30.2013] - GYTR CF Heel Trim, ProGrip CF Tank Pad, Shogun NC Crash Kit, Yamaha White Seat Cowl, Yamaha 2011 Fairings
2010 Yamaha YZF-R6 - Blue [4.09.2011] - GYTR CF Heel Trim, ProGrip CF Tank Pad, Shogun NC Crash Kit, Yamaha White Seat Cowl, GPR v4 Steering Damper
2009 Yamaha FZ6R - Blue [1.23.2010 - 3.10.2012 Sold] - ProGrip CF Tank Pad, Yamaha Blue Seat Cowl, TechSpec SS Tank Grips, Intuitive Racing NC Frame Sliders
View My Virtual Garage
Detrich is offline   Reply With Quote
Old 04-05-2013, 12:21 PM   #13
Detrich
Detrich's Avatar
Update: rode around a bit last night but -without- the high beams on. And, lo & behold- no condensation in the headlights at all.
So, I'm thinking the condensation is being caused by running the high beams continuously then? That is so weird...
:headscratch:
Sent from Motorcycle.com App
Old 04-05-2013, 01:07 PM   #14
Racer Dude
Racer Dude's Avatar
Bikes: 00 R1
:headscratch:
Racer Dude is offline   Reply With Quote
Old 04-05-2013, 03:27 PM   #15
ebags
mmmm gold bits
ebags's Avatar
Bikes: 5VY
Heat up the gooey seals with a hairdryer, pull the two halves apart and smudge to goo back into areas where its lacking heat up again and re-seal pushing them tightly togeather while they cool.
"Adding power makes you faster on the straights. Subtracting weight makes you faster everywhere."
Colin Chapman
Uncle P. Originals
Originally Posted by burn-z View Post
I'm pretty certain you don't have anything from Magnetti Marelli.
Originally Posted by WayTooFastWhyty View Post
I have a magnetti marelli battery thank you
ebags is online now   Reply With Quote
Old 04-05-2013, 04:52 PM   #16
Detrich
Detrich's Avatar
Wouldn't it be easier just to seal the chamber with silicone?
Old 04-05-2013, 05:50 PM   #17
Redgecko
buckfarack fan club
Redgecko's Avatar
Bikes: 06 R1
You can't seal the headlamps, there are 2 big holes in the back where the bulbs go
Redgecko is offline   Reply With Quote
Old 04-05-2013, 10:46 PM   #18
Racer Dude
Racer Dude's Avatar
Bikes: 00 R1
A hairdryer may not be able to heat up the entire unit enough to pull the halves apart. I have known peeps to put headlamp assembly's in a household oven preheated to 350 degree's for just long enough to be able to pull the halves apart, usually a few minutes.
Old 04-05-2013, 10:50 PM   #19
Racer Dude
Racer Dude's Avatar
Bikes: 00 R1
True that
Although, if you're in a real humid area, I think you can squeeze water out of the air, and into the assembly via the front, though an unsealed portion
Old 04-06-2013, 08:31 PM   #20
Detrich
Detrich's Avatar
I think it's weird that they only fog up when running high beams tho. Riding around in the damp/ cold night air with regular beams they didn't fog up at all.
What is different with the high beams that might cause this?
