Dot 5 fluid : Yamaha R1 Forum
Go Back   Yamaha R1 Forum: YZF-R1 Forums > R1 Related Discussion > Oil and Lubrication
Oil and Lubrication For discussion on oil and lubrication
Old 11-16-2012, 05:36 PM   #1
CroR1
Is that right!
CroR1's Avatar
Bikes: '08 BlueOne
Dot 5 fluid
Does anyone have any experience with the brake fluid from the local parts store? Seems to be inexpensive, and It's time that I flush mine.
For Sale Items;
07-08 Stock Parts
http://www.r1-forum.com/forums/showthread.php?t=289055
CroR1 is offline   Reply With Quote
Old 11-16-2012, 05:48 PM   #2
rorytsm
damn turkeys
rorytsm's Avatar
Bikes: 04 R1
what are your uses of your bike? certain brake fluids (even those dot 4 varieties) can have higher boiling points than the typical auto parts store dot 5 fluids.
Join Phantom Squadron
PDB and loving it! whoo hoo!
04 R1 - sunbeam yellow w/custom decals
rorytsm is offline   Reply With Quote
Old 11-16-2012, 05:55 PM   #3
CroR1
Is that right!
CroR1's Avatar
Bikes: '08 BlueOne
Intresting, I thought the standards would be the same across the board.
Street and a track day here and there.
For Sale Items;
07-08 Stock Parts
Old 11-16-2012, 05:59 PM   #4
rorytsm
damn turkeys
rorytsm's Avatar
Bikes: 04 R1
so what's your reasoning for looking at dot 5 vs sticking with dot 4 fluids?
Old 11-16-2012, 07:40 PM   #5
James D G
O'Gradys Paint
James D G's Avatar
Bikes: YZF R1 of course
Mix dot 5 fluid in a system already running dot 3 or 4 and you're fukced.
You can run 5.1 but it's poo compared to the proper high end dot 4.
James D G is offline   Reply With Quote
Old 11-17-2012, 02:50 AM   #6
CroR1
Is that right!
CroR1's Avatar
Bikes: '08 BlueOne
What brands would you consider higher quality when it comes to D4?
For Sale Items;
07-08 Stock Parts
Old 11-17-2012, 06:34 AM   #7
ss55539
Bikes: '11 FLHX, 09 YFZ450R, 07 YZ450F, 06 R1 50th
the only way you can run the 5 is to completely flush the system, but you will never get it all out. the 5 is silicone based and DOES NOT mix with the others. realistically the only way to run it is to have all new components.
just get the 4
ss55539 is offline   Reply With Quote
Old 11-17-2012, 06:56 AM   #8
CroR1
Is that right!
CroR1's Avatar
Bikes: '08 BlueOne
I figured with new goodridge steel lines, and cleaning the bottle and caliperS that I should be ok. I dont know.
For Sale Items;
07-08 Stock Parts
Old 11-17-2012, 06:59 AM   #9
z064life
R1 Forum Star
z064life's Avatar
I dont know.
This is the only part of your post that is correct
Stick with DOT4...there is no reason to go to DOT5 and you won't get it all out anyway
Old 11-17-2012, 01:38 PM   #10
CroR1
Is that right!
CroR1's Avatar
Bikes: '08 BlueOne
What's a beter setup, one line from cylinder splitting into two, or two lines from cylinder running to calipers? In other words, what stops quicker and has a better feel?
For Sale Items;
07-08 Stock Parts
Old 11-17-2012, 01:52 PM   #11
ss55539
i like the one into two, but ended up getting double fren tubos
Old 11-17-2012, 02:02 PM   #12
CroR1
Is that right!
CroR1's Avatar
Bikes: '08 BlueOne
Elaborate further please. Why?
For Sale Items;
07-08 Stock Parts
Old 11-17-2012, 02:12 PM   #13
z064life
R1 Forum Star
z064life's Avatar
differing opinions on which one works better....you won't notice a difference. Some say the 1 into 2 the pads wear unevenly on either side
Old 11-17-2012, 02:32 PM   #14
sircharles1
Street Runnerz M/C Natl. Prez
sircharles1's Avatar
Bikes: '03 R1, '07 GSXR750, '08 GSXR1000... all stretched and sitting in the dirt
this is comedy
How do you know the tooth brush was invented in Kentucky? If it were developed anywhere else it would be called a teeth brush.
