New clutch cable : Yamaha R1 Forum
Motorcycle.com
Old 11-09-2012, 06:50 PM   #1
Halo_2
R1, art of engineering
Bikes: 09 R1
New clutch cable
For a 2009 R1
How do you set up a new clutch cable correctly at the engine side, currently it has 10mm slack at the clutch lever but when i pull in the lever in and then release it has a very small friction point (2mm) before it engages.
Halo_2 is offline   Reply With Quote
Old 11-09-2012, 10:00 PM   #2
Halo_2
Bikes: 09 R1
Just tried this, correct ?
Completely undid the clutch lever adjuster then on the engine side did it up so the arm has 2mm movement then on the clutch lever adjusted so friction point is halfway though theres no slack.
Old 11-12-2012, 05:26 AM   #3
Halo_2
Bikes: 09 R1
Someone?
Old 11-14-2012, 01:13 PM   #4
Racer Dude
Racer Dude's Avatar
Bikes: 00 R1
Bogie is the man, and I should learn not to mess with him
Racer Dude is offline   Reply With Quote
Old 11-16-2012, 01:45 AM   #5
Halo_2
Bikes: 09 R1
Bump
