» Site Navigation |
» Motorcycle Forums
11-14-2012, 04:37 PM
#1
U win some U lose some
Bikes: 2009 VMAX, 2006 R1 50thAE
04-06 to 07-08 brake difference?
Are the brake rotors the same or is there a difference?
Can I put 07 forks and 6pot brakes on my 06 and have it line up with my current rotors?
Thanks
11-14-2012, 04:42 PM
#2
The Lead Farmer
No.
Originally Posted by Fikays
Kirk is a total chick.
11-14-2012, 05:09 PM
#3
Originally Posted by Meister37
No.
Well poop. New rotors too? Will they at least bolt to the 04-06 wheels?
11-14-2012, 05:39 PM
#4
The Lead Farmer
You will need new rotors and fender. The wheel is the same. The 310's bolt right up.
11-19-2012, 03:47 PM
#5
Apparently all I need are these spacers... perfect fit... for '06 320mm rotors and the '07 up brakes/forks
11-19-2012, 03:54 PM
#6
R1der
Bikes: 2006 R1 Blue
did you do the swap? so you are doing this mod on a 06 right? basically getting 6pot brakes on a 06?
11-19-2012, 04:09 PM
#7
Doing it here shortly...
Picked up the '07 forks with Ohlins internals from RSV4 and will have them this week. I had some '07 brakes laying around. Anyway I wanted to keep my Galfer rotors $$$ and this way I can!
11-22-2012, 07:25 PM
#8
Bikes: 04 R1
Agreeded kingnba6. Im doing the same thing actually.. 2008 forks and the 6 piston calipers will botl right up ypu just need a 5mm spacer the fit for the larger rotors on the 04-06 models
11-24-2012, 05:29 AM
#9
Done... also painted the spacers. You have to look hard to notice them.
11-24-2012, 07:17 AM
#10
R1der
Bikes: 2006 R1 Blue
great work! made a lot of peoples life easier
| Sponsored Links |
| Thread Tools |
| Display Modes |
Linear Mode