What do you call a female virgin in Kentucky? Faster than her brothers.
Kentucky: 5 million people, 10 last names.
Why couldn't the baby Jesus be born in Kentucky? Because they couldn't find 3 wise men or a virgin.
Why are there so many unsolved murders in Kentucky? There are no dental records and everyone has the same DNA
sircharles1 is offline   Reply With Quote
Old 11-17-2012, 05:55 PM   #15
IMSTuner
IMSTuner's Avatar
Bikes: 2008 R1
Just get ATE super blue.
http://www.tirerack.com/brakes/brake...cat=BrakeFluid
2008 R1 Black - Gold AVS C5 Levers, Puig DB Wind Screen, EvoTech Sliders Kit, T-Rex Clutch slider, Stomp Tank Pads, LeoVince Ti Factory Evo II CF end caps, Arko Y-Pipe, R&G Fender Elim., Proton Signals, PZRacing GearTronic Zero , Q2 tires, Flash-Tune Interface
My Build Thread http://www.r1-forum.com/forums/showthread.php?t=336353
YouTube Page http://www.youtube.com/user/imstuner?feature=mhee
IMSTuner is online now   Reply With Quote
Old 11-30-2012, 08:03 PM   #16
mr2guru
U win some U lose some
mr2guru's Avatar
Bikes: 2009 VMAX, 2006 R1 50thAE
ATE or RBF600
mr2guru is offline   Reply With Quote
Old 12-01-2012, 09:34 AM   #17
Racer Dude
Racer Dude's Avatar
Bikes: 00 R1
Glycol-ether (DOT 3, 4, and 5.1) brake fluids are hygroscopic (water absorbing), which means they absorb moisture from the atmosphere.
silicone fluid should be used only to fill non-ABS systems that have not been previously filled with glycol based fluid. Any system that has used glycol based fluid will contain moisture; glycol fluid disperses the moisture evenly throughout the system and contains corrosion inhibitors.
Silicone fluid does not allow moisture to enter the system, but does not disperse any that is already there, either. A system filled from dry with silicone fluid does not require the fluid to be changed at intervals, only when the system has been disturbed for a component repair or renewal.
Non-hygroscopic fluids (e.g. silicone/DOT 5-based formulations), are hydrophobic, and can maintain an acceptable boiling point over the fluid's service life, although at the cost of potential phase separation/water pooling and freezing/boiling in the system over time - the main reason single phase hygroscopic fluids are used.
The United States armed forces have standardised on silicone brake fluid since the 1990s. Silicone fluid is used extensively in cold climate, particularly in Russia and Finland, as glycol based fluids have to be replaced at regular intervals.
Motul RBF 600 brake fluid (DOT 4)
Boiling point
Dry: 594F
Wet: 421F
Bogie is the man, and I should learn not to mess with him
Racer Dude is online now   Reply With Quote
Old 12-01-2012, 09:35 AM   #18
Racer Dude
Racer Dude's Avatar
Bikes: 00 R1
Boiling point
Dry: 594F
Wet: 421F
Not very likely you will boil this brake fluid over
Old 12-01-2012, 09:40 AM   #19
TheBigO
TheBigO's Avatar
Bikes: 2006 R1
just get the 4
Ive ran dot 5 in my 06. I just drained it then bleed the system. Ran like that for 2 years. No issues. Only thing with dot 5 the brakes feel a bit spongy. I was gonna go back to dot 4 but i sold it sooo.
Sent from my DROIDX
TheBigO is offline   Reply With Quote
Old 12-01-2012, 12:20 PM   #20
Racer Dude
Racer Dude's Avatar
Bikes: 00 R1
Originally Posted by TheBigO View Post
Only thing with dot 5, the brakes feel a bit spongy.
That is good to know. Nobody want's a spongy feeling brake pedal/lever. This is more than enough reason not to use silicone based brake fluid.
