» Site Navigation |
» Motorcycle Forums
11-08-2012, 12:27 PM
#1
*Insert Witty Phrase Here*
Bikes: 09 R1(project), 07 zx6r(sold), 05 R6(sold), 03 R1(sold)
Smog Block Off Plates. Use Them Or Don't Use Them...?
So I am building my 09 R1 up, and I've seen a lottt of talk about the smog block off plates. I personally will probably throw a set of Driven plates on mine for future dyno tuning along with the reduction of any backfiring.
So who uses them? Who doesn't? Why or why not?
11-08-2012, 12:37 PM
#2
It's just like a video game.
Bikes: 2011 R1
I use them, I bought some reasonably priced ones off fleabay, they stopped all the back firing and popping (that wasn’t too bad with baffles out but always sounded worse when you needed it quiet) this enabled me to sneak past the police quietly that I couldn’t do with the pump on! It didn’t feel any faster or run any different but must have lost a pound in weight off the bike
11-08-2012, 03:22 PM
#3
kickin' at the darkness
Bikes: 2005 RAVEN R6, sold; PEARL WHITE 2009 YZF R1 ~ rip, CADMIUM YELLOW 2009 YZF-R1!
yeh i've been runnin' 'em Graves do-hickeys since i got rid of my cats..
running 3/4 leo vince with reflash.. now happier than ever... only get
slight gurbly pop pops when entering a corner under engine breaking...
before the re-flash n' AIS delete, it would backfire like a sumbiatch...
friends could barely ride behind me as it would try n' rip their heads off
every time i used compression... hahaha...
they're so cheap i dont see why anybody would opt not to run 'em..
takes a little mechanical know how to replace'em but its par for the course.. may as well learn
to do yer own spark plugs.. its only 1 more step to get at 'em...
'09 R1
weighs 420lbs, 160rwhp!
Dynojet PCV
Leo Vince EVOII sbk CF cans / tips
Leo Vince y-pipe [cat elim]
GYTR air filter
graves AIS block off plates
ECUnleashed w/ Custom Tune, 158rwhp {thanks Nels!}
SHORAI LFX18 Lithium-Iron LiFePO4
SHOGUN no-cut frame slider kit
GB RACING case covers
GYTR screen
tidy tail
Watsens
6000k HID
GYTR Comfort seat
RACETECH springs forks / shock
RACETECH Gold Valve, shock
OHLINs FORK PISTON KIT
Carbon Lorraine pads
HEL SS lines
11-08-2012, 03:31 PM
#4
R1der
Bikes: 2006 R1 Blue
I'm running grave block offs on my 06 and it made a huge difference in back firing popping.
11-25-2012, 06:57 PM
#5
Death's Handshake
Bikes: They're just bikes, you've seen 'em.
I like the popping.
Mind you, they are just subtle little pops, and not backfires like you would expect from a beater.
Ed - Klingon women are HOT! (A Trekker for life)
CG Artist and Sci-Fi Nerd
Manic-Depressive and my head hurts.
11-25-2012, 08:03 PM
#6
I <3 My Honda
Bikes: 2010 R1 Rossi Special
Do I need the plates or can I just disable the system with the flash?
11-25-2012, 10:03 PM
#7
Originally Posted by Minacious
I like the popping.
yeah i did too, when i was like 15
get the plates... like i said you may as well learn to do your own spark plugs while you're in there...
'09 R1
Dynojet PCV
GYTR air filter
GYTR screen
tidy tail
Watsens
6000k HID
GYTR Comfort seat
HEL SS lines
11-26-2012, 02:15 AM
#8
Death's Handshake
Well, I haven't been 15 in a very long time. Hell, I guess that's why a lot of kids like exotics, since quite a few of them do it to.
I actually think we're talking about 2 different events. My last R1, which had plates, among many other mods, still made the sound that I am referring to.
11-26-2012, 02:57 AM
#9
Extended Member
Bikes: 2008 Yamaha R1
I like the popping.
