Fault code 3K on Tacho 99 R1 : Yamaha R1 Forum
Old 11-15-2012, 04:58 PM   #1
steiner
Bikes: Blue 99 sold, Red white & black 02 sold. Raven 06 Sold. Blue 99 07 CRF 450
Hi I have a fault code on my tacho, it jumps to 3k engine running or not then returns to normal. I was told that it is to do with the actuator on the carbs. i have checked the loom and it looks good. Would my assumption that the actuator is fubar be correct??
Thanks
steiner is offline   Reply With Quote
Old 11-15-2012, 07:20 PM   #2
Sharksawyer
Is there anybody out there?
Bikes: 99 R1
3000 rpms: Throttle Position Sensor
7000 rpms: EXUP related
8000 rpms: fuel level indicator light
There's a procedure in the service manual on how to adjust the TPS. Either needs to be adjusted or replaced. You'll need a security Torx bit to adjust it.
Mark
99 R1
