Recommendations on SS brake lines and pads? : Yamaha R1 Forum
Old 11-14-2012, 10:26 AM   #1
manofsteel2000
manofsteel2000's Avatar
I was looking for some steel braided brake lines front and back and some brake pads. I dont want pads to extreme that they squeak. Any recommendations? Also I might as well change my break fluid what are you guys using and how much? Will I feel a breaking difference with SS lines?
manofsteel2000 is offline   Reply With Quote
Old 11-14-2012, 10:53 AM   #2
z064life
R1 Forum Star
z064life's Avatar
Motul 600..yes you will feel a difference.....Goodrich Supersport lines.
There is also a search button...
Old 11-14-2012, 10:55 AM   #3
smalltrack
big tracks scare me
smalltrack's Avatar
Bikes: R6 track slut
Fren Tubo lines and Motul RBF 600.
smalltrack is offline   Reply With Quote
Old 11-14-2012, 11:44 AM   #4
AKDMA
Bikes: 2011 Raven R1
I use:
Spiegler SS lines
Carbone Lorraine XBK5 pads
Motul RBF600
It's definitely an upgrade, well worth the nominal cost.
AKDMA is offline   Reply With Quote
Old 11-14-2012, 12:01 PM   #5
gsxcorey
MummyMan
gsxcorey's Avatar
Bikes: 1999 r1, 07 GSXR 1k
Spiegler lines probably look the best and pay the closest attention to detail. However, if you don't care about looks and performance is all you care about then get the cheapest set of name brand lines like the Goodridge clear lines. All lines will perform the same in that they don't flex.
As for fluid motul RBF600.
For pads it depends on what you're using it for. If it's just commuting then go with some ebc's. If you want aggressive street pads then carblone lorrain sbk5's or performance friction .95's would be great. If it's mostly track then the Performance Friction .07's are very hard to beat.
Check us out on Facebook too.
gsxcorey is offline   Reply With Quote
Old 11-14-2012, 03:21 PM   #6
Blue Streak
I've fallen and I can't get up
Blue Streak's Avatar
Bikes: 2000 Yamaha R1
Spiegler lines - although I would say all SS lines are all comparable. Like Corey said the Spieglers look the best IMO and you get color choices for lines and banjoes.
I use ATE Super blue fluid ( as seen in pic )
And just started using Performance Friction pads but have yet to try them on the track.
Vesrah good for pads too.
Blue Streak is offline   Reply With Quote
Old 11-14-2012, 03:29 PM   #7
Flexxx
*Insert Witty Phrase Here*
Flexxx's Avatar
Bikes: 09 R1(project), 07 zx6r(sold), 05 R6(sold), 03 R1(sold)
check out coremoto.com. I run these and they are somewhat "new" to the field, but I LOVE my lines. There is also another forum member that has these and says nothing but good things about them.
SAVE A HORSE, RIDE A CROSSPLANE
My Build Thread
http://www.r1-forum.com/forums/showt...602&highlight=
Flexxx is offline   Reply With Quote
Old 11-14-2012, 04:10 PM   #8
Blue Streak
I looked at them - the only reason I went with Speigler (and glad I did) is because you can tweak the fitting so that it fits perfectly onto the brake caliper or MC. It comes with a little plastic tool and pipe to adjust them as required.
I have found that even though they come custom made (fittings exactly same as OEM) the don't usually sit exactlly the same way as stock because they are thinner and stiffer and I seem to route tehm a little bit differently.
Prices were about the same.... but since motomummy gave me great service in the past I gave them my business again.
Old 11-14-2012, 04:45 PM   #9
lobsterhound
lobsterhound's Avatar
Bikes: 03 600rr, 02 r1
My core motos fit beautifully. They also have more options for color of line, tag, bango and sleeve. The bangos were labeled for top or bottom, front or rear and were set on the line to fit in the grooves on rear caliper. They also kept the logo on the tag facing out perfectly on every line
Sig pic courtesy of Uncle Petrol "Guard against the impostures of pretended patriotism." -G. Washington
lobsterhound is offline   Reply With Quote
Old 11-14-2012, 04:46 PM   #10
lobsterhound
Here is a link to a full review I did of core motos. I ordered on a Monday and had them at my door on the same Friday custom made.
http://www.r1-forum.com/forums/showt...highlight=core
Old 11-14-2012, 04:47 PM   #11
Flexxx
Flexxx's Avatar
Color options and fitment were with my lines.
My Build Thread
Old 11-14-2012, 05:25 PM   #12
JLeosnow
Greenfield, MN(55357)
JLeosnow's Avatar
I also just ordered a set(3) of CoreMoto lines myself as well. I ordered them yesterday and had a tracking# this morning!
-John
Click here to E-mail me -> JLeosnow@att.net
2011 R1
Carrozzeria V-Track wheels
Galfer wave rotors(3)
Michelin Pilot Power tires
09/10 Blue tail conversion
09 upper fairing decals
GYT blue seat cowl
Passenger pegs removed
NoMar rear master cylinder bracket
Akrapovic carbon slip-ons
M4 Y-pipe
FlashTune reflash
Power Commander 5
Power Commander AutoTune
6000k HID headlamps
Watsen flush mounts
Custom LED Blaster-X tail lamp
Black Rearsets
CoreMoto SS brake lines
JLeosnow is offline   Reply With Quote
Old 11-14-2012, 05:58 PM   #13
SPanega SS
Frnds dn't let frnds apx early
SPanega SS's Avatar
Bikes: Less than I want
Fren Tubo type 3 and Super Blue: street
Fren Tubo type 4 and Super Blue: track
Sig courtesy of my brotha from down unda PetrolSpice
SPanega SS is online now   Reply With Quote
Old 11-14-2012, 06:03 PM   #14
Blue Streak
They look good but I hope you clean your bike every once in a while
Old 11-14-2012, 06:17 PM   #15
SPanega SS
SPanega SS's Avatar
Ouch
Old 11-14-2012, 06:53 PM   #16
lobsterhound
I had just gotten back from a 1500 mile trip the day before I installed the lines. Had some nasty weather on the way back
