Help... Need info on caliper/fork offset : Yamaha R1 Forum
SportbikeTrackGear
Old 11-24-2012, 05:59 AM   #1
wildweasel_pt
Hi all
i need to know if i can replace a set of forks from a 04-06 for a set of forks from a 07-08. I know 04-06 uses 320mm rotors vs 310mm for the 07-08 but that does not matter. What i really need to know is if the offset on the caliper will allow me to fit the rotors centered on the calipers, that is the distance between the center of the caliper bolts to the center of the rotor slot in the caliper is the same for both model bikes?... If someone can help me i'd be very appreciative. I assume already done this upgrade already right? Thanks in advance
Fred
wildweasel_pt is offline   Reply With Quote
Old 11-24-2012, 06:55 AM   #2
mr2guru
U win some U lose some
mr2guru's Avatar
Bikes: 2009 VMAX, 2006 R1 50thAE
Offset is fine... need honda spacers. That's it.
http://www.r1-forum.com/forums/showt...wpost&t=347337
mr2guru is offline   Reply With Quote
Old 11-24-2012, 09:19 AM   #3
wildweasel_pt
What are those spacers for? FOr the calipers to use the original 320mm rotors instead of the 310mm from the 07-08? Im running 310mm rotors already. See below... Kawasaki ZX-14 310mm rotors on the 04-05 R1 forks... But it seems im gonna need a new fender right?
Old 11-24-2012, 02:02 PM   #4
mr2guru
mr2guru's Avatar
Ok 310mm, no spacers needed. Fender is the same... I used my 06 fender and it fit the same.
Offset is the same.
Old 11-24-2012, 02:35 PM   #5
wildweasel_pt
Cool mate
Thats good news. I see you also have a vmax. Take a look at mine... Gen 1 though... LOL
Old 11-25-2012, 05:03 PM   #6
MotoGPracing
MotoGPracing's Avatar
Bikes: YZFR1SPV
So, how did you get the pads/calipers to work with them? You , know... to sit properly?
MotoGPracing is offline   Reply With Quote
Old 11-25-2012, 05:16 PM   #7
mr2guru
mr2guru's Avatar
Looks like a bit of pad is hanging.
Old 11-25-2012, 06:17 PM   #8
wildweasel_pt
Not really... The difference is less than 5mm and the pads don't go all the way to the back of the caliper. Works fine but on the edge of the disk i assume... I didn't bother to lower the caliper mounts...
Old 11-25-2012, 08:06 PM   #9
mr2guru
mr2guru's Avatar
Nice front end conversion on that black max... I bet it helped tremendously!
