» Site Navigation |
» Motorcycle Forums
11-11-2012, 02:40 PM
#1
Bikes: 2009 R1
VIDEO HOWTO: Install SS Brake Lines
I decided to document my installation of the Goodridge SS Brake Lines on a 2009 R1. Procedure should be pretty universal I imagine. Unfortunately I have to take the video and do the work, so it's more of an outline then an in-process video, but should give a pretty good idea of the overall procedure and what you're in for. Make sure to up it to 720p or 1080p for better resolution.
Install Brake Lines:
Bleed Brake Lines:
2009 Yamaha YZF-R1
-Graves Cat Eliminator Carbon/Ti Exhaust, Frame/Clutch Sliders, Smog Block Off Plates
-Flash-Tune reflashed ECU,Dynojet PCV
-Fender Eliminator w/ LED signals, LP flushmounts, OEM Seat Cowl
-Ballistic Evo2 8-cell battery
-ASV C5 Shorty Brake/Clutch Levers (blue), Renthal Dual Compound Grips
-Zero Gravity Corsa (light smoke)
-Goodridge SS brake lines
-Driven 520 conversion 16/45, RK GXW Chain, Probolt Sprocket Nuts
-GBRacing Case Covers
Reason: Added bleed video
11-11-2012, 02:46 PM
#2
Sonic Boom!
Bikes: 2001 Yamaha R1
Cool
11-11-2012, 03:13 PM
#3
It's just like a video game.
Bikes: 2011 R1
Great Video it was awesome quality in 1080p. Nice bike, where did you get your carbon exhaust shield from, the one covering your Y Pipe?
Cheers
11-11-2012, 03:18 PM
#4
I RACE U LOSE
I installed the same lines from RD as well last month. Things I did different were, drain fluid from lines at caliper into a water bottle instead of draining through the bleeder,and ran the front lines ahead of the fork tubes for better clearance and looks without stock bracket. Thanks for adding the vid for people that would otherwise pay for installing.
'06 50th GYT-R CarbonSlipons,Akra Y Graves stacks,blockoffs,covers BMCair Bazzaz Zafm Zfi mapsw Vortex w/520ERV3 Shogun sliders Vortex rearsets Renthal med.comp Ballistic12cell Stompgrip CRG levers Galfer SBK fr&rr rotors ProboltTi  '12 50th WGP#145. Graves full Ti carbon ex,stacks,blockoffs BMCair Yosh case,oilfill,yokenut,axleblocks Renthal w/520ERV3 CRG RC2's Watsen's Shogun framesliders Renthal med.comp Ballistic8cell ProboltTi  Lucky 13th R1-013Squadron Member
11-11-2012, 03:27 PM
#5
I RACE U LOSE
The shield is a Graves, got one of those too with my full Ti system.
11-11-2012, 05:32 PM
#6
Bikes: 2009 R1
Correct, mine came as part of the 3/4 system package.
2009 Yamaha YZF-R1
11-11-2012, 05:36 PM
#7
Bikes: 2009 R1
Yeah, I had to use a few zip ties to make sure all the clearances were ok. The stock ones were a little less stiff, so this I think can use a little help getting held in place. Only reason i went behind was because that's how the stock ones ran but I like the in front idea, seems like it may take up a little of the extra length. Do you have a picture of how you routed it?
2009 Yamaha YZF-R1
11-16-2012, 06:52 PM
#8
Bikes: 2009 R1
Edited the original post to include a Bleed video as well
2009 Yamaha YZF-R1
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