+1
Dave
11-26-2012, 09:21 AM
#10
B Group ALL-STAR ¯\_(ツ)_/¯
Bikes: 2012 Yamaha R1 Raven - 2006 Yamaha R1 50th Anniversary (sold)
You can do either, however Flash-Tune recommends you eventually remove the AIS and replace with plates.
You will still get some popping, but not as much...
11-26-2012, 09:35 AM
#11
Bikes: 2009 R1
The way I see it, it's an environmental thing. If you already took out the cat, then it's useless and not helping much anyway. Might as well get rid of the extra clutter.
I far prefer the clean sound as well. Bike only pops on very hard engine breaking now. Imo, excessive popping just sounds like an out of tune bike.
2009 Yamaha YZF-R1
-Graves Cat Eliminator Carbon/Ti Exhaust, Frame/Clutch Sliders, Smog Block Off Plates
-Flash-Tune reflashed ECU,Dynojet PCV
-Fender Eliminator w/ LED signals, LP flushmounts, OEM Seat Cowl
-Ballistic Evo2 8-cell battery
-ASV C5 Shorty Brake/Clutch Levers (blue), Renthal Dual Compound Grips
-Zero Gravity Corsa (light smoke)
-Goodridge SS brake lines
-Driven 520 conversion 16/45, RK GXW Chain, Probolt Sprocket Nuts
-GBRacing Case Covers
11-26-2012, 09:38 AM
#12
ROWDY
Bikes: 2009 Yamaha R1
I don't run them, After the flash I get a pop now and then, like the M1 does on the track, usually it is during a shift with the HR Quick shifter.
ROWDY
11-26-2012, 09:49 AM
#13
Yamaha blue, in any color.
Bikes: 91 FZR1000, 04 YZF-R1, 05 V-Max 0098/2000, 04 Warrior, 05 R6
If you want the tuner to be able to accurately read your A/F, get the plates. The AIS injects air into the exhaust which will make tuning a little more challenging.
The lack of decel pops is a plus.
Signature by SpidermanSS. Thanks Shane!
Dan
R1-016 'Venom' Squadron Member
CCS #598
91 FZR 1000
04 YZF-R1
05 YZF-R6 (track bike)
05 Vmax 20th Anniversary 98 of 2000
04 Road Star Warrior
11-26-2012, 10:54 AM
#14
Death's Handshake
Good point.
11-26-2012, 03:20 PM
#15
Hooligan
Bikes: R1 2004
Block the pipe it's cheaper... Once there blocked they flame :0)
11-28-2012, 09:11 PM
#16
Bikes: 2012 YZF R1
I needed them
I have a 2012 and I wasn't going to get them until I got the auto tune for my power commander, if you run an auto tune it won't read the Air fuel ratio correctly without the plates. So if your running a tune be it auto or on a dyno I would put them on. I got the graves ones for real cheap and they were really easy to install
11-28-2012, 11:01 PM
#17
i was being an arse.! hahaha... yeah noh we're talking about the same thing then... thats the sound i love... but prior to a reflash and custom tune it was ugly... nasty throaty pop.... okay, so we're good thenl.,!..
EXACTLY! i bought my auto-tune and graves plates at the exact same time,!...
'09 R1
Dynojet PCV
GYTR air filter
GYTR screen
tidy tail
Watsens
6000k HID
GYTR Comfort seat
HEL SS lines
11-29-2012, 11:34 AM
#18
I made my own out of 3/16" carbon fiber plate. They're lighter and look better.
The flash seems to mess up the picture. They look better in person.
11-30-2012, 04:59 AM
#19
Take the number before I do it
Bikes: 08 R1 carbon two brothers exhaust, power comander, shaved blinkers and finder eleminator
i dont mind mine it has that muscle car poping to it. but i might do it anyway for tuning purposes and everyone bitches about how loud the bike is already so what the hell pop away i guess
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
